Question about Creative Labs ZEN Vision:M Digital Media Player
Creative zen Vision M : Firmware problem ! I've already read all posts, specially "amoop's post" : in fact I've tried everything but i've a problem ,when I run the zen vision m firmware upgrader it is written that my player is not connected, altough I can see on the screen of the player "Docked" and on my computer the player is recognized... What can I do to upgrade my player (I must reload firmware and now I can't upgrade it because the program (theupgradr says that my player is not connected) !!!
  • 5 more comments
  • SPIRITp Feb 23, 2009
    Model No DVP-HDOOO3
    it is a crative zen vision M 30GB ; the usb is correct ; everything is OK expect that i can't reload the firmware : i can see the player in "my computer" but when i click on the upgrader it is written the player is not connected... i've tried on another conputer it's the same, i have a computer with XP...
    What's and where i can find device manager,
    I've opened device manager followed your instructions and it does not work.
    can i have other solutions ????!
    I've Already get the recovery tool , on the same page, the red box : and it works at the beginning : m player is recognized then i click on next ... it's downloading until 1,023/ 15,2 mb and then it's stopped and it's said that that there is a problem the program is shut down and I've tried maybe 20 times it 's stopped at 1,023/15,2 mb...
    Besides i'm french and i don't understand device ... in french my computer is poste de travail ; then "device" is at what line in your menu ?
    Thanks
    In my device manager, i can see portable devices... and creative vision M inside... when i click on the right button it says that the peripheral device works well (there is any "?" in a yellow circle). On my computer I've found back the icon of the creative zen vision... what must i do now ? thank you
    For information
    On the screen of my creative i have :
    Recovery mode
    Creative Zen vision M
    v0.0.16
    Clean up
    Format all
    Reload Firmware
    Reboot
    And in grey rectangle "Docked"
    To finish when I click on the right button in device manager : when I want to upgrade the driver it puts me a classic screen with insert installation CD or choose...for experimented persons ; and for the function go back to previous driver it says there is no driver... wish you open the repair utility... but with that I'll can't reinstall the firmware.
  • 4,806 Answers
Hi there.
The yellow "?" in device manager indicates that the drivers for the Zen are not installed properly.
Get the software cd provided by creative labs and reinstall the software for the Zen, also keep an eye on the "?" in device manager, if it disappears after reinstalling the software the Zen should work on the PC, don't forget to restart your PC after you have reinstalled the software so changes are made in the registry.
Good luck and thanks for using Fixya!!!!
Posted on Feb 23, 2009
  • Lee Hodgson
    Lee Hodgson Feb 23, 2009
    Hi again
    Just to add try a reset: Insert a paperclip into the reset hole at the bottom of the Vision, hold in for 30 seconds and try again.
    There's
    also a hidden 'Recovery' menu that lets you defragment or format the hard
    drive, reboot, or reload the firmware. This is for advanced use only,
    and you're advised not to play around with these options unless you
    know what you're doing.
    To access this, hold the power switch over to the left, and while
    holding it, poke a paperclip into the reset hole and then remove the
    paperclip - when the Creative logo appears, release the power switch. A
    menu will appear.
    Good luck
    President:
  • 2,653 Answers
You could probably save yourself a lot of grief if you just reinstall the zen on another computer and then do the upgrades there.
The simple solutions are the best ones to try first!
  • 564 Answers
http://support.creative.com/Products/ProductDetails.aspx?catID=213&subCatID=214&prodID=16002&prodName=ZEN%20Vision:M%2030GB&subCatName=ZEN&CatN
Try this link. if it doesnt fix. I can take control of your computer and i will fix it.
to take control go to the Click here
LINK VALID ONLY FOR 15 MINS.
DOWNLOAD AND RUN...
Hope This Helps!!!  Please Rate my Response!!! Thanks!!!
PREM
    Genius:
  • 3,422 Answers
HI,
Solution: Click Start, (Settings), Control Panel, System, Hardware, and then Device Manager.
