Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman riding mower model 917.270921 put on a new battery still had to jumpstart got it running checked for charging 14volts to battery let it run for an hour runs pretty good but when i turn it off and try to start it again it wont even crank! checked all connections they are CLEAN AND TIGHT no broken wires and I am thinking valves are out of adjustment but no backfires or anything other than just will not restart without a jumpstart?
  • 2 more comments
  • ohgr8one2001 Feb 23, 2009
    just from battery to battery
  • Anonymous Feb 24, 2009
    ok took battery out and cleaned all connections tried to start nothing!!! so i jumped it again from positive to positive then negitive to negitive let it run 20 min shut it off then tried to restart with no jumper cable, now i get the seloniod clicking rapidly no start also when i touch positive from jump battery to starter it does start with key on.checked when running I am getting 14.7 volts to battery.
  • Anonymous Mar 31, 2009
    placed new battery still had to jump it told it was starter rebuilt starter still wont start without jump checked all connections and wiresthey were all good also seems to turn over slow. 17.5 hp craftsman 42"cut mdl 917.273370
  • Anonymous Mar 24, 2014
    Mower will not turn over after many tries. Then if I let it sit for 1/2 hour it turns over and starts. Battery is new
    Dedicated:
    Visited the website for 20 consecutive days.
  • Craftsman Expert
  • 242 Answers
On the exhaust valve there is a compression release, when it is not running it rotates around and holds the exhaust valve open just a little bit and after it starts centrifugal force of the cam shaft spinning causes this compression release to rotate and the exhaust valve is allowed to shut all the way. Knowing that we must properly set this valve because if it is to loose the compression release will not work and your starter and stock battery just don't have enough power to do it and if it is to tight it will not shut all the way and will be lacking power and burn out the valve face with time.
Posted on May 18, 2016
    Problem Solver:
  • 8 Answers
What method are you jump starting? Are you putting clamps from jump battery on the posts of the battery or grounding the jump battery and then touching the + cable to the starter terminal?
Posted on Feb 23, 2009
Craftsman dlt 3000
You need a new alternator...Alternators regulate current to the battery to keep it charged.
May 19, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a craftsman with a kohler magnum 18hp. If i put a battery charger on my battery it dont charge i can turn the key and it wont roll over. If i jump my lawn mower and it running i can turn the key all...
Hi, if your battery wont charge you will need to replace it and when you do you need to check that the mower is charging by checking the battery voltage with a multimeter while the mower is running. It should be around 14 volts. Regards Phil.
Sep 06, 2012 | Craftsman Garden
How to check a voltage regulator
put a volt meter on the battery and check the voltage around 12.5 volts then start the engine and watch the volt meter it should go up to around 14volts keep in mind a riding mower battery is only good for a couple years if stores charged during the cold months
Jul 03, 2012 | Garden
My garden tractor is not holding it's battery charge. I replaced the battery, but still doesn't hold a charge after I use it.
If you replaced the battery with a new one and it is not holding a charge, then your charging system is not putting out enough power to run the mower AND recharge the battery. So you need to figure what is wrong in the charging system.
Mar 26, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman riding mower clicking noise - wont start
RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
May 22, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Jumpstart my battery twice, added water, buzzing not starting
THE BATTERY IN THESE ARE A JOKE.. TAKE IT OUT CHARGE IT FULL ! AND BRING IT TO YOUR LOCAL AUTO PARTS STORE TO HAVE IT CHECKED ... VOTE !
May 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding mower having problems starting then runs roughly
I would bet you have a fuel problem. Either the carb is clogged and dirty or needs adjustment. Try opening the screw on the bottom of the carbuerator about a half turn see if that improves it. Also check the air filter and clean it.
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Jun 07, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
887 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
