Question about Dell Inspiron 1501 Notebook
Disk drive e
I have my dell inspiron 1501 i normally used my drive e to burn music and files but recently it cant read cd's anymore please help me i have lots of things to do:-)
  • Monette Quevedo
    Monette Quevedo Feb 23, 2009
    what is an ede cable?
  • Monette Quevedo
    i dont know if i have the IDE cable...im so sad...how can i burn files now?any recommendation...please please .....its a big help... im still trying to insert cd's but still it says that "please insert disk" so it means there must be something wrong....
I also had the same problem what i did personally was .
click on set programs and access defaults from start menu,then click on add and remove button and it was in custom and click on microsoft windows and hit ok.it solved my problem.u can try this.
or sometimes it might be bad disk..most of the time is because of the bad disk too..hope this helps .
Posted on May 13, 2009
  • 60 Answers
Clean the lens with a cleaning disc or open the burner and clean manually with a soft cloth. Check the IDE cable, if possible replace it. If these procedure did not solve, replace the burner with a new one.
keep posting.
Posted on Feb 23, 2009
  • Prosun Pal
    Prosun Pal Feb 23, 2009
    IDE cable is the cable that connects hard disk to motherboard.
I have a Dell Inspiron E1405 laptop computer. I recently noticed that when I inserted a music CD into the drive, that it would not play or even recognize it in the My Computer window. I can still play DVDs...
The Cd player my be dirty, you can get disks you put in there to clean them. Also sometimes the players are just picky and don't like certain CD's..... I'll build brand new PC's that only read some CD right from the start.
Make sure your disks are clean to, with no fingerprints.
Dec 22, 2010 | Dell Inspiron E1405 Notebook
Hi. Problem with Dell Inspiron 1501 Model No PP23LA. I blundered into using the Operating reinstallation dvd & ended up deleting all partitions & installing XP media centre edition all over again,...
NO....
disk supplied by Dell will only help you restore in an emergency....that too if your system is enabled the restore option...before your blunder....
i suggest you re-do the full PC as per my adivse....
first u must make a backup of your critical data if u have any on ur pc on DVD disks....DONT use pendrive...
since ur laptop is in working condition u can do the following in this laptop itself....else u may have to use another PC....
1st go to my shared drive (link below) and download this application....
http://www.4shared.com/file/gTU7Zdj3/boot-cd-iso.html
this is a rar file, unzip this file with winrar....the folder that winzip will create will have a self burn software called "ISO-Burner"
insert a blank CD in the drive (i guess ur laptop has a CD/DVD writer) else u will need another PC to write a CD....
click on the ISO-Burner, it's a self create burn application...it will create a bootable CD with the needed applications....
to wipe ur disk....clean...
.... u must ensure that the CD drive is the 1st boot drive in BIOS ( i guess u know how to do it)
keep the boot cd in the CD drive...switch off and switch on again...and let it boot from the CD....wait...wait...
it will boot and load an application that will have some tools to make the disk factory fit....
select application KILLDISK...on the left panel...select F10 to wipe your disk clean....type in ..."erase-my-data"....and wait...wait...
the process will take aprox 5 hrs for a 100 gb disk....wait and have patience....so if you HD is 200 gb it will be more than 11 hrs to finish....
once done you can replace the cd with the WinXP disk, make partitions, format and create different drives as per you needs and make you machine as good as new...
for more info on how to format and use WinXP pls visit my site
www.sureshayyar.110mb.com
pls revert back and leave a feedback and rating for the solution....it will help me become a "Guru" here on Fixya....
all the best
regards....
Sep 29, 2010 | Dell Inspiron 1501 Notebook
My dell laptop inspiron 1501 not burning or reading cds
Please try with any bootable disk,if the system is not booting with the disk then the issue is with the ODD and it needs to be replaced(be sure that first boot device is cdrom in BIOS).
If booting then go to device manager and uninstall the cd/dvdROM drive and secondary IDE controllers and restart the system twice and check.
If fails then lens went bad and CD ROm drive needs to be replaced.
