Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Backup and restore center will not display
When i go to backup and restore just the frame appears but nothing else
  • Microsoft Master
  • 2,386 Answers
Check the resotre date and press resotre button. you must have a resotre point before restoration.
Posted on Feb 23, 2009
Reset a Inspiron 15
Backup important files and data
  1. Click Start, and then click Control Panel.
  2. In the Control Panel window, click System and Maintenance, and then click Back Up and Restore Center.
  3. Under Back up files or your entire computer, click Back up files.If the User Account Control window appears, and you are prompted for an administrator password or a confirmation, type your password, or click Continue.
  4. On the Where do you want to save your backup? page, choose the location in which to save the backup. To do this, click either On a hard disk, CD, or DVD or On a network, and then specify the location. If you select a hard disk, be sure to save the backup to an external drive such as a USB key or USB hard drive.
  5. Click Next.
  6. On the Which file types do you want to backup? page, click to select the check boxes next to the types of files that you want to back up, and then click Next.
  7. On the How often do you want to create a backup? page, leave the defaults as they are and click Save settings and start backup, to back up the files to the specified location. Backup will save the files in the background and may take several minutes to complete. If you specified a removable drive, Backup may prompt you to enter an additional blank disc if more than one is necessary to hold all your files. Be sure to label your discs thoroughly (such as "My Files Disc 1" etc.) so you can quickly restore them later.
    Once the Backup Complete message appears, you are ready to proceed with the next step.
Remove non-essential peripherals
Except for the monitor, keyboard, and mouse, remove all external peripherals including:
An external peripheral is a device that connects to a port on the front, side or back of the computer, like a printer or memory key.
  • Scanner
  • Printer
  • Modem or Network cables
  • Personal Digital Assistant (PDA)
  • USB flash drive or other external Hard Drive
  • Any other external devices (e.g., USB-attached devices)
  • Remove the computer from the docking station, if you are using one.
Restore the computer's software to original condition.
  1. Turn on the computer.
  2. As the computer starts, press < F8 > on the keyboard until the Advanced Boot Options menu appears on the screen. You must press before the Windows logo appears on the screen. If you press after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
  3. Press the < Down Arrow > on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press < Enter >.
  4. Specify the language settings that you want, and then click Next.
  5. Log in as a user who has administrative credentials, and then click OK.
  6. Click Dell Factory Image Restore.
  7. In the Dell Factory Image Restore window, click Next.
  8. Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
  9. Click Next. The computer is restored to the default factory configuration.
  10. When the restore operation is completed, click Finish to restart the computer. The software is now installed as it was when the computer was first received.
Restore your personal files and data from backups
  2. In the Control Panel window, click System and Maintenance, and then click Back Up and Restore Center .
  3. Under Restore files or your entire computer, click Advanced Restore.
  4. On the What do you want to restore? page, click Files from a backup made on a different computer and click Next.
  5. Locate the backup you created earlier by browsing to it now. If you saved the backup to CD(s) or DVD, insert that disc now. Once the backup is located and selected, click Next.
  6. On the Select the files and folders to restore page, click Restore everything in this backup then click Next. Backup will restore the files to your computer. If you are restoring from a removable drive and used more than one blank disc, Backup will prompt you to enter the next disc in the set as necessary. Depending on the number of files and their sizes, this process may take several minutes.
Aug 23, 2015 | Computers & Internet
Factory reset
Do not rename the backup folder created by Samsung Recovery Solution or change the directory structure in the backup. If the name or structure has changed SRS will not see your recovery point when you attempt to perform a restore.
This restores the PC to the condition it was in when the Complete Backup was made. If a Complete Backup was never made, this can still be used to restore the PC to its initial status. (Out of the Box condition)
Warning: A Complete restore erases all current files, settings, programs and other data and replaces them with the files, settings, programs and other data contained in the Complete Backup. In other words, it restores your computer to the way it was when you made the Complete Backup. Also, note that any programs installed after the Complete Backup will still need to be reinstalled.
Important:
  • If you have data that you need to save, create a Data Backup before performing a Complete Restore. With Data Backup you can save your files to an external device and then use Data Restore to load those files back onto the PC.
  • If the computer powers on, but Windows does not load, press the F4 Key at the Samsung logo when you first power on the computer; and then go to step 2.
  • If the Samsung Recovery partition has been removed from your PC, your notebook will need to be sent to the service center for reimaging.
To perform a Complete Restore, follow these steps:
  1. Open Samsung Recovery Solution 5.
  1. Once Samsung Recovery Solution 5 loads, click Restore. The Restore dialog appears.
  2. Click Complete Restore. The Restore > Complete Restore dialog appears.
  1. On the Restore > Complete Restore dialog, there is list of backups created using Complete Backup and the expected time needed to perform a restore with each backup. If no backups have been created then the Computer Initial Status backup is the only item listed. Click the backup you would like to use for this restore, and then click Next.
  2. Important: Make sure you have power connected to the PC. If power is lost during a restore, you need to start the process again from the beginning.
  1. Samsung Recovery Solution 5 prompts you to restart the computer to continue. Click OK to restart the computer.
  2. Warning: If you have data on drive C that you do not want to lose, stop now and perform a Data Backup.
  1. The computer restarts and Samsung Recovery Solution 5 prompts you to click Yes to Delete all data on drive C. Click yes to proceed.
  2. A progress bar appears showing the current transfer speed, the amount of data copied, elapsed time and estimated total time to completion.
  3. After the Complete Restore is complete, Samsung Recovery Solution 5 prompts you to restart your computer. Click OK to restart.
