Question about Ultra Linear UL-2200D Car Audio Amplifier
CONNECTING 2 12" L7 TO US AMP MD1
OK SO WHATS THE BEST WAY TO CONNECT MY 2 12" SUBS TO MY US AMP MD1..I WANT THE SUBS TO HIT NICE AND CLEAR...
  • blueextc3221
    blueextc3221 May 11, 2010
    what is the voicecoil configuration of the L7s?
    Dual 4 ohm, dual 2 ohm, single voicecoil??
    Let me know, and I can help you.
    Problem Solver:
  • 11 Answers
IF THE AMP IS BRIDGEABLE, THEN BRIDGE THEM. IF NOT THEN RUN THEM MONO. THE TYPE OF VEHICLE HAS ALOT TO DO WITH HOW TO HOOK THEM UP.
Posted on Feb 24, 2009
I have 2 solo baric l7 duel 4ohm subs and a legacy la-2499 amp.What is the best way to wire it up?
Unfortunately, the amp is only 2 ohm stable, so the best option is to connect each subs voice coils in parallel (2 ohms) and connect the subs in series (4 ohms).
Oct 06, 2015 | Legacy Car Audio & Video
I have 3 L7 kicker 15" subs will my audio pipe 1500 watt run them
Well the L7 15'' solo-baric subs are rated at 1000 watts RMS, so that would be 3000 watts of RMS amplifier power you would need to supply to adequately power all of them. I also suggest that an amp capable of producing more power than what is needed is usually better in order to prevent the amplifier from running at maximum capacity for long periods. In short your amplifier will power those subs, however you will only be able to supply 1500 RMS watts to the three subs so you will only be pushing the subs to 50% of their rated capacity while using 100% of amp capacity which will make your amp run "hot" and your subs run "weak", but if you're in a pinch it will work. Your best bet in this situation is to wire the setup so that the subs and amp are operating at minimum ohm stable impendence (usually 2 ohm). Seeing that you have 3 subs begging for 3,000 watts of power and you are only going to give it half of what it wants, I would suggest upgrading the amp or at least buying another one so that you can bridge the wattage and redistribute to all three subs with the correct impendence.
Aug 31, 2015 | Kicker Car Audio & Video
I have 2 12
To be on the safe side without further information I would hook the two subs up in series leaving you with an 8 ohm load.
Nov 12, 2012 | Kicker Solo-Baric L7 12'' Car Speaker
I have 2 kicker l7 wanting to wire to best olm with hifonics 1200 mono
the best way to wire it is @ 1 ohm, but your amp has to be a 1 ohm stable amp. i'll attach some pics for you. this wiring depends on what ohm your subs are.
Option #2
2_2ohmdvc_2ohm.gif Wiring Option #3
2_2ohmdvc_8ohm.gif Option #2
Feb 26, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
Jul 16, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have 2 kicker l7's 4ohm, how do i wire them down to 2ohm?
If the subs are dual 2 ohm voice coils.....
  1. For a each sub, connect one of the "+" terminals on the sub to one of the "-" terminals. This makes each sub 4 ohms.
  2. Connect the unused "+" terminals of each sub together. Do the same with the unused "-" sub terminals. This makes the sub combination 2 ohms.
  3. Then connect the "+" and "-" sub terminals from the above step to the amp.
If the subs are dual 4 ohm voice coils, you can't connect both subs in any fashion to get a 2 ohm impedance. The best you can do is make a single sub 2 ohms by connecting both "+" terminals together and both "-" terminals together or the pair of subs 4 ohms by doing the same, then connecting one sub's "+" terminals to the other sub's "-" terminals, then connecting the other "+" and "-" terminals to the amp.
Apr 04, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
HOW TO CONNECT 2 12" KICKER L7 TO A US AMP MD-1D
So you have to run both of the subs to your amp so that its see's 2ohms. The L7's probably have to voice coils to connect both the positive's together and both the negatives together to the positive and negative on your amp
Feb 25, 2009 | Compaq Audio card Sound Card
I have two 15inch l7 subs 2ohm
With 2 ohm dvc a sub can output either a 1 or 4ohm load.therefore with 2 subs you end up with 2ohm or 8ohm load.Of course you'll use the 2ohm connection which is this.....
Take one sub and connect the (-) with the other (-) and the (+) with the (+).
Do the same with the other sub.Each sub now carries out a 1ohm load and you end up with 2 pairs of cable.Now take one(+)and put it on the amp.Take the (-) from the OTHER pair(this is critical) and connect it on the amp.You will still have a(-) from the first pair and a (+) from the other pair!Well....connect them together!!!Thus you'll have a 2 ohm load on the amp!
Nov 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Ultra Linear UL-2200D Car Audio Amplifier Logo
82 people viewed this question
Top Ultra Linear Car Audio & Video Experts
Professor_V
Professor_V
FastHarley
FastHarley
matthew nulph
Level 1 Expert
Are you an Ultra Linear Car Audio and Video Expert? Answer questions, earn points and help others
