Question about Acer Aspire 3100-1405 Notebook
Acer Aspire 5520 boot problem power on linght blinks
When i try to boot the 5520 the power on light blinks green for a while, and if i try again afer a minute or so sometimes it boot ups. I have allready reinstaled the OS, but it seems to be the problem happens even before the BIOS boots up.
  • escribileaju Feb 23, 2009
    hi zohail, I don't have any other ram to try.. but if it helps, once it does boot up ther's no probelm at all (exept when hibernates, then it dies again).
    I have just reseted default setting in the BIOS just in case, but same history.
    mike, when i'm having the "blinking light" problem for a minute or so the fun is not moving... then when i try again and again and eventually boots up the fan does move.
    thanks for the quicky reply by the way!
    President:
  • 1,223 Answers
Check ur RAM try changing RAM tell me what u get
Posted on Feb 23, 2009
  • Shoaib Rais
    Shoaib Rais Feb 23, 2009
    there are 2 things i am pretty sure that it is RAM problem or Hard Disk but check ram first try changing it
  • 87 Answers
If you can't get past the bios boot then likely its a problem with the bios settings or a hardware issue on the motherboard. Make sure the processor fan is running when it turns on.
  • Michael Patak Feb 28, 2009
    Sounds like the motherboard has a hardware issue. Power supply likely.
I tryed to recover to factory and now it is just a black screen with a blinking line.please help
Please reboot the laptop, and just as it starts loading hit F8 several times, until you see the option to boot from recovery partition.
Try to go through the recovery again.
Mar 01, 2011 | Acer Aspire 5520-5579 Notebook
My Aspire 5520-5043 began showing trouble to start: no power ligh
thats mean the charging system is faulty and sometimes there are breakages at the edge of the power cable where the pin is.try another power cable if it shows the same signal then the fault is on the laptop board.
Aug 02, 2010 | Acer Computers & Internet
Acer Aspire 5520 not turning on.
If this happened out of the blue it could be the update from mcafee that is causing issue. If you have mcaffe security on that laptop read this first:
http://www.mcvuk.com/news/38641/McAfee-bricks-Windows-XP-PCs
If you beleive this not to be the issue get back to me to try soem more steps. Owen
Apr 22, 2010 | Acer Aspire 5500 5570-2609 Laptop
My Acer Aspire 5520 blinks the power light when I turn it on; it will not boot up.
It looks like your battery is either discharged or has a short circuit.
Plug the power AC cord in the laptop and let recharge the battery at least 3 hours before you try to start it again. If the computer boots up, enter the BIOS and check to see if you have a "battery check" oprion. If you do, start it and let it run until it is done (it may take several hours to complete). It will check the battery charge cycle.
Mar 22, 2010 | Acer Aspire 5520-5908 Notebook
My acer aspire 5520 will not start. the battery light is on and is red.have the ac cord in and it still will not turn on. it came on once for about 20 sec. but long so i could boot in safe mode. please...
just conncet the main power and keep as it is for 10 - 20 minutes let the battery get charged. latre on try to swicth on the laptop .if you still facing the problem then remove the battery from laptop and directly switch on main power.
Nov 27, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire 5520g black screen, power light blinking
go to acer website ...go to dowloads section..select ur model ..n download latest bios
Nov 06, 2009 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5520 is stuck in an endless boot cycle.
hello:
thad are the best solution make a waranty note for store
if you think it are a hardware problem
other wize you loos you warenty
Aug 22, 2009 | Acer Aspire 5520-5579 Notebook
Acer Aspire 5520 does not start up, power light blinking green
I think it might be the motherboard, if its not regulating the voltage properly then to much will go thru the motherboard and the fan won't be able to cool things down properly. Eventually then the motherboard will fail and then no video like your having now.
Try these steps anyway just to be sure:
only hook up the AC Adapter keep the battery disconnected. See if it turns on, if you still get a blinking green light then go ahead and turn the laptop off.
At this point, unseat and reseat the memory one stick at a time in each slot one at a time. Try turning on the laptop after each stick reinsertion.
If that doesn't do it then disconnect the hard drive and the dvd drive from the laptop.
Then try turning on the laptop, if you still can't get video then the motherboard is bad and would need to be replaced.
At this point at least you would know for sure.
Aug 19, 2009 | Computers & Internet
Acer Aspire 5520 would not proceed to boot up
Tried replacing the memory. It worked for me. I tried removing battery, harddrive etc. Same thing: briefly power light on and fan on and then both off.
Jun 04, 2009 | Acer Aspire 5520-5908 Notebook
LAptop turning off whenever it feels like it.
ctrl+alt+del
make sure close all working procedure.
Jun 01, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3100-1405 Notebook Logo
1,823 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
