When i start my compaq presario f700 it loads to the presario screen while a buzzing sound(sounds like a busy tone) then it loads on a black screen operating system not found. The only other screen i can access is the bios utility screen. When i try a hard disk self test it states there is no ide device. I cannot change the order of the boot devices. I do not have the recovery disks as well. Is there anything i can do?
Check HDD power and IDE cable carefully. Better replace them. Open BIOS. Do you see your HDD on BIOS ? Do you hear any sound from your HDD ? Do your HDD produce some heat ? If no, replace your HDD with new one. If yes you need to repair your BOOT file and MBR. Do you have any XP installation CD ? If not collect now. If yes, boot from CD. follow instruction and press 'R' to enter recovery console. Give password , leave blank if none. Select os by pressing 1 (in single boot). Now in command prompt type this two command one by one "fixboot" and "fixmbr" without quote. Type y to if required. Than type exit to exit recovery console.
If this does not solve the problem, you must give a fresh OS install. Keep informing.
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
http://forums.lenovo.com/lnv/board/message?board.id=N_Series_Lenovo_3000&thread.id=10549
not booting ran hard drive self test and found no ide device is hard drive gone