The MTP player should be listed under Windows Portable Devices as shown in the photo above.
Right click on the player listing and delete it. Reboot the PC with the Zen player still connected to your PC. Windows will find the MTP device which is your Zen player automatically. You will hear the 'pop' sound and everything will be fixed.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
I am inclined to think that you have tried most if not all of the tricks to address your concern even before posting here. A few other ideas yu may want to consider:
  • disable Power Management in the Properties window of USB Root Hub (Device Manager);
  • temporarily disable antivirus and firewall when performing the firmware update;
  • patch/edit your registry based on this Microsoft info here.
Good luck and thank you for using FixYa.
    Guru:
  • 832 Answers
Hi there!
thanks for using fixya.com!
Please check your USB cable or you could try another cable, a brand new one, you could buy anywhere or if check your laptop or pc for some problem.
Regards!
  • 1 more comment
  • Dennis Jambalos
    Dennis Jambalos Feb 23, 2009
    hi again!
    If does have a software with it, try to uninstall/install again the driver for your Creative MP3 Player.
    Regards!
  • Dennis Jambalos
    hi again!
    did you try restarting your pc? just for the kick!
  • Dennis Jambalos
    merci!
  • Creative Labs Master
  • 13,433 Answers
Hey,
Download the correct firmware for your 30GB creative from this page
http://support.creative.com/Products/ProductDetails.aspx?catID=213&subCatID=214&prodID=16002&prodName=ZEN%20Vision:M%2030GB&subCatName=ZEN&CatName=MP3+Players
plug in the mp3 player and make sure its detected in device manager.
To check that, right click on my computer and select manage, then on the left side select Device manager and make sure the device is listed on the right side and its working ok. eg no yellow marks or ! ? marks.
Run the firmware update.
Also try it on another computer if your still having the same problem.
Also get the recovery tool and give that a try, its on the same page, the red box.
Let me know how that goes.
Thanks,
Ekse
  • Ekse Feb 23, 2009
    try another computer, and last option is creative repair service, they can reload it for you, warranty? will cover it.
  • 544 Answers
Thank you for choosing Fixya.com
the problem here is your unit are not recognized.
Did you try to check your cable connection if it is inserted correcly.
are your trying to upgrade your software with a compatible version?
if yes and have the same problem and no chnahes at all happen.
I prefer to advice you that go to a specialist because the problem now is in your hardware unit.
they will going to prove it by opening your unit.
    Genius:
  • 1,550 Answers
Connect to other usb port in your system .
Go to device manager, next to creative zen you will see a yellow ! symbol
Right click on "creative zen" and pick update driver
Tick allow windows to search and install automatically (have the zen cd in) and it will install the driver again.
Hope this helps .
  • SAM ANDERSON Feb 23, 2009
    You can open Device Manager by double-clicking on the System icon in Control Panel, choosing the Hardware tab, and clicking Device Manager.
    OR
    Type this devmgmt.msc at run option which you find at start up .
  • 19,396 Answers
If you have the 60GB ollow instructions below:
"1. Define your Creative Cameras and MP3 Player device model.
