Question about HP Compaq d530 PC Desktop
Battary problem bios battery.the computer guıde.
  • HP Master
  • 2,404 Answers
The type of battery you need to replace it with is a CR2032. It can be found in any department store like a wal-mart or best buy. Its silve and the size of a nickel.
Posted on Feb 23, 2009
Hello: I have 2 errors message when I press on F1 during the startup to enter the BIOS. Error 0271 - check date and time setting Error 0176 - System sercurity. The system has been tempered with. and i...
Try to put out the cmos battery for 5 mins or longer, then press the power button (with unplug power cord). Put back the cmos battery then try again.
Dec 10, 2017 | IBM ThinkPad R40 2722 Notebook
Como hago que funciones el asistente y el scaner de la impresora lexmark x2250
La guía para el X2250 de Lexmark usuario de la impresora le puede dar instrucciones más detalladas sobre cómo utilizar las características de la impresora y funciones.Puede descargar la guía del usuario del sitio web de Lexmark en http://bit.ly/mEpFyZ.
Nota: Esto se traduce con translate.google.com.
May 10, 2011 | Lexmark X2250 All-In-One InkJet Printer
Put two new batteries no image thers a thırd knob that has nothıng ınsıde ı wonder if you put av battery or somethıng ın...
Hello, I fell the same way buddy. Sorry to here about your Night Vision monocular? But Tasco NV monocular is manufactured in Russia. It seem you got a few year out of your NV devise...7 years is very good. The biggest thing that goods bay is the Russian manufactured image intensifier tube. There are cheap. This is about 85% of the monocular problem and 90% of the cost. Two items that viewed as important with NV devises. The case, and the image intensifier tube. Now, if you have Russian optics above 50mm for the front lens then on could consider that the optics are another cost. Auction it off on eBay as "doesn't work, parts only" Sorry, and I wish you luck...GB...stewbison
Nov 28, 2010 | Optics
Mi xsp m1330 tiene password en el bios y no me obedece para iniciar
Hi, usted puede intentar quitar la batería del Cmos del panel inferior. Usted puede ser que necesite desatornillar el panel inferior primero para revelar la batería del Cmos.
Espere que esto ayude, gracias por usar Fixya, su recomendación se aprecia altamente para la ayuda libre.
Sep 29, 2010 | Dell XPS M1330 Notebook
Hp dv2000 bios
Hello. The only way to get rid of the bios password is to remove the mainboard memory.For desktops this is very simple, however for laptops you first have to remove the case of your laptop, find the battery placed on the mainboard, wait for 5 min. then assemble it and bios is restarted.
Mar 16, 2009 | HP Pavilion dv2000t Notebook
I need to flush my bios.forgot password. Sony vaio pcg-7g1m
Try This:
Reseat the CMOS battary:
How to Change/Reset a BIOS password Posted on 30 December 2008
Tags: Tech News, Tutorials If you are a normal computer user who has forgot his BIOS password and you are unable to access to your BIOS, then you need a simple way to change your BIOS. Its not that hard because you just need a simple trick to reset your BIOS password.
Open your CPU cabinet after switching OFF the power and then try to locate the CPU battery which can be found very easily. Once you locate your battery you need to remove it once and restart your PC without the battery.
cmos-battery-check.png Note : Once you remove your battery from the mother board, you will find that all your time settings in your computer would be lost, and some softwares may stop working which are based on your computer time.
You need to shut down your PC again and now add back the battery which will enable you the time saving feature and also reset your BIOS password.
Feb 22, 2009 | Sony VAIO VGN-AR230G Notebook
Bios setup error
check your c-mose battery when power cable is unplugged the battery remove and after few seconds battery fix them and connect power cable then on the computer
Oct 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Disque cod?
To have answers in these types of groups it is best to translate in to English.
The question in English:
Hello, I have a problem with a laptop which called for a password bios. Well, I removed the battery for a moment and that is installed. I launched the boot on the disc cd then it did the restart, it asks me a password hard disk. I then passes through several means even SKY_FOX I tried but nothing.C 'is a brand Fujitsu Siemens Lifebook and I do even more started on the system' exploitation. I really need help, if you could do something without needing expensive experts. Thank you. __ Have you contacted the former owner to get the password? If the hard disk is pass-word protected and you do not have the password, the fix would be to un-install the partition, and re-make it. Then do the full re-installation of the operating system, and the re-registration for ownership. In some cases where the hard disk is password locked, there may be no possible way to be allowed to undo and re-make the partition to do a full re-install. If this is the case, changing the hard disk will fix it. The old hard disk would be scrapped unless you can have its password. BIOS Level Password Procedure: With some models of computers, you can remove the BIOS battery and wait until the BIOS setup is depleted. Then you should then be able to have access to re-set up the BIOS. You will have the choice to put in a new password or simply not to. If the computer hardware is pass-worded at the BIOS level and it does not deplete with the battery removal, you will have to send the computer back to the manufacture to have the computer un-locked. You will have to pay the shipping and the service fee. When sending the computer back to the manufacture for the unlock, you will be asked for proof of ownership of the computer with proof of identification. With most computer companies, a copy of the purchase invoice, and a copy of your driver's permit or citizenship card should be acceptable. ________________________________
Google Translated, Answer in French: Avez-vous contacté l'ancien propriétaire pour obtenir le mot de passe?
Si le disque dur est mot de passe protégé et vous n'avez pas le mot de passe, le correctif serait d'installer un-la partition, et re-faire. Ensuite, faites le plein de nouveau l'installation du système d'exploitation, et le ré-enregistrement de la propriété.
Dans certains cas où le disque dur mot de passe est verrouillé, mai il ne peut être moyen d'être autorisé à annuler et re-faites une partition de faire une re-installer. Si tel est le cas, changer le disque dur fixe. L'ancien disque dur serait supprimé à moins que vous ne peut avoir son mot de passe.
Mot de passe BIOS niveau procédure:
Avec certains modèles d'ordinateurs, vous pouvez supprimer le BIOS batterie et attendez jusqu'à ce que le BIOS est épuisé. Ensuite, vous devez alors être en mesure d'avoir accès à re-configurer le BIOS. Vous aurez le choix de mettre en un nouveau mot de passe ou tout simplement ne pas le faire.
Si le matériel est libellée au passage à niveau le BIOS et ne pas épuiser la batterie avec le déménagement, vous aurez à envoyer l'ordinateur à la fabrication d'avoir un ordinateur sans littoral. Vous devrez payer les frais de livraison et les frais de service. Lors de l'envoi de l'ordinateur à la fabrication pour la déverrouiller, il vous sera demandé une preuve de propriété de l'ordinateur avec la preuve d'identification. Avec la plupart des sociétés informatiques, une copie de la facture d'achat, et une copie de votre permis de conduire ou carte de citoyenneté devrait être acceptable.
Jerry G.
Sep 03, 2008 | Intel Motherboard
Starting UPS
hi, guies
                 First all of  look in battary condition of ups, and that
battary sencing voltage circuit
 In your second case, please replace lithium cell with same and reconfigure the bios setup
Oct 22, 2007 | Computers & Internet
HP Compaq d530 PC Desktop Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
