Question about Whirlpool AWG329 Front Load Washer/Dryer
Drum kepps filling water when not in use. Can anyone help me.
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds as if you have a faulty inlet water valve in your machine( where your hoses connect to the washer)replace that valve
Posted on Feb 23, 2009
Washing machine makes clicking noise after filling up and wont spin. Kepps on clicking until i force shutdown, which then drains the water away.
hi, the problem you have is the motor carbons (brushes) have worn down ( which is natural if machine is used every day ). the machine fills up with water but there is no motor action. the clicking noise you are hearing is the relay on the pcb sending a signal to the motor to turn, but with the carbons worn, there is no motor action. Easy enough to replace them. UNPLUG machine before any repairs are carried out.
Dec 19, 2013 | Indesit Washing Machines
Whirlpool Duet Water in drum when washer isn't running
Water fill valve ..Also.try outlet pipe not too low, water could be comming from sink back into machine...
Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
You have an open solenoid on your water valve where the fill hoses connect. Change the water valve and you should be good.
Jul 25, 2008 | Washing Machines
Drum filling up with water when not in use.....
only source is leaking inlet valves and only way to cure is to replace
May 14, 2007 | Tricity Bendix AW1000W Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Whirlpool AWG329 Front Load Washer/Dryer Logo
89 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
