Question about Philips Magnavox 51MP392H Rear Projection Television
Looks like dust behind front glass on phillips 46pp8621
Hi have problem with white dusty haze on front screen looks like dust behind front glass thanks regards Richard
    President:
  • Philips Master
  • 1,779 Answers
The only way to remove the dust and or spider webs from that area is to remove the front bezel assembly and separate the protection screen, it's better to leave a svc. co. do this because the two screens behind that are very expensive. Hope this helps..
Posted on Feb 26, 2009
How to clean glass tile after installation
Follow the steps
1.Rub the grout haze with a dry cheesecloth. Shake out the cheesecloth as you work to remove grout dust.
2.Scrub the glass tile with a nylon bristle brush and warm water if cheesecloth doesn't work. Wipe away the loosened grout haze with a sponge as you work. Avoid using the nylon bristle brush in the grout lines of recent tile installations, as the stiff bristles may loosen or cause damage to the grout.
3.Mix a solution of 1 cup of white vinegar to 1 gallon warm water if haze remains on your tile. Scrub the grout haze with a nylon bristle brush dipped in the solution, wiping away the loosened grout haze as you work. Continued use of vinegar can weaken grout, so only use this method to remove haze and not for regular cleaning of glass tile surfaces.
4.Apply a commercial tile cleaner to the glass tile if the previous methods fail. Scrub the haze gently with a nylon scrubbing pad, letting the cleaner do most of the work. Rinse off the tile cleaner with clean water. Use a tile cleaner that is labeled for use on glass tile.
5.Remove the grout haze with a tile cleaner containing phosphoric acid or sulfamic acid as a final resort. These acids are safe to use on glass tile and are highly effective for removing grout haze. Avoid using phosphoric acid on colored grout, as the acid may cause bleaching or discoloration. Read the labels of these products carefully before using, and follow all manufacturer's safety precautions.
http://www.regalotiles.com/productinfo/details/terrazzo-terrasso-polishing/17
Oct 06, 2015 | Bellavita Tile Glass Tile - Bellavita...
I have a phillips rear projection tv model no 55PP8620/79. Its showing a a red haze and poor picture quality. How do I fix this?
If the red haze is not convergence---that requires parts.
The set has three picture tubes---with set unplugged and back cover removed clean the three large lens that are topside---as for the red haze a quick way to know what is wrong is with set on turn the color to zero----what color is the screen? Should be black and white--if red to some degree tracking or screen controls may need adjusting inside the set---Yellow picture in that situation is a different issue.
Jun 05, 2012 | Philips Televison & Video
Copy has a white streak through it
Look on your original glass for a spot of white out, ren mark, etc. If you see something, wipe the original glass with a good NO ammonia glass cleaner. if the line persists, there is likely some dust blocking the optical path. It's not hard to do but you have to be careful.
And, be able to use a phillips screwdriver.
If you want to clean the optics yourself, write me back and I will help you.
Let me know
Jan 11, 2011 | Sharp AL-1000 Copier
My dishwasher has just satred leaving a white haze, almost a dust on the dishes. This especially bad on plastic dishes. I took it into a repair guy and he said my element was causing this. After spending...
HI. This is actually the result of a high mineral content build up that is occurring inside your unit. This can be corrected by using a highly concentrated dishwasher cleaner. Calcium build up will cause this most of the time. It occurs naturally overtime, thus producing this film or "white haze".
Click Here
May 17, 2010 | Frigidaire Dishwashers
I have a 60" sony projection TV (2005 mod.). I need to know how to take off the front screen (glass) of the TV so I can clean the inside that has gotten dusty.
U can't take out screen,it screws in as part of the LCD screen.Just take a soft cotton cloth,soap it with some water rinse it,gently clean ur LCD screen.
Apr 01, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
The date - February 23, 2010 - 6 days ago, I purchased a Sunbeam Humidifier from my local Walmart - Lake Geneva, WI. I really thought I had made a wise purchase - very quite, and was raising the humidity...
Im not going to recomend a humidifier because I need one myself and have not went shopping yet.
I would like to opinionate an explination on the white haze.
The humidifier is putting moisture in the air -water is much much heavier than the air - water is much much heavier than dust particles also.
therefore my theory is that the moisture is combining with the dust or whatever is already in the air and then eventually settling. perhaps if this is correct you may want to do some checking around in your home or furnace ducking or even furnace filter. The dust could even be coming from a little pin hole in your clothes dryer exhaust hose.
Mar 01, 2010 | Sunbeam Ultrasonic Humidifier
Phillips 55pw9363
Remove the upper back and clean the three projector lenses with Windex and soft paper towel. You have dust build up. If there are smokers in the house then also windex the back side of the screen to get the nicotine film off. This cured my picture. I had lost fine detail and the picture looked like there was a white haze over it.
Jul 21, 2008 | Televison & Video
Power supply problem with Phillips 46pp8621/79
Your chassis is the DPTV 325 you can get the factory training manual for your set emailed to you at the following link. It cost 12.99 but comes with unlimited tech support if you need it. The manual is listed as DTV300 series training manual its has the trouble shooting proceedures and diagrams that you would need. heres the link.
http://servicemanuals.vstore.ca/
May 11, 2008 | Televison & Video
Problems with my Phillips Rear Projection TV!!
have the coolant (glycol) in the CRT's....not as expensive as buying a new set...and sounds like it should be good as new if thats the only problem you have with it.
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
180 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
