Question about HP Pavilion dv4000 Notebook
I have a hp dv4000, the problem is my external speakers or headphones are working but the inbuilt speaker(lap speakers) are not working..pls help me.
  • Anonymous Mar 23, 2009
    no sound from both enternal or external speakers
  • lrknmartin27 Apr 13, 2009
    the problem is my external speaker are not working but my head phone are
  • 520 Answers
Check you have the correct drivers for ur sound card
Posted on Mar 05, 2009
How to increase volume aspire 57386969
Generally laptop speakers aren't that loud, plug in an external speaker into the headphone jack for higher volume.
Bottom right of the screen should have a speaker icon to change the volume.
Jun 14, 2014 | HP Pavilion dv4000 Notebook
Hi .i have hp compaq 610 in build speakers not can solve the problem.please help me.
The inbuilt speakers on my laptop do not work. I believe the headphone input socket to be the problem because when i stick my headphones in it only works if i squeeze the laptop near the socket. The input has been quite heavily used so i'm quite certain its broken somehow. Anyway, my layman theorising has led me to the conlcusion that my laptop thinks that headphones are plugged in when they're not and so disables the speaker so maybe if i could disable the headphone input the speakers might work. I'm sorry if this sounds confusing but my computer knowledge is really, really limited. Any help would be massively appreciated. thanks
Jan 02, 2011 | HP Compaq Computer Speakers
My headphone port is not working in my acer aspire5710z laptop. when pin is inserted in the port, still then the inbuilt speakers are playing, not the headphones or external speakers.
Do the following:
Turn off the laptop, unplug power cord and remove the battery.
Put back laptop together, and restart the laptop with headphone jack in. Restart the laptop with headphone in twice.
Third time , while laptop is on, unplug the headphones and restart laptop again.
This will usually fix the headphone problem on Acer laptops.
Sep 10, 2009 | Computers & Internet
I am using hp pavilion dv2214tu, able to hear from inbuilt speakers but when i insert headphones, i can still hear from the inbuilt speakers but not the headphones. PLs help.
The headphone jack contains a small contact that disables the built in speakers and redirect the audio signal to the headphones. If the jack doesn't do this, probably that contact is dirty or the jack itself has a problem to one of the contacts inside it. You could try some electrical contact cleaner (it'a a spray you can buy from any electronic store) but I'm not sure if it will help or solve the problem permanently.
The best solution would be to replace that jack with a new one. It's not an expensive or tricky repair and any service center should be able to do it without many problems.
Hope this helps,
Jul 04, 2009 | HP Compaq Presario V2000 Notebook
Toshiba Satellite Laptop - No sound when connected to earphone
possible solution: go and check your audio properties. the line-out might have been disabled, muted or simply turned down.
May 25, 2009 | Toshiba (4CH-VOUT) Sound Card
HP Compaq 6720s Sound problems!!!!
pls. check the internal speaker audio cable is ok or not. and also check the audio cable is connected on the audio section of motherboard.
Feb 16, 2009 | HP Compaq 6720s Notebook
Inbuilt speaker is not working
u need check u r sound setting click on sound icon on u r taskbar and then click on properties and playback or recording click on microphone and try to scroll lolz try dear
Oct 21, 2008 | Compaq Presario 700 470024-192 Notebook
Can't mute inbuilt speakers
That is not a software problem.
The headphones/external speakers jack socket has a switch to exclude from audio the internal speakers, when a jack plug is connected.
This is a very simple device and is not software controlled.
The fact that it has gone faulty at the same time you reinstalled the system is a coincidence.
If it does not mute when you insert headphones, all you can do is trying to play with the jack plug , inserting and pulling it out. If this does not unlock the switch, the alternative is having the jack socket replaced by a technician. This is generally an expensive repair, asthe socked is soldered on motherboard.
A cheap alternative to a proper repair is using an external USB to Audio Adapter and mute the internal audicard when using headphones.
Oct 19, 2008 | Computers & Internet
Sound Problem
Hi.........i have a compaq presario 700 series.In my laptop if i plugged my headphone into my laptop the lap speakers cant stop working,both laptop and headphone speakers are working
Aug 02, 2008 | Compaq Presario 700 470024-192 Notebook
Built in speakers don't work.i have sound only when i plugg the headphones
Looks like there is some problem with the stereo headphone connector. As its a hardware issue, I would recommend sending it to the service center.
You may also use external speakers temporarily.
Apr 15, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv4000 Notebook Logo
186 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
