Question about SanDisk Sansa Clip MP3 Player
When I plug my mp3 into my computer it doesn't seem to charge.
  • Anonymous Feb 25, 2009
    My sansa clip seems to not charge. I connect in up to my computer and after leaving to charge when I remove it to play music itis still displaying battery low :(
  • 8,596 Answers
Make sure the hold/lock switch is not engaged.
If that fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 08, 2009
I lost my charger to my mp3, where can I get a new one that doesn't cost much?
You can charge the MP3 player by connecting the USB cable to the MP3 player and then plug it into the USB port of your computer.
Jul 14, 2012 | Coby MP620 MP3 Player
My mp3 doesn't turn on but when i put it on the computer, the mp3 turn on then i unput it turn right away turn off
When you plug it into your computer, press "USB Charge" on your V-Touch. This should charge it while its pluged into your computer.
Feb 21, 2012 | Visual Land V-Touch Digital Media Player
My mp3 isn't turning on even thought it is fully charged but plays music when plugged into USB
There is a Problem with the Mp3 Battery its not Charging get it Replaced!
Dec 29, 2011 | Audio Players & Recorders
I just received a sylvania SMPK8099 MP3 player and I'm trying to figure it all out.. I can't seem to get it to charge the battery. I've followed the instruction but it doesn't seem to be...
Sylvania mp3 player lost your cd here is the softwear for you to download
You can try an overnight charge. If that fails, the usual remedy is to return the device for service under warranty. Failure to accept a charge suggests a bad battery. I find no DIY instructions identifying a change of its battery. As to the driver failure, this is likely a compatibility issue. You have not identified your operating system. The user manual may identify which OS the device is compatible with. Try installing the driver with the device disconnected, reboot, plug in the device, reboot again. I believe the device worked with Windows 7 or XP but am uncertain if it worked with other OS.
Nov 02, 2017 | Computers & Internet
My ipod A1320 freezed and would not respond to anything.
Hi. My ipod nano (a1320) just stopped displaying anything. doesn't seem to charge or respond to plugging into computer.
Any idea what i can do?
Nov 05, 2010 | Apple iPod nano 2nd Generation MP3 Player
Cant charge mp3 player
Make sure the USB cable in all the way in. Also make sure the computer is on so that the MP3 player can be charged.
Sep 14, 2009 | MyMusix PD-6070 MP3 Player
My sansa mp3 player doesn`t seem to charge anymore. what do i do?
My best bet is the cable gone wrong. If you can find a similar cable to purchase from a computer shop or a friend you can try it.
Aug 19, 2009 | Samsung YP-K5 MP3 Player
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
