Question about E-Machines eMachines Desktop PC
On off button
Were do the wires go to that are connected to the on and off button
My windows player is not working and realone player too.
Posted on Feb 23, 2009
I have an Edwards C210-W Economy Door Chime for my livingroom door. Wires came undone while painting and I don't know which wire goes where. Yellow wire coming out of the wall is from the transformer
They are connected to the chime terminal board with 3 connections!
1) wire from the transformer.
2) wire from 1st push button.
3) wire from 2nd push button.
Dec 29, 2015 | Cars & Trucks
How to i replace a horn that has three wires to it when the horn I bought only has 2 connectors
I am not an expert on auto horns, but can solve most electrical problems. Do you have a multimeter? Using the ohm-meter, measure the ohm value between the two wires, and from each wire to the horn mounting bracket (you need contact with un-painted metal. The value between the wires should be low (10-100 ohms) but not zero. This represents the horn coil. The value between each wire and the bracket should be very high (10 kilohms or more). This means the horn coil is not grounded to the bracket.
Now, using the voltmeter, measure the voltage between each wire (from one wire to another). The value should be zero before pressing the horn button, and 12 vdc when the horn button is pressed. I would expect one of the wires will also be zero ohms (ohmmeter) when measured to the car frame or body.
Ok, you are ready to hook up the horn. The auto ground wire(s) are connected to a horn wire that is common with the horn bracket. Or, connected to a black horn wire if both horn wires are isolated from the bracket. Connect the auto switch wire (the one that reads 12 vdc when the horn button is pressed) to the remaining horn wire.
Nov 29, 2014 | 1996 Saturn SL
Atv repairs
Hi Lee,
The starter requires substantially more current (amps) than the little wires and contacts that make up the start button and starter circuit. These small wires power a solenoid (an electro-magnetic switch) when the start button is pressed; which in turn closes a much larger contact that connects the larger battery wires to the starter motor.
You may have a blown fuse or fusible link, bad starter switch button, bad solenoid, broken wire(s) between the starter button and solenoid, poor connections at any of the terminals on these devices or a bad starter motor. Check the these circuits with a volt meter capable of testing 12 VDC or using a test lamp. Start with the one probe of the meter or lamp connected to a good ground or (-) post of the battery. The other probe should see 12 V (+) power on ONE of the starter button wires and on BOTH when the button is pressed. If not, work your way back to a bad connection or cut wire. Next, locate the solenoid. There should be two heavy cables and one or two smaller wires entering. The smaller wire is from the start button. Power 12V + should be on it when the button is pressed. If there are two smaller wires, one is probably ground or (-). If no power, check the wire for damage, etc. by following the wire back to the starter button. Once you have 12 V + starter circuit working into the solenoid, go to the next step.
Next, check the two heavy cables on the solenoid. One should have 12 V + power on it all the time and the other should have power only when the starter button is pressed. If you do not have power on one of the cables all the time, there is a bad connection,etc. between the solenoid and the + battery post. Check fuses, connections, etc. and make repairs. With power on one cable, press the start button A working 12 V starter circuit is required for this to work. If no power on the other heavy cable, the solenoid should probably be replaced. If you do have power out, it it still won't crank - check the cable between the starter and solenoid. Repair or replace as needed. If cable is good, the problem is likely to be the starter itself.
Apr 01, 2014 | ATVs
I'm running a toggle switch for my key and a push
Hi, connect the big hot wire from the fuse link to both the switch and the push button. On the other side of the switch, connect the pink, pink/black, and brown/white wires. Finally, connect the yellow wire to the other side of the button. Please let me know if you have any questions.
Oct 27, 2011 | 1983 Chevrolet Camaro
Replaced push to start button on console and can't remember where grounding wire was connected. It was on the right side where there are 2 holes one has metal on it the other is plastic. Where does the...
Assuming you are actually speaking of a ground wire: The ground wires connect all of the metal cases together. In your situation, you are connecting the start button housing to the washing machine housing.
Plastic does not conduct electricity (not saying that you did not know that).
Interesting that a washing machine was a push to start button (like a dryer). None the less, if the button only has two wires on it (and neither is ground), then it should not matter which is which.
The inclusion of a model number is helpful for wiring diagram obtainment.
:o)
Jun 03, 2011 | Washing Machines
Can i hook up my ps3 to a wired internet
Wired Connectivity:
The network configuration and connection depends on the connection method and equipment you have.
Important: A router would be required if you want your PS3 and the computer to be connected to the internet at the same time.
The following are mandatory. You need:
  • An Internet connection
  • A cable modem
  • Ethernet cable. (Available with the PS3)
When you have a wired connection to the Internet, it is not necessary to adjust any of the default settings. (It is done automatically). If you aren't able to connect with the default settings, follow the instructions to adjust the settings.
  1. Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  2. Select "Internet Connection Settings", press the x_button.jpg button.
  3. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  4. Select "Wired Connection", press the x_button.jpg button.
  5. Select Easy or Custom and adjust the settings.
    • If you select Easy, then the basic settings are automatically set.
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your Internet service provider.
Sep 13, 2010 | Sony Playstation 3 (PS3) Console
E30
what this indicate simple mean that there has been an over flow of water into the panel(that is power control ) or there has been a loos of wire from the connection of the panel connected to one of the button .
what you are to do to fix up this problem is to unscrew (open) the washer from the stroll then clean up the the panel very well with out disconnecting any wire from it position or
from the loos of wire trace the wire down to the control button connected to the panel and fix up the loos wire back to is position (on the control button)
please this with care with out any form of this connection on the wires.
thank you.
Aug 02, 2010 | AEG Lavamat 72640 Front Load Washer
WIRING INSTRUCTIONS for MTH gas station A
A) on the gas station gets one wire from the transformer and one to the activation botton off A on gas station ( acc power from transformer )
B) gets ground from the transformer
C ) to activation botton
D ) to Acc power on transformer
E ) ground on transformer
Dec 27, 2009 | Mth Toys
How do i jook up my playstion 3 to the internet via time warner wired connection
1st Step: Setting up the Internet Connection
When making a wired connection to the Internet, you do not need to adjust any of the default settings. If you cannot use the default settings to connect, follow the instructions below to adjust the settings.
  • Select "Network Settings" under "Settings" in the home menu, and then press the X button.
  • Select "Internet Connection Settings", and then press the X button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the X button.
  • Select "Wired Connection", and then press the X button.
  • Select "Easy" or "Custom" and adjust settings as necessary. (Easy is recommended)
  • Follow the on-screen instructions to adjust the required setting.
Easy: Basic settings are set automatically.
Custom: You can manually enter detailed settings information.
Here's a diagram set up to PS3 wired internet connection
You can take a look at the connection diagram here
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
Nee to know how to wire a ceiling fan remote to the ceiling box please. Wires coming from box are: black-hot, bare-ground, and white-?. Wires coming from fan remote unit are: black labeled wire to black in...
Try this, connect green wire to bare wire. Connect both black (power) wires to black wire in the box. Connect the blue wire to the button for the lights, and the red wire with the strip to the button for the fan, and the common for the buttons to the white wire.
Oct 03, 2009 | Hunter 52" Ceiling Fan With Light And...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
