Question about Toshiba Satellite A100-S8111TD Notebook
Can not switch on even if the battery is ok
I can not switch on my laptop.....i check the bettery nut it's ok!!what i should do??
  • gptak Feb 23, 2009
    when i'm switching on the laptop i can see the blue light that is on.....which mean that the laptop should be on.....but nothing is working!!!! only the small 'air con' is working inside the laptop.
    so you think that it's motherboard?
    thank you for your help
    President:
  • 1,223 Answers
That means no power at all , this is not curable from software this is hardware issue i mean may be Mother board dead or something pls take it to service centre or elaborate ur prob
Posted on Feb 23, 2009
  • Shoaib Rais
    Shoaib Rais Feb 23, 2009
    no if the air ventilation on the back of laptop works and u can hear the fan movement then consider changing RAM see if it helps but if u hear nothing and eveything iss like OFF then there is strong chance of motherboard fault if ur battery is OK, pls lemme know if i can help u more in this
Wronning the system can not Identified the Bettery so I downloaded the upadate of the bois but when I clicked the responding is you don not have a bettery, so what shall I do to install the bois update...
please remove the external power supply and then switch on the laptop;if it starts that means the battery is working
you can check the battery status by clicking on the battery icon
for bios update it is recommended to have battery to be charged more than 90% and to have the external power connected.
do not switch off while performing bios update as a wrong update can damage your system.
hope this helps!
all the best!
Nov 26, 2013 | Dell Studio XPS 1340 PP17S, 1640 PP35L...
I have acer5738, & i purchased 1 year before. in now at that time in my bettery problem is bettery is not charge on bettery sign cross signal. plz help me ,if any solution so plz tell me genius. i m...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Sep 06, 2010 | Acer Aspire Notebook
The phone is not working
first you have try the charge the bettery and then switch on and still problem is same then replace the bettery
Dec 16, 2009 | Sony Ericsson w580i Cellular Phone
Battery will not take a charge, i do have it plug in now,it's showing that it's connected.
you should check ur charger first if it is ok then check ur charing pin inside ur device.check ur bettery also some time betteries have problems.
Dec 04, 2009 | SanDisk Sansa Clip MP3 Player
BETTERY GET DISCHARGED VERY SOON,EVEN IN 14 HOURS?
your phone bettery need a repalcemet with new 1.....purchase new bettery...........
Nov 21, 2009 | Nokia 7210
BETTERY PROBLEM WHEN I USE GPRS ON LAPTOP
yes,as bluetooth drain battery very fast. use cable.
May 23, 2009 | Nokia E63 Cell Phone
Can not swich on even if the battery is ok
Remove both the AC cord and the battery for 1 minute. Then plug in AC only and see if PC will power up. If not, next connect both AC and Battery.
Be sure to press and HOLD power button for >5 seconds when powering a Laptop.
Feb 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
HP LAPTOP WONT STOP HIBERNATING
hi there,
if your laptop is Hibernating it is ok but if it is continuously hibernating then it is unusual.
check the battery pack of the laptop and try to change it.
Feb 15, 2009 | HP Pavilion a620n (PC028A) PC Desktop
D600 bettery charging probleb
my computer can not work and charg battery.
Jan 01, 2009 | Dell Latitude D600 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