Dec 09, 2009 | Dell Inspiron 1501 Notebook
Just bought an Ematic 1.5%22 Color 4GB MP3/4 Video Player and the driver disk it came with about 3'' wide much smaller than a std cd so i cant use it. where can i get the driver and anything else to make...
You should be able to use the small diameter disk. The disk can be inserted in the CD/DVD drive just like a normal size CD/DVD disk, it locks onto the spindle on the laptop's CD/DVD drive. The laser reads from the center of the disk.
Oct 16, 2009 | Dell Inspiron 1501 Notebook
I have a Dell Inspiron 2200 Notebook computer. I
This might be as a result of CDROM Drive speed.
Generally the spin speed of CDROM Drives are always different, and there are some desktop CDROM drives that have Spin Speed as High as 60X...yes, because I have used one before. What in this case, I would suggest you do this, : Provided the Notebook CDROM Drive can read other disks, then just try and use your desktop to burn the CD disk onto another CD Disk, then try the newly burnt disk on your laptop.
And if you have an external drive, you can just copy the CD contents using a NERO burner software or any other CD Burning software, and transfer it to your laptop.
Hope this help you out.
Jul 10, 2009 | Computers & Internet
I have my dell inspiron 1501 i normally used my drive e to burn music and files but recently it cant read cd's anymore please help me i have lots of things to do:-) it says there that " please insert cd on...
I had the same issue and finally - after coming across your question via google- got frustrated enough to start clicking thingsand hoping for the best. Lo! After six months of my Inspirion sticking a loaded disc drive at me like a two year old would their tongue, I have solved the problem somehow.
I don't know what the hell I'm doing with computers, never taken a class; but like any tool or living thing, sometimes things just want attention and will act up to get it. Here's how I convinced it to work:
By disabling the DVD-ROM device, resetting the system, and re-enabling said device, I successfully solved the problem. In case you aren't 100% sure how to go about that, I have supplied a step-by-step guide which I wrote as if it were for my father - a proud caveman.
1.) From your Computer folder, right click drive E: and select properties.
2.) Enter the 'Hardware' tab, highlight the Sony CDRWDVD device (I'm assuming we have the same software), or whatever appears to be your actual DVDROM reader.
3.) Hit the 'Properties' button near the bottom of the window, enter the 'Driver' tab on the next pop-up.
4.) Find your 'Disable' button and push it with no fear in your heart.
5.) Close out of both pop-ups, and Vista will present you with the option to Restart your laptop.
6.) Say yes, and get something to drink while you wait.
7.) Enjoy your drink.
8.) Now that the system has restarted, return to your Computer folder. You will notice that Drive E: is absent.
9.) Trust me.
10.) Right-click anywhere on the folder besides on an icon and select properties. This will take you to Control Panel > System & Maintenance > System
11.) So long as you're with me still, you will see a list of options on the right side of the window. Select 'Device Manager.'
12.) Find the DVD/CD-ROM Devices icon, click the plus sign to expand. Find the device which you previously disabled (again, mine is SONY CDRWDVD CRX880A ATA DEVICE), right click, and select 'Enable'.
13.) Is an unlucky number to finish on.
14.) You're back in business!
As with anything in computers, there are thousand ways to do the same thing, so I have merely opted to write this list in precisely the order I did things. If it doesn't work, feel free to contact me @ DigitalGrampa@Gmail.com with any sort of abuse.
Feb 23, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron
check the possible drivers
check the software, including the cd part of operating system
get the cleaning cd and clean the laser
Dell Inspiron 530 DVD Burner Issue
i have a dell inspiron 530 and i have a slideshow movie business that i operate from my pc i have nothing special other than what came with computer!! anyone that needs help with burning i can help. i am on kudzu.com under memories my name is george
Apr 06, 2008 | Computers & Internet
My dell inspiron 1501
is it vista or xp? if its xp u need to restore to prior day of you instlaling soem cheesy cdburn app. cd burning apps .. some install a specfial driver/filter and messes with it. sonic isone of them from dell. call dell if u have to 1-800-822-8965
Nov 05, 2007 | Computers & Internet
Dell Inspiron 1501 Notebook Logo
35 people viewed this question
Alun Cox
