Question about HP Business InkJet 2800 Printer
Printer needs all cartridges for black.
I only print in black but the printer won't print unless I also replace the colour cartridges.
  • james_gower Feb 23, 2009
    Thanks Mike .... but ... what's a cleaning cartridge?
  • 87 Answers
Load the empty slots with cleaning cartridges and set the printer to greyscale.
Posted on Feb 23, 2009
  • Michael Patak Feb 28, 2009
    Cleaning cartridges install the same as your regular cartridge and are used to clean the print head. You can purchase them at most computer stores or online.
Mix-it-up
  • 832 Answers
SOURCE: Help with Cartridges
you can cheat if you like:
stick some tape around the "nose" of the colored ones. The part of the printhead which uses the C/Y/M might be in disorder because of lacking ink after some time!
Posted on Nov 05, 2007
  • 286 Answers
SOURCE: printing
Likely your purge unit needs cleaning...
Make sure by printing out a test page from printer (not from computer).
If test page is good, you have a software issue. If test page is bad, you need to clean your head and/or purge unit.
Posted on Dec 30, 2007
SOURCE: Canon Pixma IP4300 - cartridge recognition preventing any printing happening.
I am having the same problem. My magenta cartridge light is OFF, no light, I replaced it with a new cartridge but it still will NOT light up. the printer is just over a year old and customer service wanted to charge me for the last time I called up with this problem.
ANy other suggestions?
THanks,
Steve
Posted on Aug 25, 2008
SOURCE: Possible to print only black when colour cartridges are empty?
I 've bought already 2 Magenta Cartiages but it always says X on it. whats the problem. Office Max don't replace it any more.
Posted on Oct 11, 2008
SOURCE: printer prints in colour but not in black ink
did you chech if the clack cartridge is empty or not..?
Posted on Jul 21, 2009
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
Quicken 2008 won't print anything in reports in black
You need to replace the Black cartridge, as it appears the colour one is fine. Look in the printer options on your PC for a display of ink levels, and you'll probably find the black down to zero. If you've used generic cartridges, not genuine HP, you may find the printer can't actually read the ink levels.
Feb 06, 2013 | HP Photosmart D7260 Printer
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
I have a four in one Lexmark x5630 printer and have replaced cartridges with brand new black and colour 36 & 37xl. The printer won't even print a test page - just says that cartridge error co
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Try to contact the store where you bought the new cartridge(s) and have them replace it. You may also contact Lexmark Technical Support Center for assistance (especially if you're using genuine cartridges).
Feb 14, 2012 | Lexmark Office Equipment & Supplies
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
My black ink is not printing, I know that I need to replace my color inks.
Some printers won't print unless both cartridges are present.
Find your manual here if you need to.
Good luck
Oct 18, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
My Hp color Laserjet won't print unless all
You have to replace all empty cartridges...no other solution
Oct 19, 2009 | HP Color LaserJet 3500 Printer
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
I cannot print but i have only the black cartridge but i dont have the yellow cyan ang midget
Most modern printers use some colour when printing Black and therefore will not print if ANY ink cartridge is showing as empty.
Unless your printer has a setting for using Black ink only (this is not the same as printing a black and white document), then you will need to purchase and install the colour cartridges before printing can take place. The good thing about this is that very little colour ink is used when printing black and white documents - so they should last a long time.
Good luck.
May 09, 2008 | Brother Multi-Function Center MFC-240C...
HP Business InkJet 2800 Printer Logo
210 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
