SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
SOURCE: i have a cda mx194
MX194 Dishwasher.
Switch off and unplug before doing anything. .
First three lights are flashing on top and it will not stop making stupid noises.
Remove plastic panels at front of machine under door, see if there is water inside.
If there is ... something is leaking. If it is a slow leak - solution is to dry up excess water in tray with paper towels or whatever comes to hand. You will need to find the leak somehow - salt container is usual suspect.
There is a microswitch attached to a float on the left hand side inside a white plastic cover. Water at the base of this activates the switch and disables machine. Mine has not leaked since trying this fix and machine is running well 2 months down the line. Better 10 minutes with paper towels than 2 hours of expensive plumbers.
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
SOURCE: GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
SOURCE: cda cw 496 dishwasher runs cycle till rinse light
cda cw496 stops after a few minuts then just beeps help me with my problem please
You have to pull the unit out and turn off the mains. Turn off the water, unhook the water line and check the filter screen that is in the connection. If it is dirty, clean it out
dishwasher just beeps at start of cycle
