Question about HP Pavilion a305w (DM181AR) PC Desktop
Net server not starting
When try to start the server service i m getiing a problem
i have to restart the comp...pls help
  • Samiullah May 11, 2010
    your did not explain your prob friend lil bit explain that
  • Deboo Geek May 11, 2010
    What version of Windows are you using?
    What is the error you are getting?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
Can you get the error code and post it. We can identify the problem through that code in order to resolve the issue.
Since there are many services that are running on the same server, you cannot tell unless you know it's dependencies why is it happening.
Posted on Feb 26, 2009
My lexmark p707 has just stopped printing. It keeps cancelling jobs and tells me to reinsert the cartridges (which I have done). But is still not working. Help pls?
It could be due to the Print Spooler on your computer. Please follow steps below to ensure print spooler service is running and print queue is clear from pending print jobs.
  1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
  4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Try to print again.
Jun 23, 2011 | Lexmark P707 Photo Jetprinter InkJet
Hi i have problem E00064-0000 since yesterday what is the problem can you pls help thank you
Restart print spooler service on server..IF does not work
please let me know in explain ,what exactly happened?
Mar 06, 2011 | Canon (6981A002AA) for imagerunner 2200,...
My print spooler service is not running
Try This :
Click on Start >> Run >> CMD >> OK
Type in SC CONFIG SPOOLER DEPEND= RPCSS
Press Enter
Then try to restart the compter
Then try to restart the print spooler this should resolve your issue
otherwise get me the exact error message you are getting
Regards
Sandeep
Oct 06, 2009 | HP Computers & Internet
Printing Problem.
RPC server may not be started issue the following command to start the RPC server:
net start rpcss
I successfully ran the command to resolve a previous problem. keep me posted
Jul 23, 2009 | Computers & Internet
How to stop DCOM server prosess launcer service terminated unexpectedly...plssss
your comp is infected for sure.i`ve seen many cases where my customer`s comp is infected and they face the same problem.
Simply turn on your computer. Wait for that rebooting message to appear. and go to: Start --> Run
If you can't find it quick enough.
Pressing the "Windows button" + R simultainusly will do the trick. a little window will pop. type in "shutdown -a" without the quotes. and press Enter or click ok.
download,install and run this software.after running the scan clean all the infections and restart your comp.
http://www.download.com/Malwarebytes...dlPid=10878968
May 30, 2009 | Dell Latitude D600 Notebook
HP server with 2k3 reboots again and again.
Have you installed any service packs for Win 2K3?
if not yet, please go for the latest service packs since there were some problems identified with win 2k3 and this is one of them.
You can also try restarting the sytem in safe mode by pressing F8 after boot screen.
Hope this helps.
Thanks.
Mar 16, 2009 | HP Compaq ProLiant DL380 G4 Server
How can i make exe as a windows service without programming
There are some solutions for your problem, everything has
positive and negative side. (Pro and contra)
1. Startup folder
Put your exe or bat file to the startup folder. The Windows will start automatically when the Windows is starting. You put the exe to the desktop, then copy to Start/Program/Startup folder.
Positive: Quickest setup
Negative: To stop your program, you have to start the taskmanager. (taskmgr) You have to start taskmanager if you want to check the status of your exe.
2. Make a Windows service
Serveral ways can do it. The Windows resource kit contains
two utilities with this programs you can do it.
(instrsrv, srvany)
Here is the appropriate link:
http://www.tacktech.com/display.cfm?ttid=197
You can do it with registry modifications.
Here is the instructons:
http://www.overclock.net/faqs/119474-how-run-program-service.html
Positive: You can control your program from mmc
Negative: A bit complicated
I suggest to use service methotd instrsrv program.
I hope this helps, and you like it. :)
Jan 10, 2009 | Microsoft Windows Server Standard 2003 for...
Sql service restart
  • Hi, from the Desktop, (right, click) on the Taskbar, or press (CTRL+ALT+DEL) to open the Task Manager. Next in the (Tasks Man...) window, press the Services (tab), at the bottom of the window, click on the (Services...) button, the services open. Next scroll to find: SQL Server... and the InstallDriver Table...these will be services of interest to "Enable, and or "Start," also check the "Dependencies" of the services. Select "Apply and OK" once started. The next area you may want to check is the Computer Management, Type: (comp...) in the Start Search "window". Look in the Internet Info...Serv...(IIS)... "Providers category." "You may what to restart the computer, some services require ("rebooting") to "configurate" correctly." "If this helped, feedback is appreciated, thanks"
Dec 30, 2008 | InstallShield Update Service Version 3
Wireless
Try to restart the the Wireless Router if that doesn't work then go to:
Start-> Run-> CMD [Enter]
type in: netsh winsock reset [reset]
restart the pc... when it boots back up go back to CMD prompt and type in:
net start [enter]
this will start the net services
you may need to go type in Services.msc in cmd prompt and go all the way to bottom and enable Wireless Zero Configuration... If that doesnt work you may need to reinstall Drivers on room mates PC.
Dec 09, 2008 | Belkin (F5D7001) 802.11g/b Wireless...
Vista OS can't connect wireless to Dlink DI-614+ rounter
yes it does but what exactly is this it's your comp that's not connecting to your wireless network..so here try these steps...
first click start>click in start search>in that box type in services>it gives you an option of services on the same start menu at the top click on that...
it will take you to a new screen that says services at the top on that screen you need to scroll down at the bottom and look for wlan auto configuration rt click on it and click start if start is greyed out press restart....
close services down..
click start>click connect to form the start menu> and check it gives your network name in there .if it says anything like no network found in range. pls make sure that wireless switch on your laptop is turned on...
if still you're not able to connectr it's a concern with the drivers of wireless adapter on your comp genrally on new comps its quite common get the drivers reinstalled....
Feb 18, 2008 | D-Link AirPlus DI-614+ Wireless Router
HP Pavilion a305w (DM181AR) PC Desktop Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
