Question about Microsoft Computers & Internet
About hyperbola transverse axis on the y-axis, slope of asymptote numerically equal to nine-tenths of the conjugate axis,one vertex at (0,-9).
2 Suggested Answers
  • 8016 Answers
SOURCE: find the equation of the
I am not quite sure how the major axis of your hyperbola is directed and i do not know if the lengths you give are measures of the major and minor axes or the measures of the semi-major and semi-minor axes. So I am giving you the equations and the graphs so that you can decide for yourself what is appropriate for your problem.
Major axis parallel to the X-axis
Equation and graph
Center is at x=1 and y=-2, semi-major axis length is a=6, and semi-minor axis length is b=12
Major axis is parallel to the y-axis
Equation
Center is at x=1 and y=-2, semi-major axis length is a=12, and semi-minor axis length is b=6.
I trust you can customize the equations to fit your need.
Posted on Mar 26, 2011
Nolan plots a point at 0, 3 on the y-axis. He uses a slope of 2 to graph another point. He draws a line through the two points. Which equation represents Nolan’s line?
Y = 2x + 3
.... but you should do your own homework Valentina. You won't be able to take me to work with you when you get a job.
Dec 06, 2017 | The Office Equipment & Supplies
The equation of the straight line PQ is 3-2kx+k+1=12,calculate,in each case,the numerical value of k if the line PQ is parrallel to the line y=4x+7;is perpendicular to the line y=4x+7;
that sounds like a problem about "slopes" so I am looking at using the derivative, which is basically the slope of the graph.
- the equation of line PQ can be simplified to y(x) = -2kx + k -8
- derivative relative to X (k is a constant) gives you -2k
- derivative of y(x) = 4x + 7 relative to x gives you 4
if the lines are parallel then the slopes are equal:
-2k=4 gives you k = -2 => your function becomes y = 4x - 8
if the lines are perpendicular the two slopes multiplied together give you -1:
-2k * 4 = -1 gives you k=1/8 => function becomes y = -1/4x - 7/8 or in other words y = -(2x+7)/8
I have made graphic representation and it looks to be correct.
I hope it makes sense.
Apr 12, 2017 | Homework
Whats the answer to y=(x+2)^2 using a new equation in vertical form a transfer right 4 unit up 2 unit and reflect on x axis
Let's start with the original equation. It is in the form y=a(x-h)^2+k, where (h,k) is the vertex. In this case, h= - 2 and k= 0. Thus, is it y=x^2 and we have done a horizontal translation 2 units to the left. I assume we are going to translate this 4 units to the right, then 2 units up, and then reflect it in the x-axis. Before we do the reflection, we will be 2 units to the right and 2 units up. This equation would be y=(x-2)^2+2. If we reflect this in the x-axis, would we get a downward facing parabola y=-(x-2)^2 -2?
Good luck,
Paul
Dec 06, 2015 | Office Equipment & Supplies
How i can solve quadratic equations which have no real roots
If the quadratic equation has no roots, you cannot find the roots. The discriminate is negative, so if we attempt to use the quadratic equation, we get no roots.
For example, y=x^2 +0x + 3
a=1, b=0, c=3
(-b+/- sqrt(b^2 -4ac))/2a
Substituting in the numbers, we get
x= (-0 +/-sqrt(0^2 - 4(1)3))/2
x= (0 +/- sqrt (-12))/2
We cannot do the square root of -12. Therefore, there are no roots. This is the same as having no x-intercepts. The discriminant is b^2-4ac. In this case it is -12. Thus, there are no real roots.
However, you can still determine the maximum or minimum, the vertex, the axis of symmetry, the y-intercept and the stretch/compression. With this information you can graph the equation.
In this case, the y-intercept is 3, the vertex is at (0,3), the axis of symmetry is x=0, the minimum value of the function is 3.
Good luck.
Let me know if you have any questions.
Paul
Nov 04, 2015 | Casio FX991ES Scientific Calculator
How do I find a slope then describe what it means in terms of the rate of change of the dependent variable per unit of the change in the independent variable.
Slope is defined in many ways. Some use rise over run. y over x. delta y over delta x. I find the easiest way to find it is to draw a triangle to calculate the slope. I try and pick points on the line that go through the corners of the graph paper to more accurately measure the slope. The bigger the triangle the better. Now count the number of squares going up and down and the number of square going left to right. Divide the change in y by the change in x. This is your slope. If the line is going up to the right. the slope is positive. If it is going up to the left, the slope is negative.
"describe what it means in terms of the rate of change of the dependent variable per unit of the change in the independent variable."
If the y axis is distance and the x axis is time, the slope will be kilometers/hour, or speed, the rate of change.
Good luck.
Paul
Feb 24, 2015 | Office Equipment & Supplies
Y=-3/4x+13
Assuming we're dealing with the straight line y=(-3/4)x+13. the y intercept is 13.
If we're really dealing with the hyperbola y=-3/4x+13 then there is no y intercept since there's a vertical asymptote at x=0.
Mar 20, 2014 | Computers & Internet
What is the axis of symmetry of the function f(x) = x2 + 10x?
It is the vertical line that passes through the vertex of the parabola y=x^2+10x
You can graph the function or use differential calculus to find position of the minimum.
The vertex is at (-5,-25) and the axis of symmetry is the line x=-5.
Dec 19, 2013 | Office Equipment & Supplies
Can i ask how to answer this?2x-4y-9=o
That is an equation describing a straight line. The "slope-intercept" form of a line is
y = mx + b
where m is the slope (change in y-value / change in x-value)
and b is the y-intercept (the point where the line crosses the y-axis when x=0)
Positive slope means the line is rising and negative slope means it's falling.
You can rewrite the original equation 2x - 4y -9 = 0 in slope-intercept form:
y = (1/2)x - (9/4)
So you know the slope is positive 1/2 (line rises 1 y-unit for each 2 x-unit change) and crosses the y-axis at -9/4. With this information you can graph the line.
Jul 12, 2011 | Sewing Machines
Find the equation of the hyperbola which satisfies the given equation center(1,-2) transverse axis to the x-axis transverse 6 and conjugate axis 12
Equation and graph
Equation
Mar 24, 2011 | Office Equipment & Supplies
Computers & Internet Logo
108 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
