Question about Acer Computers & Internet
When power of batery finish, My laptop swich off without any information.
    Problem Solver:
  • 15 Answers
All laptops are like that.That's usual.No problems detected...
Posted on Feb 23, 2009
How do i fix the swich of my vector light batery gets charging but the on and off swich do not works
Self help isle at your local auto parts store should have something close. You may have to remove the switch and take it with you to compare.
Dec 27, 2012 | Camping, Backpacking & Hiking
Charging problem
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue ( Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
Nov 03, 2012 | Acer Travelmate Series 5330 5520 5535 5730...
Heather blower fan is not working on the dash swich but the swich got power i bypass it at the moter on a regular on and off swich to the batery
The blower motor is drawing to much power and has blown the resistor. As the motor build up too much resistance it will do that. That is due to the motor brushes and bearing failure. The impeller should turn freely. Sure it will work with direct power, but you do have a faulty motor. You need to replace the resistor and the motor at the same time to return it to normal operation.
Sep 29, 2011 | 1997 Isuzu Rodeo
My laptop was shut down, then when I was start it again it doesnt work anymore...What should I do?..please help me, aside from this those keyboards does not functioning correctly in their corresponding...
First thing you do to power your laptop on again try removing the battery and the charger complitly leave it for 10 sec without power then press the on off switch for 2 or 3 times without puting the power or batery later try not to put the battery and put only the power adapter and start your laptop dose it starts if yes good shut it down and put the batery in and start the laptop if its starting and leave it running for cuppul of hours and then again remove the power adapter and let it run the system with batery power if it stays on and fine you are ok and fine there was just a power dump but if it fails in any case like fails to boot with power adapter and so you have adapter issue need to be checked if dosent work with batery it self its a batery issue and needs replacement .
regarding the keyboard issue you can open the kay board and clean it with contact spray if posible.
Dec 12, 2010 | LG NB E500-JAP51A Notebook
My hp pavillion dv7 1130us laptop will not turn on at all was working fine then stopes charging and then when batery went dead that was it I have no power at all now with or without the batery in
press and hold the Power button for 60 secs without the battery and power cable and then reconnect to it back and try to restart and if nb turns on then log on to and download the latest bios and install it as Administrator.
Aug 06, 2010 | HP Pavilion dv7-1130us laptop
MPC Transport X1000. After replacing the dc jack I am now prompted for a password whenever I power on my laptop. I have removed both batteries that plug into the motherboard and all power and nothing has...
try to find a small batery inside netbook you find-it behind keybord or nerby cpu. you disconnect baterry about 10min. ALL THIS PROCEDURE WITHOUT BATERY AND MAIN CHANGER.
Note: All user bios config, are reset. You must config again.
Nov 01, 2009 | MPC Computers TransPort X1000 Notebook
Brand new dell inspiron 1545 says it is the wrong charger but it is the wright one battery will not charge but will run from ac adaptor
take another adapter , same type you have it and prove is working or not?
if yes meaning that output current in your adapter is wrong it is defektive , and change, if even second adapter is making same thing try to get another model adpter that is close in power and curent ratin with yours or same, if isnt working this too try another batery because maybe is finished, if even new batery dont work with your adapter or a second adapter you have to service your laptop inside in electric circuit entering is blown out.
Apr 04, 2009 | Dell Dimension 8400 power supply ** FREE...
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