  4. After you restart your computer, the restore process is complete.
  5. Note: You will need to perform an additional restart for Windows to apply its changes.
Nov 22, 2013 | Samsung R519-53S Notebook
Samsung recovery solution 5
Step 1:
Step 2:
Once Samsung Recovery Solution 5 loads, click Restore.This display is observed.
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Mar 18, 2013 | Samsung Cell Phones
How to reset laptop
Knowledge Base
Restoring Your Computer´s Software to the Factory Settings for Windows Vista
Table of Contents:
  1. Backup important files & data.
  2. Remove non-essential peripherals.
  3. Restore the computer's software to original condition.
  4. Restore your personal files and data from backups.
  5. Download and install driver updates
This article provides information on restoring your computer´s software to the factory settings.
Dell has designed two new backup and restore programs.
Dell Inspiron, Studio, and XPS computers use DataSafe Local Backup 2.0 as the PC Restore/Factory Image Restore option as of April 22, 2009.
Dell OptiPlex, Latitude, Vostro, and Precision computers use Dell Backup and Recovery Manager as the PC Restore/Factory Image Restore option as of May 26, 2009.
  5. Click Next.
    For additional resources to help resolve issues not covered under Dell's limited hardware warranty, refer to Dell Knowledge Base article, Search for Additional Solutions .
Back to Top
  • Scanner
  • Printer
Back to Top
Back to Top
Back to Top
Once your operating system has been restored, visit the Dell Support website to download and install the latest drivers and firmware for your computer.
Sep 30, 2012 | Dell Latitude D420
EMachine EL1850-01e
It looks like you'll have to either return it or perform a default factory recovery. These instructions are from their site but proceed knowing that this will erase any data that is stored on the primary partition (meaning if you have anything on it, it's gone...). Esentially it resets it to a point as if you just picked it up in the store (which you did.. :( )
How can I restore my computer with the backup discs I created?
With user created backups you are able to restore your computer to the factory default settings. If backup discs were created instead of factory restore discs, these can be used instead and will restore the system to a user backup point.
    If you have a recovery disk:
    1. Ensure that the computer is completely shutdown, then turn on the computer.
    2. When the eMachines splash screen appears, tap the Alt and F10 keys simultaneously. A screen stating "Starting eMachines eRecovery" should appear.
    3. From the recovery options, choose Restore system from CD/DVD.
    4. Insert either the first Recovery or Backup disc that you created.
    5. From the on-screen options, choose a backup.
    6. Click OK and the installation will begin.
    7. Change the disc as necessary when prompted.
      If you do not have a recovery disk:
    8. Restart the computer.
    9. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
    10. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
    11. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Dec 13, 2011 | E-Machines eMachines Desktop PC
I WOULD LIKE TO RESTORE TO FACTORY SETTINGS TY
You will loose all data you have put on the computer. When you turn it on right at the beginning there is a black screen and there are a few f key options.
They will flash up with the option when you turned it on, before windows kicks in. Take a look at the user manual to find out for sure.
Press the correct f key before windows starts up, then go through the menus in setup (it will look all crappy and dos like) and find restore factory settings (or something like that) and click yes.
It's a great feature, and will completely kill any virus or **** problems you have had and couldn't get rid of.
Hope this helps. I would appreciate your feed back as I do this for fun not pay.
Oct 01, 2011 | Acer Aspire One PC Notebook
I Forgot My Iphine Personal Passwordd, How do I Unlock It?
We usually forgot iPhone encrypted backup password, I did for my iPhone 4. I used application "iPhone Backup Password Unlocker" via http://goo.gl/lNtZb It helped me recover forgotten backup password quickly with pro techinques!
Dec 24, 2010 | Apple iPhone 3G
This is a Compaq Presario CQ62. It is 3 months old. The orange Compaq screen pops up but then the computer shuts down after just a few seconds. Have tried it unplugged, plugged in with and without the...
Simple test to determine if it's a hardware or software problem : try to boot in the BIOS. If you can't then it's hardware you should just return it, it's still in the warranty. If you can then Windows is totally corrupted so just reinstall it.
Dec 19, 2010 | Compaq Computers & Internet
Want directions on how to backup to western digial external hard drive. We use microsoft vista and we have a 500gb external drive.
This may vary, depending on the software you use, but if it's Vista backup and restore, follow the steps below:
  1. Open Backup and Restore Center by clicking the 'Start' button, clicking 'Control Panel', clicking 'System and Maintenance', and then clicking 'Backup and Restore Center'.
  2. Click 'Back up files', and then follow the steps in the wizard (during this process, you will be given an option to select the destination for your backup - Browse for the WD drive in my computer and select it). You will also be given the option to select which files you would like to backup - You can either select everything or you can select specific folders (an option for browsing will be available), you may want backed up. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Hope this helps.
Jan 23, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
I HAVE UPGRADED MY PC WITH A 32 BIT WINDOWS 7 DISC DO I NEED TO MAKE A 3 DISC WINDOWS BACK UP AGAIN AS I DID WITH VISTA. IT HAS LET ME MAKE A SYSTEM RECOVERY DISC BUT THIS WAS ONLY A SMALL PROGRAMME FOR...
Yes it is. But it used together with the Windows 7 Backup and Restore Center (Control Panel - Backup and Restore). If you set up the backup setting in this option, make a backup, and create a restore disk you will be able to restore your system in the event of a problem. Please note that it will restore the system as it was on the day you made the backup.
Nov 11, 2009 | Microsoft Windows XP Home Edition
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
