Question about Technics SL-1200MK5 Turntable
Thump or thud coming from speakers when turntable is tapped
Recently I noticed a thump or thud coming from my speakers when the needle is on the record. I have two tables and it happens with both of them. The sound quality is fine and everything else works great. I have tried changing the needles/cartridges, swapped mixers, adjusted the height, checked the grounds and I still have this sound. The best way to recreate it during normal use is by pushing the light down. On the other hand, I can tap my thumb against the shell of the table, anywhere, and still here this sound. I can also hear it from tapping the table on where the equipment sits and also the mixer. The next thing on my list to try was to swap the surge strip. Any ideas?
  • rstorrs1 Feb 24, 2009
    The speakers are about 2 - 3 feet away. They would be behind my back. I can see the noise register on the mixer and notice it less on the headphones. If the volume is down on the amp the noise is still there.
    New Friend:
    Problem Solver:
  • 18 Answers
There is absolutely no comparison between a vintage Thorens and the technics tables other than they play albums. The suspension system on a TD-166 table needs to be finely tuned. It's not like any other system. Would you say a swill Rolex is ok if you thump it and it makes a weird noise? These machines were made by the same people as the rolex mindset. Although it may be normal, I can't say. All I know is I trust no one with my TD124 besides STS Turntables. Contact them at classicthorens.com. Their technician was mentored and trained by original Swiss Thorens engineers and is by far the best with these vintage machines. You can't just haphazardly thigh ten or loosen the suspension springs. There are tolerances that must be maintained for proper performance they were designed for. You have the rolex of turntables, an entry level rolex but a rolex nevertheless.
Posted on Nov 26, 2014
Just wondering how close your speakers are to your tables.Could be the tables pick up the low from the speakers.
Posted on Feb 23, 2009
  • 189 Answers
HI
I have noticed this kind of problem even on my 1970's original Technics SL1200 mk1! It certainly won't help that your speakers are very near your decks - try to get them further away if you can.
I have looked at a Technics SL1200mk2 recently and you could hear the "thump" or "thud" when the deck was tapped.
In my experience this seems to be more of a problem with direct drive turntables (it's do to with the isolation of the platter & arm), though less of a problem on belt drive decks (I own a Thorens TD166mk2) and I can tell the difference.
All I will say is if it is playing the music fine - no need to worry.
Posted on Jul 20, 2009
Toyostove (laser 30). When it starts, why does it make one loud thump/pop like it backfired and then runs fine?
Sounds like the pilot is short causing thump , clean out pilot or get it serviced .
Apr 08, 2016 | Heating & Cooling
Sound system makes a thump thump noise
Your speaker is now blown.. Replace the Speaker and you will get sound back instantly. Happened to my Drivers Speaker last week, replaced the speaker and life is good again.
Mar 01, 2014 | 2010 Kia Soul
Clicking in the engine
here are few components that can cause such problem.Its advisable to click the link below and follow the troubleshooting to correct the problem.
Engine makes noise? http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Chirping sound coming from engine? http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
--------- Vehicle making Clunk Thump Thud noise? http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
Car Engine Overhaul Tips? http://vwrepairhelp.blogspot.com/2011/11/car-engine-overhaul-tips.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Rattle noise from engine? http://whatisbyme.blogspot.in/2012/05/2005-toyota-corolla-rattle-noise-from.html
These will help.
Thanks.
Jul 21, 2012 | 1999 Ford Explorer
My 2006 Infiniti g35x has a thump thump thump sound coming from the front end
A tire can have an internal flaw. Can you figure out which one it is? Maybe mark them and then rotate them to see if the sound moves with the tire...
Aug 16, 2017 | Cars & Trucks
Hi.. I have a bose wave ipod docking system.. the sound is amazing.. or was... until a few weeks back when i noticed that in order to hear my ipod... i had to tweak the ipod a little on the docking...
Are you using a voltage adapter of some kind to convert the ireland standard 220VAC to the USA standard 120VAC that this device uses? Over voltage can deplete an electronics life very quickly.
By the sound of the "thump-thump-thump" noise emitting from the device, you may have a broken ipod dock connector, or a short somewhere in the connector/wiring/device itself, or the ground has failed.
By the description of having to "tweak" your ipod to hear it, it sounds like you've slowly broken the dock connector. Check to see if it moves easily, or if you can hear anything loose.
This is more than likely fixable, but it's probably easier to replace the device than to fix a broken connector.
May 26, 2011 | Bose Battery for SoundDock Portable...
My 2001 saturn is making a thumping noise from the right front tire. It is not the tire. Thump.Thump.Thump, as the cars moves forward. there is no shaking, just thumping.
  1. Inspect your tire. Look for any bubbles or knots on the side of the tire. Look for any damage to the tread. A bubble or knot can mean that you hit a curb, pothole or another object on the road. Bubbles and knots can sometimes be repaired, but more often lead to the need for replacement of the tire.
  2. Think about what you were doing when you first noticed the tire noise. If you just hit a pothole or a curb, chances are you have a bubble on your tire and that it needs to be fixed or replaced. If you had recently spun out of control or had to make a forced turn quickly, you might have an alignment problem and the noise might not be a tire issue at all.
  3. Listen to the noise while you're driving. If it's a repeated thud on regular intervals, you likely have a severe knot problem on your tire. Take the car to a tire repair place as soon as possible. Tire knots may not appear serious at first but can be potentially dangerous.
If you have no others noise especially into turns (it would be a suspension problem, i.e., cv joints) then it is a tire issue.
Oct 26, 2009 | 2001 Saturn SL
I have a Brother ex-660 and it is making a thumping noise, it seems to make the noise every time the needle goes down into the fabric. I noticed the plate under the fabric is chipped (could be from the...
Change the needle and then using the side wheel wind through the stitch process manually. If the needle is still hitting something down under the needle plate, then your timing is out, take it to a mechanic.
Oct 07, 2009 | Brother Sewing Machines
Thump at the time of shutoff
The amplifier in the sub as with any other amplifier has a capacitor in it. Essentially a battery that holds a charge. When you trun things off such as subs or amps with a powerstrip instead of the intended on off button, the power supply has been cut, but the capacitor is still energizing the unit. So it catches the noise in the line.
Mar 07, 2008 | JBL PB10 Subwoofer
Subwoofer "thumping" w. no audio feed
You need to check your ground connection. If there is a bad ground there will be feedback to the amp and it will just sit there and loop back with the Thump, Thump, Thump sound. I had to wire my amp's ground all the way back to the negative battery terminal. It was a pain but I have never had a problem since :)
Feb 12, 2008 | JBL SCS125A System
Technics SL-1200MK5 Turntable Logo
263 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