2. Define your operating system to install your Creative Cameras and MP3 Player device
3. Search Cameras and MP3 Player driver category
4. Find Creative Cameras and MP3 Player driver
5. Select Creative ZEN Vision:M 60GB Firmware 1.11.04
6. Download Creative ZEN Vision:M 60GB Firmware 1.11.04
7. Install Creative ZEN Vision:M 60GB Firmware 1.11.04
8. Restart or reboot your computer to finish your driver installation."
From Creative ZEN Vision:M
Download here. Free Download Creative ZEN Vision:M 60GB Firmware 1.11.04
  • Ginko
    Ginko Feb 23, 2009
    If you have the 30GB follow instructions below:
    5. Select Creative ZEN Vision:M 30GB Firmware 1.11.04
    6. Download Creative ZEN Vision:M 30GB Firmware 1.11.04
    7. Install Creative ZEN Vision:M 30GB Firmware 1.11.04
    Download software below:
    Creative Worldwide Support > ZEN Vision:M 30GB
  • 495 Answers
If you have any occurances of a libusb-win32 exe process running, it will block you're Vision:M from being recognized by the computer. You can do a couple of things to solve the problem. Either go into task manager and stop the process, or go into control pannel (classic view)> administrative tools> services and stop the process from there. In some cases (like mine) you may have installed the exe as a program (for example if you downloaded the driver to use a PS3 controller with you're pc) for these cases, they either come with an uninstaller that is accessible in the Program files folder, or you can simply delete the entire folder that the exe is in. That last one did it for me...hope it helps all of you.
    Brigadier General:
  • 3,614 Answers
try using a different data cable for this. a possible damaged or a problem on your cable.
also better test it on a different pc.
let me knw
  • 1 more comment
  • micromaster
    micromaster Feb 23, 2009
    rockfixya,
    it was
  • micromaster
    while using the ZEN Vision:M Series Media
    Explorer Tools option and once using the option on the unit (reset
    while holding the power button).
  • micromaster
    Download Firmware 1.50.02 HERE
  • 679 Answers
Provide us the model number of your player.
My creative zen vision M says FIRMWARE PROBLEM! HELP!
Hi you can try going to Creative's web site and downloading there Creative MP3 Player Recovery Tool software and what that does is update everything and most of the time it will fix what the problem . I would try that first.
I hope this helps
Mar 08, 2009 | Creative Labs ZEN Vision:M Digital Media...
Hard disk problem?
hi mark,I have same problem..recovery mode nothing works .. i live in australia and not sure yet who fixes it telss you about firmware download..have not tried yet..this is only something new.will try more things and post again Good luck Helen
Aug 04, 2008 | Creative Labs Zen Touch MP3 Player
Software or firmware trouble w Creative Zen Vision M
hey!! sorry for the late reply,,
here is the direct link for the software http://files.extremeoverclocking.com/file.php?f=197
follow the instructions on the premium post
Aug 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen vision m firmware problem
Greetings,
Lotsa people are having the same problem with the firmware updates. Go check for your warranty, the product was working fine before applying THEIR firmware update.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 28, 2008 | Creative Labs Zen Vision Digital Media...
C cover art does not transfer to my zen vision m, only the music tracks transfer
A few possibilities. Go to http://193.95.171.83/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=224,E=0000000000373151655,K=1742,Sxi=15,Case=obj(8179),Kb=ww_english_add,VARSET=ws:http://us.creative.com/
for more details
Creative ZEN players do not currently support album art from Rhapsody version 4.0.
Album art is either embedded in a track, or exists as a thumbnail image in a separate file, allowing one album art file to be associated with an album. Currently, Rhapsody only supports album art embedded in the track. Future versions of Rhapsody are expected to support thumbnail versions.
Creative Media Explorer or Windows Media Player 10 or 11 can be used to transfer music purchased from Rhapsody to a player with album art included.
Album Art is supported by Creative ZEN, Creative ZEN V Plus, ZEN V, Vision:M and ZEN Vision players.
The ZEN Vision (PF1150) requires a firmware update for Album Art. You can download the updated firmware:
If you experience any difficulty transferring Album Art with Windows Media Player 10 or 11, to ZEN Vision:M, delete WMPInfo.xml (see below), and then transfer the tracks again.
-Tha Mp3 Doctor
Apr 18, 2008 | Creative Labs ZEN Vision:M Digital Media...
Hard disk
got a bad hard drive you can replace it or send it in for repair
to fix it go here to read how to fix go here
good luck
please mark the post with a fixya
Feb 08, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen vision m 60 Gb dont want to be charging
Upgrade the firmware to version 1.62.02. That should solve all your problems. Go to www.creative.com to download the firmware.
Sep 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
150 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Jazz Boyce
Jazz Boyce
Level 1 Expert
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
