Question about Philips 43PP9202 43" Rear Projection Television
Philips Rear projectoion tv picture not clear
A friend gave me a Phillips rear projection tvname on the front states: Match 111 Line.on the back it has: 43PP8420/79 (hope this helps
It worked fine at his house but when it arrived at my place the picture is not clear.
Someone said that you should not tilt them on their back when transporting. They need to stay upright.We did tilt on its back to transport.
Is this true? and if so how do I fix the problem and at what cost?
No its not true, you can lay them flat to move, it sounds like the convergence is out of whack, download the owners manual and redo the convergence manually for the red and blue, then go back and do the same for the multi point convergence for the red and blue, also if the color looks muted or flat, the projector lenses might need to be cleaned as well as the mirror in side of the unit.... very easy to do, just use caution and DO NOT SPRAY ANY LIQUIDS INSIDE THE UNIT.... spray the cleaning rag outside the unit the wipe off the mirror and lenses....i got this same TV free from craigs list here in pa, put a new mirror in because the original was shattered and re did the convergence and this TV pic is AWSOME.... very crisp and clear...hope this helps you
Posted on Apr 13, 2009
Well hear goes, I have a Philips 60pp9363 60"
Coolant Fluid is a common Problem ,most of the time it will be the Green and Blue Coolant Fuild that becomes dirty and comtainated
With TV on. Look down into each Tube If it is not clear then change the coolant fuild .
Mats Electronics has Coolant Fuild 1-800-628-1118
Oct 29, 2010 | Philips 60PP9363 60" Rear Projection...
HAVE PHILLIPS 60 INCH 5 YRS OLD GREAT PICTURE NO
Hi, check for any speaker switches around rear of set that may have been accidentally switched. Could potentially have a "hotel lock mode"
which some philips sets automatically entered after a set time (namely months) which limited volume settings. Your friendly local service technician may be able to help you out with that one
Mar 19, 2010 | Philips 60P8341 60" Rear Projection...
How to make the picture to a Philips 2002 rear projectiontv clear
needs to replace the liquid in the tubes of blue and green projection
Jan 06, 2010 | Philips 55PW9363 55" Rear Projection...
I have a phillips magnovox 9p6031 c103 rear projection tv. At first the screen would shrink and have an orange look, when I would go through the convergence re-set it would clear up, now the tv makes a...
This problems is the cause of 2 Convergence is dead also.Know how to solders?Buy a convegence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Nov 29, 2009 | Philips 46PP9302 46" Rear Projection...
Doesnt turn on and beeps, philips match line rear
i believe it takes a couple minutes for the pamp 2 warm up and the start
Aug 22, 2009 | Televison & Video
Picture is clear but with a yellow tint .
Make sure, if your using component cables ,that they match up color for color and are plugged in.If it looks good try adjusting your colors on the TV.You can also try unplugging the TV for 5 min. and then plug it back in.This might be a TV issue.
Jul 07, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Unknown AutoLock on my Philips rear projection tv
If you look on the rear of the set and locate the chassis number can probably assist you. But I will need the chassis number for RCA & Phillips/magnavox.
Feb 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
60" Projection - Screen shrinks down then back up
I had the exact same problem. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
Jan 19, 2008 | Philips Magnavox 55P9271 55" Rear...
Philips 43PP9202 43" Rear Projection Television Logo
410 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
