Question about Refrigerators
I have an old astor freezer with a slid button with a red line on the right ,where do i put the button for normal working , Not Fast Freeze. Thanks Terry
  • 1 more comment
  • terrence_oma Feb 23, 2009
    The frezzer is so old l can not see or get to modle number.
    There is a switch that slides from left to right on the right side is a red line , 3 lights buttons yellow,green red.
    just like to leave frezzer on its normal running ,not fast frezze..
    Again thanks Terry
    Again thanks Terry
  • terrence_oma Feb 24, 2009
    As to all above l have a switch which is slide from left to write if l have the swith on the right there is a green light comes on and the red line is hidden is this on fast frezze,or is the switch on left or right I do not want fast frezzer on just Normal.
    Again Thanks
    Terry
    Brigadier General:
  • 5,158 Answers
As the fridge is so old.... you will need to rely on trial and error... try it one way and if that is fast freeze move it in the other direction
Robert
Posted on Feb 24, 2009
  • 60 Answers
Welcome and here is your solution, turn the slid button right to the last point. Now that will create normal freezing environment.
Thanks for choosing FixYa.
Posted on Feb 23, 2009
  • 544 Answers
Thank you for choosing Fixya.com..
In your statement you said that the machine are already Old so we need to observed it first.
Just in case any problem may occur we are ready and we can prevent it.
I prefer to suggest you to select normal mode.
  • Mark Milan silaran
    Mark Milan silaran Feb 23, 2009
    Hello their again,
    please observed it for 3-4 weeks any un usual sounds or happening specially in the freezer motor.
    turn it off immediately and ask for the assitance specialist repairman.
    Again to make it sure select the normal mode.
    thanks again and good luck.
    please don't forget to rate our answers properly.
    Hello their again,
    asking the direction where you should be..
    plese turn the switch to the right prompting to the green button don't turn it full just balance it.
    thanks,
  • 495 Answers
Try this link for online repair
online repair
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On some comparable style of temperature adjustment, the further away from the red marking, the colder the setting.
Good luck and thank you for using FixYa.
    Genius:
  • 1,550 Answers
What is you model number initially .
Normal working will always be in middle . It will not not be in neither of extremes .
To give correct solution provide model number .
  • SAM ANDERSON Feb 23, 2009
    For normal settings you need to move from left to right .
    You need to move gently upto a point just before the red line which is the only the settings for normal . The button should be green for normal .
    If you go towards red mark it indicates fast freezing .
    Hope this helps .
Hi I lost my manual to my westpoint tropical chest freezer, and wanted to find out how the fast freezer switch works. Does it mean when i switch it off the freezer goes off? or is it just a switch to help...
Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
Aug 25, 2014 | Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Freezer stuck on fast freeze
i think ,you are right ,friend.
Feb 19, 2013 | Freezers
Well i have a problem the fridge is working 100% but our freezer is not working right it is cold at bottom half but it is not working at top half like i put ice thing in it the water fast freeze tomoro...
If I read the manual right the red light indicator your seeing is the exlamation point above the fast freeze button. This is telling you that the freezer compartment temp is to high.
There can be multiple reasons for this:
1. Evaporator fan not running (Check fan by depressing door closed plunger for the light switch) The fan should be on and light off.
2. An unseen block of ice over the evaporator coils due to an automatic defrosting probelm. If you can determine that there really is ice on the evaporator coils, perform the manual defrost procedures I described in my initial response. If after doing this manual defrost things return to normal for a few days and then you see the high temp indicator again there is for sure and automatic defrosting problem.
3. Automatic Defrost Problem (Causes)
a. Defrost control failure
b. Defrost control heating element failure
c. Temp sensor failure or Bi-metal 60 Deg F thermostat failure
4. Condenser fan not running in the borrom rear of the unit. (Check to see that the fan is running by removing the fiberboard rear cover.)
5. Condenser coils blocked with lint (Check the coils when you inspect the condensor fan for operation.) Clean both the coils and the fan.
6. Thermistor failure (measures temp and has a resistive output) in the freezer.
7. Compressor not running (Causes)
a. PTC relay
b. Run capacitor
c. Conpressor failure
8. Compressor running but not cooling
Check to see that one of the copper lines line is hot to the touch. If it is not hot the causes can be low freon level, clogged freon drier, damaged capillary tube.
These are all the things that can cause your current symptom.
Thanks for choosing FixYa,
Kelly
Mar 20, 2011 | Refrigerators
On the bottom outside of freezer bottom front what is the on and off switch for it located between a red an orange color light
it is the fast freeze button,use it when filling up freezer when less than 1/2 full.red is a high temp warning.orange is fast freeze on/working.
Jun 18, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
WHIRLPOOL UNDER WORKTOP FREEZER APPROX 11 YEARS OLD BEEPING
the temperature control is bad. when you push the fast freeze it bypasses the thermostat for 12-24 hours depending on which model you have. I am not able to find any parts information with the model number provided but you should be able to find a temperature control at any local appliance parts house or online thru any reputable supplier. Thnaks Peyton
Feb 24, 2009 | Whirlpool Freezers
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
Feb 11, 2009 | Magic Chef 5 cu. ft. / 142 liter Chest...
Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
Jan 21, 2008 | Freezers
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
