Question about Phoenix Gold Octane-R 8.0:4 Car Audio Amplifier
Were do you connect the sub and what wire do you use
  • 93 Answers
Is it a 4 or 2 channel amp will be label as 'L' + and - and 'R' + and - will need to use some thick gauge wire like 6mm /10mm
Posted on Feb 23, 2009
2 ohm amp to 2 10 inch dual coil 4 ohm subs how does it need to be wired
Is the amp a single channel? If so, the only way to connect the subs (without overloading the 2 ohm stable amp) is to wire each sub's voice coils in parallel (2 ohm) and then connecting the subs in series (4 ohms). If the amp is two channel, the subs can have their voice coils connected in parallel (as before) and then each sub connected to its own channel.
Apr 08, 2016 | Dual Car Audio & Video
I have a JBL TLX CSS-SUB1 sub at the back are where you connect the speaker wires to the receiver but i don't know witch wire goes in what? i have no clue
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | JBL Audio Players & Recorders
Hi, I have the Kenwood Subwoofer KS-201-HT, my question is how do I connect it to my receiver?
usually subs have outputs 4 ur monitors however if ur sub is active @ ur monitors are passive then you need 2 connect sub 2 ur tape loop with rca connections,usually you use the send signal from ur reciever which would norm connect to ur tape input , if the sub is passive then u connect direct to speaker output on amp then monitors to the sat connections on sub
Oct 12, 2010 | Kenwood SW36HT Subwoofer
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
Installing subs, how to use rc converter
from the rc converter i connected to the rear speakers taking both positive (left and right) to the positive on the factory speakers, then done the same with the negative (left and right) to the negative of the factory speakers. i connected with a quick connect. then from the converter to the amp using rc's. since my battery is in the trunk, the only wire i had to run through the car is the remote wire from the radio to my amp and then my subs to my amp.
May 14, 2009 | 2005 Chrysler 300
Need wireing diagram for hooking up two as12sq 12-inch square 2
you can run each sub at either 4ohms or 1ohm which means that two of them will run at either 2ohms or .5ohms....be careful how you wire them because most amps cannot handle .5ohms very well and might blow.....to wire them for 2ohms you will need to wire each sub the following way. they have two voice coils make a jumper wire connecting the negative on one coil to the positive on the other coil. what you are left with is a coil with an open positive and the other coil has an open negative. when both subs are wired like this connect the two positive terminals together (1 from each sub) and the two negative terminals together (1 from each sub) now the subs should be wired together at a 2ohm load. run the two positive wires into another combined wire which will run to the positive speaker terminal on the amp. do the same for the negatives
Apr 17, 2009 | Hifonics AS12SQ Car Speaker
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
3 amps 2 subs sound system for car, need wiring help
As i read your problem i can recommend you that connecting each of the hifonics amp to each hifonics sub with the same specs by getting the specs in interfacing the two or you can simply look to the output of the amp and the input of the sub and find a suitable plug that fits to them.
In the case if you want to run each hamp to individually run each sub but sharing 3 farad capacitor: what i can suggest is that you connect in parallel one connecting wire of each input or ouput of the amp or sub. Its like connecting a connector from each of the input or output of the amp or sub to one leg of the capacitor, and connecting two wires to the other leg, one is being connected to the amp or sub and the other wire is connected to the other amp or sub.
In the case of putting a circuit breaker at the car battery: what i can suggest is that you find an appropriate circuit breaker that fits the specs of the car battery then connect it in series on the positive supply or read the specs of the circuit breaker before you connect it to the battery. Having a circuit breaker is like having a fuse but with special advantages in favor of the circuit breaker.
In the case of having power to the amps you can run one power wire to the amps by dividing the power wire into two, one connected to the amp and the other wire to the other amp. Then you can connect each amp and sub in series individually by connecting one wire b/w amp and sub. I hope i solved your problem
Feb 08, 2008 | Car Audio & Video
Phoenix Gold Octane-R 8.0:4 Car Audio Amplifier Logo
79 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Matthew Spark
Matthew Spark
Jose Velazquez
Jose Velazquez
ronniebissoo
Level 1 Expert
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
