Question about Sony KV-XR29M61 TV
Power Supply Demage Of Sony TV KV-XR29M61
Hello Sir,Hi! : I have Sony TV Model No.KV-XR29M61 The probleum is that the i have lost of power supply FET No.IFRIB7N50A & replace is wrong no of part.then i swichted on then burned it and other component of power supply .i did not guest what is value or part no. i have big trouble kindly request you to please provide me Schamatic Diagramm.i m very thankful to you.awaitinh you reply.
Thanks & Regard
Abdul Ghani
  • 10,594 Answers
You can get required service manual from Manual Zone for little fee.
Posted on Feb 23, 2009
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
Connot power on
no power at all?, ok lets do a component checking at the regulator in the power supply section which have shorted pin. the at the same time at the horizontal deflection circuit which may have open resistance or shorted component.
Jul 25, 2012 | Sony KV-XR29M61 TV
I have sony 29'' crt tv . model no KV-DZM61 .when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 2 times .then the tv goes in stand by mode
2 blinks means - over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
Jun 23, 2011 | Sony KV-XR29M61 TV
Dear sir I am working with a Sony KVJ21MF model TV with a problem in Power Supply Section. No output from Power Supply. Only Noisy Occilation sound (around 50hz) from power supply. I replaced the SRT6707...
Replace the electrolytic capacitors 220uf and 1000uf/35v on your primary section of the regulator. also check the .01 Mylar cap. in parallel with b+ rectifier diode. also check if the horizontal output is shorted..
Feb 17, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Our TV shuts off when we are watching it. This
it is problem power supply some of components are demage such as capacitor or diod is bad. You go to a service centre and repear it by a good technician
Nov 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No sound or picture-just clicks when turning on-standby light flashes 5-7 times
it is problem in power supply.may be some of components are demage such as capacitor or diod and mosfac .Repear it by a good technician in your area.
Nov 22, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Berndulay@yahoo.com
Accroding to your model number:(KV-...) In sony tv units power supply porblems is very low unless a power surge.
You have to check these things.
1. Stand by 5V available or not
2.If stand by 5V available press power and check B+ is getting or not
3.If B+ available check Horzontal oscillation
4.May be H-out transistor or video amplifier is bad.
Oct 14, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony TV KV-XR29M31 with supply blow-up. Fet Q608 and Q607 short circuit taking horizontal output Q and R642 .1 ohm. Is it caused by dried-out caps and does it take IC 602? Appreciate any help. Thanks.
Replace the FETs with ones from Sony distributor. Do not substitute. Replace all of the small blue disc caps in the area. These can short causing the power supply to fry. In your case, the HOT probably was the initial problem, not the supply.
Dan
May 01, 2008 | Televison & Video
SONY KV-2740 LOST 2 PART
You can possibly find the parts at MCM Electronics.
Hope that helps...
Geno
Mar 22, 2008 | Sony KV-27V40 27" TV
Sony KV-XR29M61 TV Logo
252 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
