Question about Sony Handycam DCR-HC48 Mini DV Digital Camcorder
DCR HC48 not working on battery
I have a Sony DCR HC48 nowdays it is not working on battery, but when i connect it to direct power supply then it works fine, first it seems to me that battery is bad, when i used the same battery in another camcoder that camcoder works fine on my battery.
So my battery is also fine but it doesn't work when i am using it with my camcoder then it doesn't work and my camcoder works fine with the direct power supply.
Help!!!!!!!!!!!!!!!
  • dk_deepak008 Mar 30, 2009
    I tried to clean the terminal of battery using the dust removal liquid but it didn't help.
    Do let me know any other solution.
    Thanks
    Deepak Kumar
  • dk_deepak008 Aug 05, 2009
    Thanks Guru for your assistance.
    I went to the Sony service center, they told me due to moisture it has stopped working.
    They told me that the problem is in the CPU and repairing the CPU will be costly as well as risky bcos it can also completely stop working.
    Currently it is working fine on direct power not on battery.
    Please suggest me any solution for this moisture so that i can use my camcoder.
    Appreciate your help.....
    Thanks
    Deepak Kumar
    President:
  • 1,223 Answers
See the contacts on the both side are they rusty current is not passing thru the terminal properly try cleaning them with some rust removing liquid on a cloth and then try it
Posted on Feb 23, 2009
  • Shoaib Rais
    Shoaib Rais Mar 30, 2009
    actually u shud look out for the battery volts is it supplying the correct volt ur cam uses are u trying the battery on the same cam model and it works fine bcoz some cameras have different requirement of batt volt than others , otherwise u have to get it checked with Sony centre u cant do anything remotely it is a circuitry issue.
    what ur camera do when u disconnect ur ac and fit ur battery and try to switch on any lights or something or just dead ?
    pls consider updating ur ratings atleast to helpful bcoz they affect us in the mean time i willl tru to find solution for u
    regards
How do I transfer video already on tape in the Sony DCR-HC48 to the memory stick in the same camera?
don't listen the 3 other answers, because i know what you mean, you mean directly from the tape to the memory stick, right ?
it is impossible, the memory stick is only usable for taking pictures, no video, and even, it would have to be recorded directly on it, but it is impossible !
Dec 07, 2014 | Sony Video Cameras
Problem of handycam DCR-HC48 shows error c32 11 tape comp.not closing
The problem is most likely a defective rotary mode switch in the cameras tape mechanism. This can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
May 22, 2011 | Sony Handycam DCR-HC48 Mini DV Digital...
Sony Handycam DCR - HC48 door jamb repair. Cassette door is not closing,
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 27, 2011 | Sony Handycam DCR-HC48 Mini DV Digital...
Hc48 lcd stopped working. touchscreen works but no picture.
Hi, I had the same problem. I had to change the flex wire connecting LCD with camcorder. It's very common cause everytime we open LCD the wire "working and becomefaulty.I change it by myself, got it from the repair shop andit's like new.
Let me know and good luck.
Oct 15, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
I have a Sny dcr-hc48 camcorder which stopped working some time back. this week i had my friend who came with the same camcorder and i swapped in his battery and my camcorder started working. but if i...
First: put your battery in your friends camcorder and use ur friends charger to charge the battery.
Then put your battery back into your camcorder to see if it works.
If the battery works then this eliminates the battery as a problem.
Next plug your charger into your friends camcorder to see if it will power the camcorder without battery, if this works then the problem will most likley be the connector in your camcorder.
If this does not work then the problem will be the plug or the charger.
Next plug your friends charger into your camcorder if it does not work this will verify that the problem is the connector on your camcorder
binary6
Sep 16, 2009 | Sony Video Cameras
My camcorder tape door won't close
Try removing the battery for a few seconds, and then re-inserting. This seems to reset something on my DCR-TRV20, and it starts closing properly.
Jun 15, 2008 | Sony Handycam DCR-HC48 Mini DV Digital...
Drivers!
I THINK SONY WILL LET YOU DOWNLOAD DRIVER FOR FREE AT www.sony.com
Jan 29, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
Sony Handycam  DCR-HC48 Mini DV Digital Camcorder Logo
204 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
