Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba touch pad not working to tap of finger
The touch pad worked find until I tried to get Windows mail working and now when you tap the screen to open, close or just click nothing happens!
It was working fine until then, so I am wondering if there is a setting or did I turn something off ?
    Novelist:
  • 172 Answers
First got to Start/Settings/Control Panel/Mouse(or there may be a separate Touch Pad setup) and check were options for touchpad Settings Options are tabbed or listed.
All touchpads allow on/off settings for Tap or NoTap. Also, check Sensitivity Settings. If very low, then Tap would have to be very hard to be recognized.
Next, reboot your computer.
Posted on Feb 23, 2009
Touch pad no longer reacts to finger tapping but still can drag.
You can try solve this problem by,
1) Uninstalling the touch pad driver and reinstall the driver.
If the problem is not fixed,
2) Try installing latest version of driver.
Jun 22, 2011 | Toshiba Satellite L500 Series Notebook
Cursor is frozen, tried allsorts to solve it. Nowt works. Using mouse with usb cable, works fine. Synaptic logo from bottom right of screen also gone. Tried system restore and it works until I log on...
Sounds like a driver issue with the touch pad. You should try and reinstall the driver.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1998675&rpn=PSLB1U&modelFilter=L300-EZ1004X&selCategory=2756709&selFamily=1073768667#
follow that link..it will take you to the driver page for your model laptop.
Mar 07, 2011 | Toshiba Satellite Pro L300-EZ1004X...
How to use touch pad dell latitude D610
The touch pad on a Dell Latitude D610 works much the same as with other laptops. You can move your finger around the pad to simulate the movement of a mouse, and it will cause the pointer to move across the screen. You can also tap on the touch pad (gently) to "click" on a file, folder, or other item. The touch pad on a D610 doesn't have a hardware switch like some other laptops do so that you can turn it on or off -- it's just always on.
Aug 08, 2010 | Dell Latitude D610 Notebook
My touch pad will not allow me to tap on it with my finger to choose things but will allow me to use my finger to move the arrow around the screen? help it very frustating
just reinstall the driver for it ..if it has no driver it works just with the generic one in windows and the scroll and select will not be allowed..or install a usb mouse and will be easier to work and have all features..(in case the driver is not available for the touch pad )
here is the place to look for the pad's driver ..
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=380609&rpn=PS630U&modelFilter=&selCategory=2756709&selFamily=1073768667
this is for Toshiba m-15 s405 ...I linked it cause you placed the question in this category ..If you use another model ..select it from the download list ..also select the operation system ..
If you do use this one ..but another operation system try to install it anyway but under the executable properties modify to run in compatibility with windows xp
have a nice day ..and please rate my answer ...
May 20, 2010 | Toshiba Satellite Pro M15-S405 Notebook
Synaptics touch pad, double tap not working
look in the sys tray, (lower left of screen) one of the icons will be concerned with the touch pad. you can turn on and of the double tap here. Sounds like yours is switched off.
Nov 04, 2008 | Logitech V220 Mouse
Toshiba notebook touchpad tap doesnt work
Goto 'Control Panel - Mouse - Device Settings, Highlight the device in the list and then click settings. It Might just be that it needs re-configuring. Devices like this tend to loose there configuration due to being used so much and of course the ammount of pressure put on them. There is alot you can reset here. The touch pad does alot more than you think, We just dont bother to look at the settings because we are too busy looking at the screen,and rightly so. Im not saying this will rectify the problem but its worth a try.
Sep 21, 2008 | Toshiba Satellite A135 Notebook
Touch pad not working
That's a sign that the synaptic touch pad needs to be replaced. Eventually they wear out.
Jun 13, 2008 | Toshiba Satellite A105 Notebook
Toshiba laptop touchpad click not working
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Mouse touch pad
I couldn't find an answer online, I have a Toshiba satellite with Vista and the clicking wasn't working on the pad. I found the answer....
open control panel...
hardware and sound....
mouse....
the tab Device Settings
click Settings
click Tapping on the left
click the check box enable tapping
and for everyone with problems with nothing working on the pad at all hold down the FN key next to the control key and press F9
Feb 05, 2008 | Acer Aspire 3000 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
298 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
