Question about HP PSC 1610 All-In-One InkJet Printer
Hp inkjet printers gears the same?
Would like to ask if all printer gear assembly found on hp inkjet printers
would work if you try to inter change them?
I'm looking to replace a broken gear assembly on a broken printer
to a working printer with a broken gear assmebly causing it to
have a paper jam when printing.
  • 50 Answers
NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO
Posted on Jul 12, 2010
    Scholar:
  • 96 Answers
Definitely not!
Posted on Sep 09, 2009
    Problem Solver:
  • 6 Answers
No it would not . however if you are trying to use it from a similar model, it may work.
Posted on Aug 28, 2009
Why does it make a grinding noise while printing?
If you have an older LaserJet, overhaul parts/kits may not be available. You may have to check on the HP website to determine availability/
Mar 07, 2013 | HP LaserJet M5025 MFP Printer
Printer error 21.1:03 what i di?
Service station Motor not working or not rotating
Take out carriage assembly from serve station area.(Power on printer wait till service station un lock carriage, switch off main power, take out carriage assembly from service station. If service station not releasing the carriage assembly, my sincere advise "call for service personnel")
Remove right cover,check service station motor connector,connectivity cables,if no damage found,remove service station, check any paper particles jammed inside?any obstructions?any gear damage?.. shoot the problem, other wise replace service station..
This activity is advisable for the service personnel only.
Sep 01, 2012 | HP Designjet T1300 Inkjet Large Format...
Drum motor noise
Need to open the entire printer, don't feelbad if you are capable you start to open other pl don't open it,its major issue..While printing main motor driving entire printer except fuser assm, entire printer load on Main motor assembly, in main motor assembly contains motor and gears, pl see the marked gear in snap I experienced this gear found warn out, this is suits hplj 5200 main motor gear, you can choose this gear and its easily available.. replace this gear, but opening the printer is difficulty.. thanks..
Feb 04, 2012 | HP® LaserJet M5035 MFP Laser...
The printer makes a grinding/squeaking sound when printing. The sound seems to be coming from the top rollers at the back of the printer.
This sound possibilly from top of the right side, open right cover refix the deplex drive gear set if not presists, inter change the duplex drive gears(these two similar gears drives white & black gears easily locatable).....
Sep 06, 2011 | HP LaserJet P2015dn Printer
Operation stop after one use. All you heard is a continuous shutter sounds found on the scanner or photostat copy section. How can isolate this kind of trouble?
This is already a possible hardware issue.
If its making unexpected or noisy sounds while operating gears inside of it is causing the issue.You cannot fix it unless you change gears inside of it which is very mechanical and only the manufacturer can do.
Try calling Hp support 18004746836 because for this type of issues they can enroll you to their loyalty program where you can upgrade your printer to newer version.Take advantage of it!
Hope I help you a bit
Thanks
Mar 28, 2011 | HP OfficeJet 6110 All-In-One InkJet...
HP 8500 Drive clutch gear is broken. Gives "paper jam"message. Can the gear be replaced? Thanks Roger
Yes, I printed a gear made from stronger plastic and it works great! Let me know if you want one. Not sure what to charge yet....
Mar 01, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Orange light on drum. drum making a loud hammering sound when printer is put on or attempting to print.
Sounds like a broken drum drive gear. Try another known good drum assembly first. Parts can be googled and found. But, difficult for end user to replace. You have to remove all covers and fuser asm. Then gear housing from the left side to change the drum drive gear.
Dec 30, 2009 | Brother HL 1440 Laser Printer
HP PSC 1610 Jams 1/2 way everytime now
the gears of the paper feeder tray are worn out or got cracked.it needs to be changed.the assembly of six gear set will cost u near to $30 .
Nov 23, 2008 | HP PSC 1610 All-In-One InkJet Printer
My printer the gear the drum its crash
hi,
your printer is having a problem on a cluster gear assembly.try to drop it on a service center to replace that defective parts...
Oct 14, 2008 | HP LaserJet 1320 Printer
HP PSC 1610 All-In-One InkJet Printer Logo
66 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
