Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washing Machine The washing Machine kwwps running the water out of the discharge hose, and will not fill up.
  • 5,911 Answers
Do you have the hose inserted too far down in the drain standpipe? If so, you may have created a situation called "siphoning". You need to have an air gap so the hose will drain properly, and doesn't drain when you don't need it to. If the hose is resting in the trap area of the drain, it stays submerged in water and will siphon the water from the washer as it fills. Another situation that occurs is when consumers try to seal the top of the standpipe to keep odors from coming back up through the drain and/or to prevent overflows. This can also cause siphoning. Just some things to consider. Double check your drain hose and let me know if this helps you.
Posted on Aug 02, 2007
My hoover 500mb 5.0kg washing machine fills up fine at start of cycle then just washes for a bit then just stats to fill up and wont stop till I stop it
I had a similar problem and not sure whether my solution would help you.It was to do with the position of the waste pipe.It should raised about 2ft. ,looped before discharged into the washing machine tee.when the discharge hose is lying on the floor there's a possibility that the water is filling up and going straight out.By raising it you are letting it fill up and presumably triggering the water level sensor.Hope this helps.
May 29, 2017 | Hoover Washing Machines
How do I stop my frigadar top load washing machine it leaks and won't stop filling up
Make sure your discharge hose is higher than the water level. Some washing machines won't fill up if it's not.
Oct 09, 2016 | Frigidaire Washing Machines
Have a maytag neptune washer is taking in water but throwing the water back out the hose and not washing it just started today before it would not spin but washed and clothes would come out very very
Too may things could be wrong with it, with out actually seeing it , it would be hard to diagnose this problem..
I believe those are computer controlled.
so it could be a computer problem.
make sure discharge hose is above level of machine, meaning if your hose needs to be vertical to the machine or the water will flow right out. The pump should not be running while the machine is filling. If it is, then that would also indicate a computer problem.
Nov 26, 2014 | Maytag Washing Machines
Water is coming in through the entry hose and running straight out the drain hose. No agitate, no spin, just constant water. Happened after I tried to wash three towels & got an imbalance alarm. R
Is the discharge hose higher than the machine? If it is Lower it will never fill. Don't think there is a shut off in the hose to stop the water discharge.
Nov 08, 2013 | Haier HLP21E Top Load Washer
Washing machine stops in the middle of washing and then restarts. Machine fills and washes at the same time.
Could be that your discharge hose is causing the machine to syphon off water because there is no Air Break in the system
Test is to hook the hose into a basin and see if it does a full normal wash
Also could be problem with the pressure switch falsing due to a soap build up in the Air Bell on the side of the drum
Jul 08, 2009 | Kenmore Washing Machines
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine never fills in rinse cycle. water runs out through discharge hose.
pull drain hose out of drain reinstall 6-8 inches in drain or if drain hose fits snug in stand pipe try creating air gap between pipes sounds like water is being siphoned out..once water flow is established in first pump out it will continue to run out with no pump action if end of drain hose is lower than water level in tub or it can't catch air to brake siphon
Jun 06, 2008 | Frigidaire Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
