Question about Sony VAIO FR130 Notebook
ITS TOO HOT
THE WHOLE LAPTOP GETS ABNORMAL HOT
  • 87 Answers
Your fan is either clogged or not working at all. Try spraying canned air into the exhaust port to clean it. If that doesn't help then replace the fan.
Posted on Feb 23, 2009
Front wheel hub gets hot atfter driving 20 miles
Hubs will be temperate depending on braking. If there is a failure with a wheel bearing or a brake shoe you will experience grinding noises, which is friction and will cause things to get abnormally hot.
Apr 13, 2014 | 1995 Nissan Pickup
My bottom of laptop gets hotter
This seems to happen to all laptops (including mine which is nice and toasty below). There are a few things you can do to make it cooler (or less hot).
Shoot over to i.e. Futureshop, Walmart, Best Buy, anywhere really that carry's computer equipment. You can purchase a pad with fans or a riser that sits below your laptop to cool things down a bit. Also you can as a cheaper alternative, put something to raise/prop your laptop up (i.e. a thin like book). This will help air circulate through and cool down your laptop.
However, if your laptop is abnormally hot, I'd suggest checking your Heatsink. On laptops espically, dust can build up inside the components and thus you'll need to clean off the heatsink.
If your running Mac, luck is not on your side and this is something you'll have to take in to get looked at..
Hope this helps brtandan :)
Nov 03, 2010 | Computers & Internet
Vacuum getting hot in filter area
That's not abnormal, unless it's getting very hot. Have you changed the filter recently? If the filter is blocked it will get hotter than normal. the filter should be changed every 4 to six weeks of normal usage.
Apr 06, 2010 | Euro-Pro Shark Professional Upright Vacuum...
Sony vaio system becomes hot and shutdowns
More than likely the fan above the processor is not working. Or the vents are clogged on the computer case due to dust/dirt. Ventilation.Check the fans.
Nov 22, 2009 | Sony VAIO VGN-CR510E/L Laptop
Gto trimmer keeps geting hot when i use it
It's not abnormal for a trimmer to get hot while being used. If it's getting VERY hot it may be time to get a new one. Most important is to make sure you oil the blades every so often (a lite oil, like sewing machine oil is my recommendation. Oiling the blades will reduce the heat generated and provide a longer life to the trimmer.
Sep 29, 2009 | Kitchen Appliances - Others
I have hcl laptop.i bought it 18month back.it has1.5gb of ram.80gb of hd.two week back blue tooth of my laptop has stopped working .when i use to start the b.tooth it displayes the massage that b tooth has...
I assume you have Windows XP as your OS.Take back up of all your important data and get the windows restored to an earlier date(just click start, the Run then paste there %SYSTEMROOT%\System32\restore\rstrui.exe
and click OK.). If it does not help you proceed for a fresh windows installation
Dec 18, 2008 | Computers & Internet
Touch pad is on fire!
same laptop but intel core 2 duo, and I got the same problem , my touch pad is very hot sometime and I have the cooling fan underneath the laptop it's help! and after that like couple weeks later my laptop was death it wasn't boot the vista. it shown the options like 1. fix the ..... 2. start normally.
when I choose No.1, the screen turn BLANK all day and nothing changed and I power shut down and choose No.2, then it boot!! But the programs were not boot well and stuck like not completed. SO what's wrong with it???
Aug 04, 2008 | Toshiba Satellite A135-S2386 Notebook
Eror code on sharp copier AR-M276
UNRELATED PROBLEMS.
H4 = MAIN HEATER LAMP ABNORMAL LOW TEMP. THE FINAL UNIT BEFORE PAPER EXITS. HAS TO BE HOT. LAMP OR THERMO-FUSE? CHECK CONTINUITY LAMP WIRE IN THROUGH WHOLE PATH TO OTHER LAMP WIRE OUT.
E1-15 = IMC board Page Memory error/SRAM
error. MEMORY FULL? Mfr. says "Print Buffer Page Memory or Work SRAM abnormality"
SORRY NO MORE.
Jun 24, 2008 | Office Equipment & Supplies
Toshiba e-studio error code
It is abnormal temperature in the fuser*, thermistor error.
Maybe replacing fuser would help. But better contact service person.
*fuser, the part of a laser printer that melts the toner onto the medium. It consists of a hot roller and a back-up roller.
Feb 13, 2008 | Office Equipment & Supplies
Sony VAIO FR130 Notebook Logo
56 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
