Question about GE Dishwashers
DIRTY DISHES ,HAZY GLASSES.ALL SOAP NOT GONE
DIRTY DISHES ON TOP RACK GLASSES NOT CLEAR SOME SOAP STILL THERE MAYBE WARM BUT NOT HOT.
THANK YOU LENNY
  • 38 Answers
Sounds like the heater is not working, could be bad heating element, bad door switch, or bad heater relay on the main control board. Check for continuity on the heater element to rule out a burned out element. Do the same for the door switch, if all checks out good then replace control board with heater relay.
Posted on Feb 23, 2009
Top rack not rinsing
Check the hose that connects the top sprayer to make sure it is connected and there is no holes or cracks in that hose.
Jan 28, 2013 | Dishwashers
Top rack not washing. All soap not cleaned out of dispenser
This may sound ridiculous, and I'm no "expert", but are you starting out with really hot water (i.e. running the faucet at the kitchen sink until hot water comes out)? My wife refuses to do this and she encounters the same problems: dirty dishes and leftover soap. *I* make sure that hot water is readily available to the dishwasher (even though it's *supposed* to heat it for you) and never have either issue.
Feb 07, 2012 | Dishwashers
DISHES ON TOP RACK NOT GETTING CLEAN, GLASSES HAVE A HAZY RESIDUE.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 20, 2011 | Maytag Dishwasher
Glasses int he top rack of my kitchenaid dishwasher don;t get clean. they finish the run spotted and covered in what looks like baked on dirty dishwater. dishes in the lower rack look ok, but the...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 11, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
There has been a trail of dry soap on inside of door after wash is complete, also dried soap on some dishes in bottom rack as well as not being clean and on top rack spots on glasses and sometimes some...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 28, 2010 | Hotpoint 24 in. HDA900X Built-in...
My dishes come out dirty and glasses are cloundy.
#1 check the upper spinner arm to see if it is clogged with particles if it is, clean the holes outi f they get clogged the arm-sprayer will not clean the upper rack
#2 if it is not clogged got to your local Grc.chain and purchase a bottle of dishwasher cleaner for about 8.00 follow all instructins on bottle make sure water is hot by running hot water tap closest to dishwasher.use it in an empty dishwasher.You will be amazed how clean your dishes will come out after the first wash
Jan 23, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
UNDISSOLVED SOAP RESIDUE AND
I have the same dishwasher and kept having soap still in the dispenser at the end of the wash. Someone mentioned this, but what was happening is that the soap dispenser lid was blocked from fully opening by the top rack. You also typically have large pans in this area, so the water spray is blocked from getting under the half open lid well. I started opening the dishwasher after I heard the dispenser latch release, so the lid could fully open. After that, I had no problem with soap still in the dispenser. I started setting a timer to open and shut the dishwasher door about 20 minutes into the wash process (after the latch had released for the 2nd wash cycle), so the soap dispenser lid would be fully open. This was a pain, but it worked. The other thing to be careful of with this dishwasher is to ensure you have pushed the top rack in tight before closing the door. Look at the water connection for the top "spinner" and you will see how the plastic pipe fits up to the supply. If you don't have the rack pushed in tight, you get leakage around the connection and don't get good water spray from the top spinner arms. This can definitely affect the quality of the wash. You mentioned the dispenser lid is open when the cycle is complete, but that is because once you open the door it can fully open.
Mar 26, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
233 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
