Question about Boating
I have a Simrad CP32 mk2 chartplotter ,when VHF radio is switched to channel 10 no communication is possible due to heavy interference. Even a hand held radio independent of all electrical connections has the same problem within 5 meters of the boat. Any suggestions.
I have a Garmin 182C and I get interfernce on VHF channels 21,22 and 83 the moment I turn on the Garmin. I have tried changing radios, antennas, placed separate poer and aground lines and nothing helps. Garmin gives me the run around.
Posted on May 25, 2009
FRS 2Way Radio 14 Channel Conair Expedition MODEL FRS200SLV MANUAL
Here is some information that might help.
Range can vary due to topographical and atmospheric conditions. Voice transmissions on some channels are not permitted by law.
Use in DUPLEX mode, Repeater stations can re-transmit your signal over a wider area giving you extended range depending on the location, height and availability of the local repeater station.
For information on the locations of repeater sites in your area visit the manufactures website or look-up UHF channels and frequencies for your area.
Note: some channels / Frequency's are to be Avoided.
UHF Repeater operation is used when long distance communication is required, unless specifically needed use of the repeater channels is to be avoided. Some channels and emergency channels, some are calling channels for establishing communication and some are customary road vehicle channels.
You will need to look these channels up for your Area.
Other stuff on this subject on safety and safe operation.
Electromagnetic Interference/Compatibility
Nearly every electronic device is susceptible to electromagnetic interference (EMI). To avoid the possibility of electromagnetic interference and/or compatibility conflicts, turn off your radio in any location where posted notices instruct you to do so such as healthcaer facilities.
Feb 06, 2014 | Radio Communications
Simrad Shipmate CP32 Chartplotter won't turn on - any suggestions
bad key pad rick or power on and off switch
Jun 11, 2013 | Boating
Change MMSI number ? simrad rd 68
Hi!
Sorry to be the bearer of bad news, but according to the Owners Manual for this unit:
http://www.busse-yachtshop.de/pdf/simrad-rd68.pdf (Page 6),
to erase a previously entered MMSI, the radio must be sent to a Simrad authorized dealer. I suppose this feature was put into effect to cut down on stolen Simrad products.
Hope this is helpful, sorry I couldn't do more for you.
Jun 19, 2011 | Simrad RD68F VHF Radio Class D DSC by GPS...
How do I change and select channels and frequencies w my motorola axv5100 two-way radio? Can it communicate with a motorola talk about?
This radio comes with programmed channels and tone codes programmed into it. Should it still be stock the the diagram below is what you will use. The tones programed into are there to prevent someone on the same frequency from interfering with your conversation. It's a way of isolating the frequency. These are adjusted by the A,B,C,D You will know what frequency it is by the channel indicated. As for weather or not it will communicate with a Motorola talk about the answer is no. This radio is a VHF frequency and the talk about is MURS.
Regards, Tony
Channel - Pre-Loaded VHF Frequency (MHz) - Code (Hz)
1 151.6250 67.0 2 151.6250 77.0 3 151.6250 88.5 4 151.6250 179.9 5 151.6250 None 6 151.9550 67.0 7 151.9550 82.5 8 151.9550 94.8 9 151.9550 179.9 10 151.9550 None
Apr 17, 2011 | Motorola AXV5100 2-Way Radio
Downlading manual in DANISH or ENGLISH for VHF
Hi!
Here's the link to download the manual for the Simrad RS82:
Unfortunately, there doesn't seem to be a Danish version listed:
http://www.simrad-yachting.com/Products/Professional/Communication-Systems/RS82-dVHF-Radio-System/Downloads/
Hope this helps!
Aug 31, 2010 | Simrad Rs82 Handset Vhf Radio
I cannot get a position on my Simrad CE33 chartplotter/sounder
Ensure that the external position to be OFF, refer to manual below. See interface display in [MENU],7,2
Try resetting the Chart Plotter to factory settings. Use the Delete Memory and Factory Preset options as described in section 9 of the user manual below:
M A N U A L Simrad CP33 Chartplotter
Sep 05, 2009 | Simrad CE44 GPS Receiver
Chartplotter (Garmin 450s) won't talk to VHF DSC radio (Icom IC M
As advised, reset to factory settings. Then re-entered custom settings as required. Seems OK now. Many thanks.
David Godfrey
Jun 16, 2009 | Garmin GPS
2-way radios
The Bellsouth 2231 is a FRS VHF I couldnĀ“t find if thi Bell south 1007 is FRS in UHF or VHF if you have this informtion compair them if both are in the same band VHF or UHF both radios can communicate to each other
Mar 02, 2007 | BellSouth 1061 (14 Channels) 2-Way Radio
Boating Logo
394 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
