Question about Lexmark X1240 All-In-One InkJet Printer
No color on printer paper
I got my printer to work but when it prints there is no color. help me fix
  • 50 Answers
In the printer settings under preferences check to make sure black and white only is not selected
Posted on Feb 28, 2009
How to fix CM2320 MFP PAPER JAM
if you don't find nothing inside printer and you are SURE there is no paper inside machine try to clean or replace pickup roller, if you wanna be sure about that try to print from Try1, if it work the problem is in try 2
Aug 28, 2014 | HP Laserjet CM2320nf All-In-One Color...
Colors and photos do not look right when printing on glossy paper using the HP Z6100PS large format printer. With photos on glossy paper, the ink seems to reflect off the paper, making the photos have a...
Hi
Did you try to calibrate on the same media what you want to print?
Try to delete any other calibrations stored. And re-calibrate the plotter on the same media or a plain paper.
DO RATE MY SOLUTION
Jul 07, 2011 | HP Designjet Z6100 InkJet Printer
Printer won't print B&W even though black cartridge is full but 2 colours are empty.
Although you are only trying to print a B & W picture, the color print cartridge/cartridges must also contain ink in order for the printer to work. All print cartridges must contain ink for printing of any type to take place.
Load the color print cartridges and the B & W picture will print.
If you were trying to print a color picture and the B & W cartridge was empty, the printer also, would not print.
I hope this helps you out.
Good Luck
Jan 25, 2011 | Office Equipment & Supplies
Blurry, Ink Smeared pages
If the media (glossy paper) is designed for an ink jet printer you should be fine.
Ink has to be able to be absorbed into the fibers of the page. If you are using paper for a laser color printer, that's your problem.
Don
Jun 19, 2009 | Ricoh Aficio CL7300 DT2 Laser Printer
I have an HP 6180 that works fine except the colors are WAY off -- everything is muted and dull and the blacks are very weak. I've tried everything in the print dialogue box -- switching to application...
Bugger! HP wants your printer to work, so you buy more ink! Mine works beautiful
Scan a good photo and print it out or insert SD card and print photo on PHOTO paper GLOSSY SIDE DOWN Inkypete
Apr 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink Color Issues
Did you change any of the configurations on your printer. Most photo printers have color settings that are media dependent. It sounds like you might have it set to print on regular paper but not on photo paper. There are a lot of settings that you can accidentally change on a printer so I would suggest uninstalling the printer then reinstalling it and see if that is the issue.
Sep 11, 2008 | HP Photosmart 3210 Printer
Blue smudging down left side of the paper and paper turning greyish color
check the fixing unit if the adjustment for envelop is activated or not the same. set to normal.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
Won't Print Color
Check and make sure the box for Print all in black; has not been selected for your printer. Make sure the ink cartridge nozzles are not clogged and that the ink cartridge has been aligned correctly. Hope this helps.
Jul 02, 2008 | Lexmark X6170 All-In-One InkJet Printer
Epson Stylus r320 photo
Hello Ed,
I believe I can help. I happen to have the same printer. My printer was unused for about a month and I could not get the black to print. What happens with these ink jet printers is that the ink drys out and becomes clogged in the print head and other jets. The spray orifices are extremely tiny.
I have a unique method of handling these problems that "usually" works. Here's what you can try.....
1), Get a paper towel
2). Set the ink cartridge to the setting where you remove the ink cartridges and can slide the print assembly back and forth.
3). remove ALL the ink cartridges
4). Fold the paper towel into a rectangle that is 1 inch wide and about 4 inches long) it should be like a fat pillow.
5). saturate the paper towel with clean water.
6). Position the saturated paper towel underneath the print head so that it is pressing against the bottom side of the print head where the ink would spray out on the paper. (It is crucial to get the damp paper towel into contact with the print jet's lower discharge surface. Make especially sure you get it under the clogged (non functioning color position).
7). allow this to set overnight.
8). The next day, remove the paper towel. Whatever color was giving you trouble printing, you should see that color ink in the paper towel. This is because the dampness has loosened the dried up ink. You may also see other colors too.
9). Re-install your ink cartridges and try it again (you may have to do 1 clean cycle but often it isn't even necessary.
This has worked like a charm for me over and over again. No guarantee it will solve your particular problem but it's easy and worth a shot and has returned my R320 to perfect service after sitting for long periods. (You can also leave a moist paper towel under the heads when not in use to prevent clogging). But IMPORTANT...if you don't remove the ink cartridges, the paper towel may pull all the ink out..
Jolly Chollie
Dec 15, 2007 | Epson Stylus Photo R320 InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
