Question about Danze D500540BNT Brushed Nickel Fairmont?? Single Handle Pressure Balance
Danze D500540BNT Brushed Nickel single handle leaks
When i turn on the water in my shower, it pours into my basement, turn off the shower handle, no water, do i need to replace the whole kit i just bought less than a week ago, and chalk it up to a faulty shower tap?
  • 2 more comments
  • fentie276 Feb 23, 2009
    shower head was leaking, we changed and replaced copper pipe to shower arm, that was replaced too, water stopped leaking from the elbow, but it is still pouring into the basement when i turn on the shower tap
  • albert getty
    albert getty May 11, 2010
    no umproper installtion you have a leak at faucet or to shower head plumbing tape or bad sauder
  • Anonymous Mar 14, 2014
    Danze single handle shower makes a loud vibrating noise when shower is turned on
  • Anonymous Mar 15, 2014
    Loud shrieking noise when shower. Is turned on.
  • 547 Answers
Only when its on? it can only be from 3 places the the plumbing up to shower head or the tub spout or crack in fixture make a hole in the wall behind fixture easier then replaceing tile if you can turn on and see where the water is coming from you need to open anyways thank you for useing fixya please rate me
Posted on Feb 23, 2009
Leaky danze shower faucet
you need to go to lowes or your nearest plumbing supply store and get a new cartridge and replace...you may also just be able to replace springs and seats if its like a delta...i believe danze is made by delta...ask them for help and they will advise you on parts...good luck...remember to shut water off to home before doing this repair...
Oct 17, 2012 | Danze D500511BN Brushed Nickel Melrose??...
I have water coming up through the centre,under handle,only when turned on
Hi
This sounds like there is dirt under the cartridge you would need to turn the water off and take the cartridge out and clean the valve as well. this should stop the water coming through
Mar 14, 2010 | Danze D500540BNT Brushed Nickel Fairmont??...
Water leaking around base
Make sure aerator is tight and check cartridge under the handle
Oct 29, 2009 | Danze & Antioch™ Single Handle...
Danze pressure balance single handle shower faucet (D500558BN) pipes vibrate when adjusting hot and cold water.
it the valve is full of dirt or needs to replaced not all the time but i have fix many buy just cleaning it out or pipes are fasten down. try just cleaning.
Jun 10, 2009 | Danze D500558BN Parma Shower w/ 4"...
Shower valve leaking
here is the link to the pdf file http://www.plumbersurplus.com/pdf/07606.pdf
If you cant get directly to it from the above link, go to plumbersurplus.com/prod/danze-D51001BNT then click on "documents"
Apr 04, 2009 | Danze D510011BNT Brushed Nickel Melrose??...
Danze shower fixture issue
If it is a single handle there should be an access hole to the under side of the handle that will allow access to a allen style set screw, loosen it and the handle can be removed.
Feb 21, 2009 | Danze D500540BNT Brushed Nickel Fairmont??...
How to you get the cap off the shower handle/
try a magnet before drilling if it don't work drill a small hole do not push in to screw
Cannot get the cap off the shower handle of a Danze fixture
not familiar with that exact unit but alot of the caps unscrew or pop out when pried or you may have set screw on body
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze D500540BNT Brushed Nickel Fairmont?? Single Handle Pressure Balance Logo
267 people viewed this question
Top Danze Home Experts
Mike
Rabbit Brains
Rabbit Brains
Bill Boyd
Are you a Danze Home Expert? Answer questions, earn points and help others
