Question about Xerox FaxCentre F110 Plain Paper Laser
Xerox FaxCentre F110, both red and green light on
I have a Xerox FaxCentre F110. I can't do anything with it. Both the red and the green light, respectively right and left next to the LCD display, are switched on at the same time. I have to note that both lights are NOT flashing. There is no message on the LCD display giving informaton about a possible error. Only the cursor is flashing.
Did you ever figure this one out? I'm having the same issue
Posted on Mar 01, 2011
  • ELston Oct 26, 2011
    have the same problem...I am about to change out the main board tomorrow
I had exactly the same problem and after i havent found any solution anywhere so i call xerox support and after i get it to them they told me that the cost to fix it was around 150 euros they said there was a prblem with power supply and paper loader or something like it.
Posted on Mar 20, 2014
I would like to block all incoming faxes on the faxcentre f110 so that it is an outgoing fax only, how do i do this?
You don't really need to block incoming faxes, but just set the machine not to automatically answer them. This figure is from the manual:
Press the MODE button until you see MANUAL displayed. In manual mode you need to answer and start receiving a fax yourself from the machine.
You can download a copy of the user manual from Xerox if you need it.
Dec 17, 2010 | Xerox FaxCentre F110 Plain Paper Laser
Black line on the page when printing fax or making copies
The lines may come from the toner/ drum cartridge. Try stopping the job by opening a cover, and see if the defect exists before it reaches the fuser.
The fuser for the F110 is PN 126N00235
The toner/ drum unit is 013R00605 (several alternate numbers exist)
And it could also be the transfer roller 022N02107
Hope that helps
Whit
Item, Inc.
Oct 06, 2010 | Xerox FaxCentre F110 Plain Paper Laser
Flashing cursor on a Xerox F110
Most likely the Low Voltage power supply has failed. I have seen this a couple of times on that product.
Dec 17, 2009 | Xerox FaxCentre F110 Plain Paper Laser
I am serching of front motor gear of my fax centre 123.
Google a business called " the parts drop" give them a call and ask for Britt. I dont work there, but have done business with them for a long time. Honest and professional, and fair. Give them a call, they will help you out.
Mar 10, 2009 | Xerox FaxCentre F110 Plain Paper Laser
F110 new cartridge, insert card, but card expired?
You will have to exchange it. If you got it from Xerox they will send you a new one, or exchange it as defective. That is very unfortunate.
Jan 23, 2009 | Xerox FaxCentre F110 Plain Paper Laser
My e mail adress
Cant sent to this E-mail address, I have a manual to send you
Apr 24, 2008 | Xerox FaxCentre F110 Plain Paper Laser
Fails to work though powered up
That is due either to memory corruption of a bad main board.
the memory reset is really complicated. If you want to provide me your E-maill address it would ne easier to explane.
Apr 23, 2008 | Xerox FaxCentre F110 Plain Paper Laser
We have XEROX FaxCentre 123.
1. Instead of printing / copying page by page, collate the print...see the options while printing...it will look like 111,222,333 OR 123,123,123 etc.,
2. connect the machine to LAN network by using the LAN module
3. if LAN module is not available, connect a PC to it directly and make it the print controller -> share the printer -> install drivers in other pcs and ..... start printing
have a nice day
bye
I hope my solution was useful
Feb 23, 2008 | Xerox FaxCentre F110 Plain Paper Laser
Fax centre F110
Reset 02 means the fuser is not warming up.
Most likely a fuser failure of the overheat thermostadt.
Need to have the fuser replaced most likely.
Jan 03, 2008 | Xerox FaxCentre F110 Plain Paper Laser
Xerox FaxCentre F110 Plain Paper Laser Logo
590 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
