Question about Sony Playstation 3 (PS3) Console
My ps3 is turning on but my tv says no signal on AV1,2,and 3.
I had a hdmi cable hooked up yesterday but not today
    President:
  • 2,653 Answers
You should start with a manual video reset.
While th PS3 is off, hold down the front power button until you hear two beeps, then quickly release. This will reset your video back to default.
If you have more problems you can check out my common PS3 problem and repair guide here:
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and don't forget to rate!
Thanks!
RescueTechLA
Posted on Feb 23, 2009
Ps3 turns on but no signal on tv
Hi There,
Is the TV set for the correct input?
I assume you are using HDMI?
If all settings and input selections are correct then I will have to say that either the HDMI cable is faulty, or the HDMI port on either the TV or PS3 could be faulty.
Check if PS3 can work on another TV with the HDMI cable.
Check if another Device can work on that TV with the HDMI cable.
Try another HDMI cable.
From this, you should be able to determine where the issue is sitting.
Hope this helps!
Jan 13, 2016 | Sony Playstation 3 (PS3) Console
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
My PS3 worked fine for 2 months, then just like that I get "no signal" on the tv screen. Nothing has been changed (cable or tv). I've tried holding the on/off button down till the unit turns back off, but...
Your A/V cables might not work anymore. Do you have any spare A/V cables....like from a ps2? Try the cable on your ps3 to see if you can get a signal then. If you don't get a signal it is a problem either with your ps3 or the TV. Try using a different TV, if it continues to happen than it's your ps3. I highly doubt it's your ps3 and doubt you will get to this step, but if you do what you need to do next is buy an HDMI cable and hook it to your ps3 and tv. If your tv doesnt accept HDMI than i dont know what to tell you. If you do this step and it still doesnt work than sorry it didnt work. Hope this helps, good luck.
Jul 25, 2010 | Sony Playstation 3 (PS3) Console
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is hooked up to my tv via HDMI cord. The
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Then after that change the output setting to HDMI on your PS3 and see if it works after that, if not, try the system on another TV to make sure its not a problem with your tv.
If it still doesn't work try another cable and then after that it could be a problem with the main board inside of the ps3.
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 HDMI cable no signal to tv
by new 1ns i had the same problem i bought new 1ns it worked just fine
Aug 22, 2009 | Sony Playstation 3 (PS3) Console
Cascading white craziness
First thing you should try is using the regular old AV cables. That way we know if it's an hdmi problem or a video problem with the PS3. Hook them up, do the manual video reset ( hold down the power button until you hear a second beep, quickly release) and then post back here with the results.
May 11, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
HDMI for PS3 Doesnt work
do you get picture on tube tv if so hook up to tube tv go to settings and set for hdmi then turn off and take to hd tv hook up with hdmi cable and should work you need to set hdmi in settings as it will be set for s-video at 480p I do believe
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
216 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
