The key board either does not work, give letters you do not type and usually 2 at a time, or when trying to search inserts random characters automatically
SOURCE: my acer lap top key board is doesn't work
Try to turn off the acer laptop, remove the cables and battery . Press & Hold the power button. Then replug cables and battery. Turn on pc and if symptopm persist, consult acer tech support at 1-800-816-2237
SOURCE: hp netbook 110-97TU 1: Text box
having this issue may cause by hardware problem or key board malfunction, if the computer is still under warranty call your manufacturer and have it replaced.
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
