Question about LG DLE2532W Electric Dryer
DLE2532W electric dryer: BLOWN CIRCUIT BREAKER
There are no signs of overheating of the dryer, the lintfilter is clean and the exhaust pipe has been disconnected to ensure free airflow.
There are no warning signs on the control panel; the dryer apparently overloads the circuit breaker and one of the the wires connected to the breaker is piping hot
The circuit breaker for the dryer opens after 90 second after the dryer has been started.
  • tjrships Feb 23, 2009
    One wire at the circuit breaker was loose and burned. Stripped off burned insulation, reconnected the wire and the dryer runs fine. Thank you for the advice.
  • 360 Answers
I would check the wire at the breaker for a poor connection causing arcing and excessive heating causing the breaker to trip....with the breaker off, loosen the binding screw on the wire and check the wire for any signs of arcing. reattach the wire and tighten binding screw snugly.
another though, ensure there are no other devices connected to the wire that is heating.
Posted on Feb 23, 2009
My dryer we've had for about two months won't dry clothes. it heats up, but they are still wet four cycles later
I was thinking you have a bad circuit breaker. This dryer runs on a 2 pole 30 amp 240 volt breaker. The motor runs on one side of the breaker on 120vac. The heater has to have 240 volts to work correct. When that breaker is on the way out it will take a new dryer 3 or four times as long to dry the clothes. themobilian_294.jpg
If you are cleaning the lint filter out and don't have a clogged vent pipe themobilian_295.jpgthen in my opinion you have a bad circuit breaker. Seen it.
Nov 27, 2010 | Amana NDE2335AY Electric Dryer
All of a sudden dryer won't come on. Checked connection, OK.
Check your circuit breakers. Your unit usually has a double circuit breaker. Find the correct circuit breaker and turn it to the off position to reset it then turn it back on.
Good luck
Sep 29, 2010 | LG DLE2532W Electric Dryer
The dryer "lintfilter" light comes on and the dryer stops- however the lint filter is totaly clean and free from lint. how do I fix this? Sue
Sue -- LINTFILTER light without visible LINT means that either A: the internal (or exhaust) lint pathway is blocked or B: the sensor that makes sure the unit does not "overheat" is malfunctioned. Check the dryer output hose to make sure it is not plugged. Get your vacuum cleaner and make sure there is no lint buildup below the lintfilter screen. If you need more help, please ask. -- SWT
Aug 04, 2010 | Dryers
The dryer has no heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check the lint filter and exhaust duct is clean.
Select the heat setting other than Air Fluff.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Samsung DV448AEE Electric Dryer
Will not get hot
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker. Make sure that the lint filter and exhaust duct is clean.
Another common cause of a dryer failing to heat is a faulty heating element. You will need to replace it.
Jun 30, 2010 | Maytag SDE3606A Electric Dryer
My dryer dont want to heat is electric dryer what you think it is
Jun 26, 2010 | Whirlpool LER5636P Electric Dryer
My dryer all of a sudden will not come on. Is there a reset button on these dryers?
Your problem could be a result of several possible issues:
* voltage coming to the dryer (110 V for gas & 220 V for electric); Check circuit breaker, voltage at wall outlet, etc.
* thermal fuse (non-resettable) that has blown and shuts off the dryer typically due to overheating (may be caused by clogged exhaust system)
* timer
* motor
* Start button or door switch
You should contact an appliance service company if you have checked the circuit breaker for proper voltage.
Jan 20, 2010 | Roper REX4634KQ Electric Dryer
My dryer won't turn on what can i do?
Check house fuses or circuit breaker.
Ck. power cord and power outlet for signs of arching an replace if needed.
Ck. power cord at dryer side and make sure the ends are not burnt. Unplugged of course.
If all is ok call for service.
Jan 16, 2010 | LG DLE2532W Electric Dryer
LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
http://www.repairclinic.com/0100_16.asp
Hope this helps.
Illeagle
Aug 27, 2008 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
193 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Dryer Expert? Answer questions, earn points and help others
