Question about Intel Motherboard
Desktop CPU isn't booting fine...
Whenever i put on the system, when it gets to the point where it says "start windows normally" and i press the enter key it hangs there,and nothing happens again.the hard drive is a new one that i changed, but formated it in a different system.what is the cause of this?
  • 790 Answers
Hello!!
yes of course .. u cant format it in different system .. u want install the new copy of OS in ur system .. All the hardware signs with the OS .. so that u can use it with ur system .. SO the solution is to gotta reinstall the OS!!
Posted on Feb 23, 2009
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
My HP Pavilion is stuck on the blue screen
While your system is still booting from start, keep hitting F11 to get past that point then proceed with the system recovery.
Nov 12, 2013 | HP Pavilion a6110n PC Desktop
Message saying windows did not start properly. recent hardware or software change may have caused
There must be a corrupted software drivers.
For quick solution tried to boot in safemode then perform system restore, if it doesn't work tried to restore the last known good configuration.
How to boot in safemode:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
  4. Once your on the Windows desktop, click on Start>All Programs>Accesories>System Tools then select System restore
  5. Choose the recent date or restore point that your computer is working fine.
How to boot in Last know good configuration:
  3. When the Boot menu appears again, and the words "Last Known Good configuration" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Jul 13, 2011 | HP Pavilion a1620n (882780664494) PC...
PC boots but no video display. worked fine last night. i was reading on my PC Kindle ap. fell asleep and when i woke the screen was asleep. i shut the unit down. didn't think anything of it. Now...
look sir
first thing you try to boot on safe mood (to make sure that the problem is about operating system windows or the problem could be simply that the display card driver has crashed
turn on your computer
press f8 repeatably you will show a list to choose from like
1 - start windows normally
2 -last know good config .....
- safe mood
press the number crossponds to safe mood the enter
wait until the machine boots
it will look odd the windows don`t worry
go to start menu then select accessories ---- system tools -- system restore
choose yesterday cheek point
May 22, 2011 | Acer Aspire 77415137 Core i3350M...
No output from CPU - led lights up, CD drive
Just for a chance , can you press f8 before it loads windows or alt and f12 or f12 by its self to give u a system restore setup, or a last known good confirutation options, hope this helps in some way, remember keep pressing either of these just before the point it goes to load windows, strait before bois screen goes.
Dec 04, 2009 | HP Pavilion a1140n (PX774AA) PC Desktop
Windows will not open up
try to get into safe mode (press the f8 key at the bios screen, before it starts to enter windows) inside safe mode, go to control panel/system/device manager, and look for and repair any hardware defices denoted with an exclimation point ,caution sign or red x.
Dec 29, 2008 | eMachines T5274 Desktop PC
Can't get out of safe mode
While booting ur system press F8 initially when system turned on you will get booting options .Select Normal and Enter you can able to boot in normal mode.
Oct 26, 2008 | Microsoft Windows 2000 Professional for PC
Icons & start
boot to safe mode..then do a system restore about 15 days back
Apr 18, 2008 | Microsoft Windows XP Home Edition
My computer starts but before booting it shuts down.
You may have lost part of your windows program. If you have a system restore disk, you can run a system restore and probably fix your problem.
Some of your windows files have gotten deleted. When windows gets to this point all windows knows to do is restart. A virus can cause this problem.
Stargazer
Mar 16, 2008 | Gateway 310S (2900621) PC Desktop
Intel Motherboard Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
