Question about Samsung Digimax S800 Digital Camera
Hi, when i start my camera it showes "connecting computer" even when i dont connect to the PC. can any one have solution
  • 790 Answers
Reinstall the camera drivers in ur comp ./..
Posted on Feb 23, 2009
When I switch on to download photos the camera lense slightly comes out and there is also no beep noise that normally follows, it is not letting me download?
Even if the USB cable is connected perfectly to the camera and PC it still is not sure everything in the cable and both connectors is 100%. Or even the drivers in the computer can be corrupted.
Start with another cable, and if possible try to connect another camera to the compeer, to check the computer acts normal to that.
Always try to isolate a problem to one thing.
For the time being, you perhaps could place the memory card in an external card reader connected to the computer, to put the pictures on your computer that way?
Jan 29, 2014 | FUJIFILM FinePix S1800 Digital Camera
Usb connection show on starting
connect camera to pc and power on the camera.
Nov 20, 2013 | Samsung ES30 Digital Camera
I have a Kodak mini Zm1 that connects to the computer, but as soon as it starts to download the hardware it says that it is disconnected(which it isn't). I can't access any of the files on the...
When I want to download from my camera it has to be switched on and I have to open the camera menu and select PC before it connects to the computer and once it connects it shuts down so it doesn't run the battery down.
Sep 05, 2017 | Cameras
When I connect my camera to the computer to transfer picturs the camera turns off>
Try using some SD card reader and connected this device at pc.
Jun 02, 2011 | Cameras
I dont have any disk and want to download one, my disk has gone
Most of these cameras will work without any discs.
all you need to do in most cases it to just plug the camera to your computer with a usb cable, if the camera screen shows options select the one for PC or storage, NOT PC CAMERA (which will instead of showing your pictures turn the camera into webcam mode where you can see the picture feed from the lens instead of your pictures)
Ones connected open my computer or "computer" from either your desktop or from start menu.
you should find your camera in my computer under a removeable storage device or the cameras name.
Jul 29, 2009 | Canon IXUS V2 Digital Camera
Pics not showing up
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Jun 10, 2009 | Olympus Stylus 1010 Digital Camera
Pc camera dose not work properly even if software is installed.
there is a web cam mode in the camera settings put it on webcam mode check the settings in camera , and then connect it to ur computer actually u are connecting in usb mass storage mode it will only allow u to copy pics to ur PC for webcam if ur camera supports it u should have this mode in ur camera menu check and then connect it thru usb see if it works ok
pls vote fixya if i fixed ur problem
Feb 02, 2009 | Vivitar ViviCam 5355 Digital Camera
Digital concepts digital camera
This camera is compatible with vista and you dont need any software for this camera to work on vista, its plug in play device. When you connect the camera to your computer it should show up as removable disc under my computer. If its not showing up please try connecting the camera into different usb port and make sure your laptop is fully charged.It will work.
Aug 21, 2008 | Digital Concepts 54782/54783 Digital...
My Canon A540 cannon be connected to my PC
Here are the steps to take.
1. Establish whether or not you have a connection between your camera/computer by going to your start button, control panel, system, hardware tab and device manager. The camera must be powered on and in playback mode (should automatically go to playback mode when connected, camera's screen should go black if there is a connection). Make sure you have a fully or nearly fully charged battery in your camera.
2. Once in device manager, look under Imaging Devices. If your camera is properly connected it should show up as Canon Powershot SD800. If it shows a yellow exclamation point, there is a driver issue, and even if it doesn't show a yellow exclamation point, you may want to update your driver anyway by right clicking and having the system search automatically for driver updates. If download of driver begins, great...once finished, restart camera and your problem may be resolved.
3. If there are any other imaging devices, you may have to temporarily disable them to avoid conflicts.
4. If you have any other imaging software running, exit or close the program in your system tray (down by your clock in the right hand corner of your computer's desktop.
5. Try again to connect.
6. If you are on a desktop, try a rear usb port vs. a front port. You can also try a different port on a laptop. After each change, try restarting camera to establish connection.
7. Go to start/My Computer and look for the icon for your will be able to download images even without Canon software loaded onto computer so this is not a software issue if you have no hardware connection. If you see the icon, right click on it and choose Get or Import pictures. From there the default Microsoft scanner and camera wizard should launch and you will be able to import your images.
8. If still no connection, try going to Start/Run and type in services.msc here you are looking for 4 services to be running. Check under status of each service and make sure it reads that each of these services are started.
  • Canon Camera Access Library 8 (if Canon software loaded)
  • SSDP discovery service
  • Universal Plug and Play Device Host
  • Windows Image Acquisition
Once all of these services are started on your computer, restart camera once again. If any of the last three services are not on your computer or are not started, connecting will be a problem.
If all of these steps fail, try purchasing an SD card reader from your local electronics store for around $12 and download images from there. Canon also offers lifetime technical support for your Powershot, so give them a call if none of these steps work or if you would like someone to walk you through it.
Best of luck to you!
May 29, 2008 | Canon PowerShot A540 Digital Camera
Samsung Digimax S800 Digital Camera Logo
47 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
