Question about Whirlpool Dishwashers
Need to purchase the one adjustable foot - Whirlpool Dishwashers
  • 360 Answers
Posted on Feb 23, 2009
Foot not tight enough against feed dog to hold fabric as I sew.
The foot always has an adjustment screw that is above the foot. Follow the foot arm directly above the foot. It will have a little screw above the foot that turns. You may have to open the front of the machine where you will see a small numbered gadget; round or star shaped usually. Anyway, this will have to be adjusted by the sewing individual. If it can't seem to be adjusted to hold the fabric the foot arm length needs to be adjusted by a repairman. Anyway, go to utube and type "adjust sewing foot pressure" for an easy lesson.
Aug 23, 2017 | Sewing Machines
Pfaff 113 want to free motion quilt the foot will not allow me to se. I even took the screw for adjusting preasure all the way out and it still has too much preassure
Sounds like perhaps you have the incorrect foot. Did you perhaps purchase a quilting foot (used for piecing)? A free motion foot is actually shorter in height so it will not contact the feed dogs or needle plate. It is this added space that allows the fabric to be moved freely under the foot. Also, be sure to drop the feed dogs.
Open Toe Free Motion Spring Foot
Open Toe Free Motion Foot
Pfaff 113 free motion foot Google Search
If the presser foot is still too long, perhaps the shank is not correct for your machine. Sorry, am unable to locate information re your particular model.
Sewing Machine Feet
Apr 05, 2017 | PfaFF Sewing Machines
How to put singer model 6233 foot pedal back together
These machine s are mechanical wonders, always have your machine serviced by trained technician. End user servicing is not recommended, and if needed, parts will not be available to end users so take your machine in for service, repair and adjustments to sew perfectly. A new foot pedal can often be purchased on Ebay or just make sure it's made for your machine make and model when making this purchase.
Embroidery Services
San Diego, CA
Jul 25, 2016 | Singer Sewing Machines
When I sew silk or fine fabric the thread breaks and the fabric bunches up, what am I doing wrong, I first had the A foot and changed to B, changed the needle and still the problem persists
Check to be sure you are using needles and thread that are compatible with the fabric. Generally, finer threads will work better on fine fabrics along with a smaller needle. Be sure to change needles frequently as dull, bent, or nicked needles will cause very frustrating issues.
All About Needles
Remove the thread completely from the machine. RAISE the presser foot and rethread from the beginning, making sure the thread path is correct.
Some machines have a presser foot pressure adjustment (consult the owner's manual). Adjusting the pressure that the presser foot applies to the fabric & feed dogs is helpful when sewing especially fine or heavy fabric. Also, when sewing fine fabrics, loosening the tension could be beneficial.
Changing presser feet may also help, ie try using a straight stitch foot vs a presser foot for zig-zag stitching.
Something else you can try is finding a presser foot with a teflon finish or a roller foot that will glide or roll with the fabric through the machine. Even if you can't find a brand name presser foot for your particular machine, an adapter shank can probably be found that would allow you to use snap-on feet of all different designs and uses. Provides a lot of choices for presser feet for less than purchasing a brand-name presser foot. There are snap-on kits available on eBay and other auction sites.
Some machines also can take a straight-stitch needle plate--usually an additional accessory that can be purchased. The hole where the needle penetrates the needle plate to access the bobbin thread is actually a small round hole. With a zig-zag needle plate, the hole the needle penetrates is a wide rectangular hole that can allow fine fabrics to be pulled down through the hole. Zig-zag capable machines usually have a zig-zag needle plate as standard.
Feb 22, 2016 | Sewing Machines
How to sew narrow seams
A hem gauge foot is adjustable and can aid with small seams
Jan 03, 2016 | Sewing Machines
I have lost the warranty and and also the tool for foot adjustment. Where can I replace these?
the tool will be a spanner of the right size
The warranty is the receipt of purchase as that gives the date of purchase
Jun 21, 2015 | Bosch Classixx WFL 2066 Front Load Washer
I need help with the outside walking foot on a singer211 it has to much pressure on it I need to know how to adjust.
I am NOT familiar with your Singer model 211, BUT.... Most machines [most brands too] have a knurlled screw knob on top which is attached to the long vertical shaft upon which the foot is mounted at the bottom.
"Normally," turning this screw clockwise tends to increase the foot pressure, while counterclockwise rotation tends to loosen the spring pressure on the foot!
Jan 09, 2015 | Sewing Machines
Gear shifter adjustment
The VZ 800 ,has a linkage system ,it can be adjsted to suit your needs .Firstly , your linkage attaches to the front foot lever.on the other end the linkage attaches to the actual gear box.Its this part that you need to adjust ,Undo the bolt that holds the linkage bracket to the gearbox spline. slide the bracket of the spline .undo all the adjusting screws on the linkage rod ,position the gearbox linkage unit to the required angle you need to position the foot lever to the popsition you want and the adjust the linkage rod to suit the distance between the garebox liinkage unit and foot change.
Mar 25, 2010 | 2002 Suzuki VZ 800 Marauder
Adjustable Foot Rest
it may still be under warranty so the store you purchased it from can help
May 11, 2009 | Quinny Buzz Three Wheel Stroller
Dishwashers Logo
37 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
