Question about Nintendo DS Console
MY DS WONT CHARGE
Every time I put it in the charger and leave it there for hours or even a day I will turn it on and I will see the flashing red light and then it would turn it's self off.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
You need a new battery. After you a certain amount of charges, the battery's charge capacity is decreased. A new battery is all you need.
Posted on Feb 23, 2009
My JBl Synchros E50BT Bluetooth headphones wont charge or turn on.
sadly the battery has possibly died and will never charge .
Oct 19, 2016 | Cell Phones
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
When I plug in the adapter to the charge the consol the orange light lit. The light does not turn off even after 13 hours of charge. After 13 hours when I want to use it, the red light comes on not the...
Hello there. You may need to replace your battery pack, as leaving it charged for over 4 hours can lead to "overcharging" a condition which can dramatically shorten your battery packs lifespan and charge retention.
Also, be sure to charge your console while the device is turned off. Although you may charge it while it is powered on, it will take longer.
As stated, be sure not to leave the system on charge for more than 5-6 hours, as this can damage the battery and is liable to cause battery leakage, burning, or overheating.
Battery life is largely dependent on the game being played - some games can give you up to 10 hours of battery life, though the real-world estimate is really more like 5-7 hours of constant use before you'll need to recharge.
I hope this helps you. -
Frankie.
May 11, 2011 | Nintendo DS Lite Console
What is the proper way to charge the Pronto M51
Eduardo After using your chair and the battery level lights are down with yellow or red lights showing just plug the chair into the wall socket and let er rip. Now really after using your chair during the day and you are ready for bed just plug in the charger and let it charge over night. In the morning unplug the charger and you should be set for the day. If you don't use the chair everyday always put it up with a full charge and about once a week plug it in and let it charge overnight. Never leave the chair plugged in all the time and never leave it for more that 24 hours. The charger has two lights on it one red and one yellow or green that are hard to see because they are under the rear cover. When the chair is fully charged the yellow light turns green and you can unplug the charger and you should have a full charge. Hope this helps you
Sep 08, 2010 | Invacare Pronto M51 Power Wheelchair
My ds lite wont turn on but it charges fine
if your ds is about 2 years old, it's probably time to change the battery. even though the battery is rechargeable, it wont hold a charge as it gets older. no matter how long you keep it on the charger, the battery is truly dead and it wont turn on. if anything, replace the battery. if your ds is brand spanking new, then you probably didn't leave it on the charger long enough to begin with.
hope this helped
Jul 23, 2009 | Nintendo Video Game Consoles & Games
Battery Dont Charge
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
Dec 26, 2008 | Casio Exilim EX-Z77 Digital Camera
My ds lite wont turn on or charge
Charge:Plug In Charger and put in ds.wait 3-5 hours.
Turn On:Move Power Button to right.
Dec 23, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Power problems with DS Lite
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
Mar 29, 2008 | Nintendo DS Console
Ds nintendo will not charge light flashing and think it is the connection on the ds as i have tried other chargers in it
um.... im jut asking dose it flash green, orange or red? if it flashes green it is fine if it flashes orange its giving you a warning then if it flashes red that is when you charge it oui? but if it flashes red and you still cant charge it well i ont know what to tell you? oui, no, maybe? wll if i didn help sorry but i tried. sorry or your welcome which ever best fis your dicription. †
Dec 01, 2007 | Nintendo DS Console
Nintendo DS Console Logo
44 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
