Question about Panasonic Audio Players & Recorders
Little and poor quality sound from turntable
I replaced the stylus on saturday hoping I would be able to resolve my problem. I have also replaced the cables connecting to receiver. I have the connection to the AUX input. I have to turn the volume to max to hear and quality is tinny.
  • 4,234 Answers
Turntables do not produce "line level" audio which is what is required for input into the AUX on the receiver. If you do not have a phono input on the receiver, you must purchase a phono pre-amp. These are readily available for about $20. This will boost the output of the turntable to line level so you can use the AUX input on your receiver. That will resolve the problem.
Dan
Posted on Feb 23, 2009
My crossly turntable isn't level. Sound quality is poor as a result. Any ideas? Thanks in advance.
Hello, my Crosley has the exact same problem. I'm struggling to find any answers at the moment. Did you manage to get yours fixed?!
Dec 22, 2011 | Crosley CR249TA Turntable
I have a 1984 AKAI stack hifi system. Has been stored in garage for years. Brought it out yesterday and all appears to be working well except when playing records on the turntable the sound from one...
Just had a search and found this
http://www.epinions.com/inst/submitted_form_~ultrafinder/ultrafinder_submitted_~%20Go%20/search_vertical_~all/search_string_~Akai%2520Stylus%2520Needle%2520Apx1c%2520M313w%2520M452%2520cd%2520M50%2520M502%2520M512
Hope it is useful for you
www.epinions.com
Aug 04, 2011 | Akai Stylus Needle Apx1c M313w M452 (cd)...
Looking to upgrade the cartridge/styli in my ion audio profile pro turntable. What products/company/style should I be looking for?
I have the same turntable, and sadly the cartridge is proprietary and unable to be changed. However, you can still upgrade the sound quality by replacing the stylus to a higher quality needle. I did that for about $25 and feel better about playing my precious vinyl. The biggest problem to this turntable is the lack of anti-skate. That's very bad...
Mar 27, 2011 | ION Audio Turntable Cartridge Replacement
I have a TT1600 Turntable. I need to replace the Stylus. Can you provide me with the part number?
The correct stylus will depend on which cartridge is fitted to your turntable - these can vary. Makers name and model number should be printed on the cartridge. Personally, however, I prefer to replace the whole cartridge not just the stylus for better quality sound.
Feb 24, 2011 | Numark TT1600 Turntable
The sound quality gets real bad after playing for a while. If I take the cartridge out and put it back on it sounds fine again for a while. Should I just replace the cartridge or could it be in the tone...
Are you sure it's not the amp it's connected to that's not the problem? Magnetic cartridges have to be amplified by a pre-amp inside the main amp. It's sole purposes is to do just that, so the rest of the amp can work just fine. Most of these pre-amps are just a single IC and a few other parts. From what you describe the IC is perhaps getting hot, due to some internal fault, when a signal is applied to it. Break the signal and it cools down making it sound normal. There could be one in the turntable itself, but I doubt it.
If you are good with a soldering iron you will find the IC by tracing the wires back from the turntable imput socket on the amp. Conecting the turntable to another amp will confirm it either way.
Jan 30, 2011 | Technics SL-BD20D Turntable
Can hardly hear the record playing on an old panasonic se 2519 turntable. How do I know if the cartridge, needle, or belt needs replacing?
The belt will only need replacing if it breaks or falls off, or the sound has wow and flutter on it. It will not effect the sound level. First has the sound level gone down or is this the first time you have connected it to your amp?
If it is the first time, you need to check the amp has a 'magnetic cartridge pre-amp' built in. If you don't know look at where the turntable plugs in. If it doesn't say phono or record deck etc, then it most likely doesn't. In which case search on the net for one.
If the sound has gone bad then: (A) sound quality poor - change stylus. (B) sound level low change cartridge. A good test to determine it's the cartridge is to remove the wires to it. With your amp working touch them one at a time. You should hear a loud buzz on the right on one wire and and another buzz on the left on another wire. The other two wires should not produce any sound or little.
If you do hear the buzz then the cartridge is faulty, if not then either the amp isn't working or the connections between the two devices are faulty.
Nov 14, 2010 | Panasonic Audio Players & Recorders
This is a question for my daughter who lives in Japan. She has a Crosley turntable she bought from Urban Outfitters. The stylus arm has suddenly started skating over the record, ie won't play anything. ...
I have no experience of Crosley turntables, however, stylus arm skating across the record surface on any turntable is normally due to the counter balance weight being incorrectly adjusted. In order to track across a record properly, the stylus must press down on to the record very lightly. If there is too little pressure, skating is what tends to happen. Too much pressure can cause distortion of the sound and excessive wear of the record.
At the pivoting end of the stylus arm, there should be a counter balence weight. This is normally adjustable (but not always - depends on quality and features of the particular turntable), and is used to set the pressure the stylus applies to the record surface, measured in grammes. The manual that came with it should tell you how to adjust it, but for most turntables stylus pressure is between 1 to 3 grammes.
If you dont have the manual, have a good look at the pivoting end of the stylus arm to see if soemthing is obviously wrong, or if not whether there is something with numbers on it that can be turned or slid. This is likley to be the counter weight. Try adjusting it.
Within reason, the stylus weight isnt critical so a "trial and error" approach wont do any harm.
Nov 12, 2009 | Crosley CR249TA Turntable
Poor quality sound
Double check all your cables. The only 2 things that affect sound on the 1200s is the RCA cables and the tonearm. I would first replace the RCA cables to a better quality set.
- OPTiC
Technics Repair Videos
Technics Turntable Repair
DJ Equipment Sales
Technics Parts Sales
Jan 16, 2009 | Technics SL-1210 Turntable
Poor sound output
One of the wires from the stylus had a poor connection through the pin connector.
I recrimped the pin lug reconnected and all is now working as it should.
Jan 01, 2009 | Ortofon Stylus DJE Turntable
176 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
