Question about Akai LCT2662 Television
AKAI LCT3201AD television Most days i have to unplug and replug the tv after several minutes befor it will turn on. If i dont do this then the tv will not operate, the green lite will come on and then the red lite comes on and the tv stays off.
    President:
  • 196 Answers
Check cap near relay and blows cap around
Posted on Apr 23, 2010
    Problem Solver:
  • 8 Answers
Master Power Relay issues. Seen it to often on many of my cable customer on this brand. Check warranty.
Posted on Feb 23, 2009
My akai lct3201ad tv volume just stays at 100 cant turn down or mute or source to change tv to channel 3 what can i do to fix this problem?
replace the main board. You can get the replacement main board from www.tvcircuitboards most likley if they dont have it listed I would send a email as they only list boards that they have more than one of single boards are not always listed.
Jan 02, 2013 | Akai LCT3201AD 32 in. LCD Television
Akai tv/dvd combo LCT3201ad 32" auto-shutoff or turns off after 3-5 seconds after being turned on.
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT3201AD 32 in. LCD Television
Akai 32" wide screen lcd tv/dvd combo LCT3201AD
This may be an instance were the idea was great but the execution wasn't thought out. I've heard of several related problems that may be related. Both the TV and the DVD player tend to produce heat, not in great abundance, but together a sizable amount of heat. The power supply may have been ample for the TV at first but with the addition of the DVD player was not able to handle the extra load. If still under warranty you're all set. If not you might call Akai and see what they might be able to do for you.
Sep 29, 2011 | Akai LCT3201AD 32 in. LCD Television
(Please Help)Need to unplug my TV everytime to turn it on
you have a bad power supply, here is the part number
MLT169B
google it or try to get here :>
http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=MLT169B
Fosg2000, Rate me Please
Mar 15, 2010 | Akai LCT4216 42 in. LCD Television
Tv won't turn on
Although not a great solutin it does allow me to use my fairly new and expensive LCD TV. Heres what I do, UNPLUG THE TV FOR 20 -30 MINUTES, WHEN PLUGGED BACK IN YOU NEED TO VERY QUICKLY PUSH THE POWER BUTTON ON THE TV.
Let e know if this works fo you.
Mar 27, 2009 | Akai LCT3201AD 32 in. LCD Television
MY AKAI LCT3201AD TURNS OFF BY ITSELF
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Jan 10, 2009 | Akai LCT3201AD 32 in. LCD Television
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Nov 14, 2007 | Akai LCT3201AD 32 in. LCD Television
Won't turn on now
ftry to unplug it and push the on/off switch...plug it back in and see if it will turn on
Sep 09, 2007 | Akai LCT3201AD 32 in. LCD Television
See my other support issue regarding a simillar problem: http://www.fixya.com/support/t155367-red_line Since this is a row of dead pixels and the TV is under warranty, you need to either contact the manufacturer or even exchange it at the retailer you purchased it from.
Jun 22, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai LCT2662 Television Logo
141 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
