Question about Xante CL30 HSE Laser Printer
My printer prints some lines and do not print others. what is the reason?
JOU MASEKAFFER
Posted on Mar 22, 2009
Tip
Horizontal Lines on your print out paper
Possible Cause:
Air in the print head: This is the most common cause of printing problems. When changing the cartridges, or for other reasons, air bubbles can enter the print head. This prevents the necessary pressure build up (through heating or vibration) as a result, no ink is sprayed onto the paper and you can see white lines. This effect is also called banding.
Solution:
To improve your print, most printers feature a print head cleaning cycle. Ink is flushed through the print head to re-establish the ink flow. It may be that you have to carry out this procedure several times to achieve the desired result.
Possible Cause:
Blocked nozzles: If the printer is not used for a long period, particles can build up and block the print head.
Solution:
To remove this blockage, run the cleaning cycle. If you cannot achieve a satisfactory result, use a nozzle cleaning fluid.
Possible Cause:
Defective print head: Print heads are exposed to high stress. The temperature variation in thermal print heads can vary by 100`s of degrees centigrade up to 10000 Hertz (10.000 times per second). Therefore print heads have a certain amount of wear and tear. Depending on the manufacturer and price, print heads have a limited life. Epson uses Piezo print heads, which guarantee a long life. However if they do become defective, compared to other printers, the repair can be costly.
Solution:
With printers that feature integrated print heads that are separate from the ink tank (that is for example, Epson and most Canon machines) all that remains is to change the print head. With HP Lexmark and Dell the print head is part of the cartridge, and is automatically replaced each time you replace the cartridge.
on Aug 29, 2010 | Office Equipment & Supplies
Having a problem with printed pages that are printing lines of random letters within the document. Parts of the document appear fine, random lines are printed as crazy groups of letters. For example: ...
Hey,
First its not the issue of the printer nor the printer driver
Let me know which internet browser you are using if its Internet Explorer try using Google Chrome and reply back....
Oct 03, 2013 | Office Equipment & Supplies
Is it possible to view prints sent to a Intermec PM4i printer? Reason is we are testing label printing to a label printer in the UK and would like to see what is being printed on line perhaps via a web...
Hi Karen - with Label Printing Software such as LabelView Pro and others from Teklynx and Bartender you can have multiple software licences that can be linked remotely if your printers are network ready. Using advanced rather than basic software you will have full control of exactly what is being printed/not only having it viewable. I hope this helps
Oct 20, 2011 | Intermec EasyCoder PM4i Printer
For some reason my cp2025 printer will occasionally print horizontal lines about an imaging drum revolution space between them, and runs down the page. The lines are about a 1/2 inch wide. Sometimes it...
There is no imaging drum in this printer there is only a transfer belt. It is the green film that is visible when you open the door. This sounds like there could be a problem with the dc controller take the printer to a local asp.
Al
Aug 25, 2010 | HP Laserjet Cp2025n Printer
HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Nov 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Extra Line when printing from a dos-based program
your printer paper size shorter than your PC dos-program print size setting, example: if use a letter size paper to print a A4 size file which should occur two paper go out..
so you need check your PC print setting or take a presetting paper size, make a size match between PC program and paper in printer .
hope you fix it, please take a rating let me know how much helped you thanks!
May 21, 2009 | Dell 5100cn Laser Printer
ON SOME LINES OF PRINT, THE ENTIRE LETTER DOES NOT PRINT
Do a printer utility deep cleaning and possibly be prepared to replace the cartridges
Nov 23, 2008 | HP Photosmart 8450 InkJet Printer
Hp photosmart 7960
For Photosmart 7960...
Hit MENU
Select "TOOLS" by hitting OK
Select "Clean Cartridges" by hitting OK
Carefully review printed output for white lines on printed areas
If white lines appear:
Select "SECOND level cleaning" by hitting OK
Select "THIRD level cleaning" by hitting OK.
Jan 17, 2008 | HP PhotoSmart 7960 InkJet Printer
Xante CL30 HSE Laser Printer Logo
828 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
