Question about Samsung RS2534 Side by Side Refrigerator
Freezer temp erratic, so cold 1 min it freezes water in dispensor next min ice cubes are melting. assume thermostat is faulty. how do i replace?
  • 700 Answers
What it sound like is that its frozen up (the coil) take and push the top two buttons on the cotroller for about 8 seconds until the display blinks and then that will reset the controller. my email is my at gmail.com and if you email me I can send you the list for troiuble shooting the unit's codes.
Posted on Feb 23, 2009
Have replaced everything and ice maker still doesnt work model ed5shaxmb10
An ice maker has 3 basic tasks:
1. Call for water.
2. Freeze.
3. Harvest.
Then the cycle repeats. There will always be some sensors that determine timing of those tasks. Home units usually have a bin level sensor (often an arm that's lifted as the bin fills) that can be locked in the up position to disable the ice maker.
If it's calling for water but not freezing, make sure the condenser is clean. (Sometimes they look clean but are plugged in the middle.) It has to get down to nearly 0 degrees to efficiently make ice, if it's not getting cold enough you may need a tech to figure out why.
If there's ice in the tray but it's not harvesting, clean the tray, hard water deposits can make the cubes stick in the tray.
May 26, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
My GE Profile fridge freezer is having issues staying cold and also with preventing frost. Now it is melting from the ice bin.
If the auto defrost mechanism is not working, specifically, the defrost heater you will have ice buildup in unit and warmer temps all over. Check here for part(s) Search Over 2 1 Million Appliance Parts
Sep 07, 2017 | Refrigerators
Frozen freezer water line
Odds are your temperature is too cold in your freezer. If when you moved you just plugged in your freezer without adjusting your temperate for your new location you accidentally froze whatever water was coming into your freezer.
First you will need a cooler for whatever you have in your freezer, unless you have wonderful neighbors who will let you keep your food in their freezer for couple of days.
Take note to see what your freezer thermostat is set to. Turn off your freezer. Take out all the food. Keep the door open. This would be a great time to clean your freezer. Let the freezer thaw out for at least one day. Check the line to make sure there is no ice. Once everything has melted turn your freezer back on. Turn your freezer back on but this time set the thermostat to three or maybe 4 levels below what you had it set to before.
Finding Freezing level:
Fill an ice cube tray or small plastic cup with water. Put it in your freezer and come back in about three hours to see if has begun to freeze. If it has not begun to ice raise your thermostat to make you freezer colder by half or 1 level. Leave the ice tray or cup of water that you originally placed in the freezer but add another one. Come back in three hours to see if the water has frozen or has begun to freeze.
You want to leave the original water because you need to make sure the new water does not freeze solid as fast as the original water. If it does your freezer is too cold again.
Repeat "Finding Freezing level" until the water begins to freeze but does not freeze solid. Once your ice begins to free you can put your food back into the freezer. Wait a couple of hours more to see how much more your cubes freeze. If they are hollow or still watery in the center you should go up another half level and check on it the next day.
Once your cubes freeze solid you should be all set. If you don't get at least one tray of ice per day from your freezer you could go up another half level so your ice freezes faster.
Be careful about making your freezer colder because you might end up with the same problem you started with depending on how sesitive you thermostat is.
May 03, 2012 | Maytag MSD2578VEM (254 cu ft) Side by Side...
Model TXI 20ML Ice maker is melting ice cubes in the grooves and blocking them from falling into tray-not making any ice. Took out IM let it thaw then replaced. I increased the freezer temp from 4...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 20, 2011 | Amana Top Freezer 20.6 cu. ft. Top Freezer...
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Ice maker not completing cycle
You need to check the thermostat setting. If its set too cold it will never dump ice. Warmer the setting the more ice it will make.Also check the temp. If it should be 10-15 degrees. If its 5 degrees then turn thermostat to warmer setting.
May 09, 2009 | U-Line Icemaker
Top freezer food gets freezer burn fast and now ice cubes and ice
Your discribing 2 opposite symptoms. But 1 thing may be causing both. first thing I think of is a defective defrost heater safety switch. It allowes the food -and freezer compartment to become too warm during defrost. This allowes the food to un freeze. then when defrost is terminated the temp goes back under freezing til the next defrost. 3 to 5 cycles like this and yes you could ahve freezer burn and icecream melting. DOes the ice cream refreeze too? If so you have to remove the freezer pannel covering the evaporastor coil inside the freezer. Locate the defrost safety.
1 of 3 kinds 2 opf these are b8-metal switches and are round and of these 2 kinds 1 is about nickel size and the other is about quarter size and both are round and can be attached to the coil tubing or the freezer wall. Usually these 2 kinds are on Refg/Freezers with no electronics on the door or thermostat.
If you have an Led or LCD display you ahve electronic controls and in most cases have an electronic thermisitor about 1" long and 1/4 to 3/8 inch dia and insulated and attached to the freezer coil line leaving the freezer or on one of the U bends of the coil. It may be attached with a plastic wire tie. (The tie could be broken but this is doubtful from discription).
1st freezer burn is usually caused by drying out of the food while still frozen. And this is why your case is so interesting by doing it so quickly. In all cases 1 the food is not in air tight containers. And the water in the food is being drawn out of it.
May 08, 2009 | Electrolux Refrigerators
Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
Apr 21, 2007 | KitchenAid KSRS25ILSS Side by Side...
Samsung RS2534 Side by Side Refrigerator Logo
82 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
