Humidifiers
Problem for Humidifiers
Generic problem for all Humidifiers
Aprilaire 440 won't stop running
By hey_you_at on Feb 23, 2009
I noticed that we have no hot water and there is a contant flow of water exiting from a PVC pipe coming from the humidifier into the sump pit. I tried adjusting the setting on the humidistat and even turned it to off and the water just keeps flowing. It did stop when I turned the saddle valve all the way off for a little while, but then I won't get any humidity and it is very dry. It is Feb. in Chicago and it's been around 20 degrees and going to be hitting 30. I had the humidity set at 25, and just changed it to 35. I do not want to shut it off, but I do not want the water, hot water heater and sump pump running constantly and I do not want to always be out of hot water.
Same Problem
Mar 29, 2009
-   I have an Aprilaire whole house humidifier and even though I turned the humidifier totally off, the water from the humidifier just runs and runs. We shut off the water valve completely to solve the problem temporarily.-   sauters88
Solution #1
posted on Mar 08, 2009
Not Rated)
hvac teacher
Rank: Guru
Rating: 91%, 51 votes
Disconnect the two low voltage wirings going into the solenoid valve. If the water does not stop running after a few minutes the valve is bad. When you check your local area to price a new valve. Also get a price for a new humidifier. You will be surprised to find that a whole new unit isn't that much more. Or should I say that you will find that the replacement parts are overpriced.
Good Luck
HVAC Teacher
Was this helpful?
Yes
No
Popular Solutions for Humidifiers
Questions and Unsolved Problems for Humidifiers
Answer
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find... (More)
Answer
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of... (More)
Answer
Refill/reset light is on while the water tank is full. What do I do?Unit is not operating.
Answer
Will Super Wick Model #1045 work on my Bemis 497-300? The filter box says it is for Bemis &... (More)
Answer
water valve stays on all time 2001 model
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Humidifiers:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 2528
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
