Question about Landice L7 LTD Executive Trainer Treadmill
Landice L7 Exec Trainer won't stay stopped after I push stop ****
I have a 1999 Landice L7 Executive Trainer. If it's running and I push Stop button - it stops for a second or so - then it starts right back up again. All other functions seem to work ok. If it's running and I push Pause button - it pauses like it should - and when I push Pause button again it starts back up. All the other programing functions work fine
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I need instructions for a LANDICE L7 LTD PRO SPORTS treadmill
You can get the manual on link below.
http://site.thefitnessoutlet.com/landice/LandicePTManual.pdf
Posted on Jan 27, 2010
maxtreadmill
  • 832 Answers
SOURCE: Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Posted on Feb 28, 2010
  • 20 Answers
SOURCE: Motor or belt sqeals -
this may require proper troubleshooting but it is either the belts on the motor needs changing or the track belt ihas come to the end of it's usage life... but check thorougly.
Posted on Apr 09, 2011
Reset incline
Run the software calibration for easy diagnostic and fix it. God bless you
Jul 15, 2013 | Landice L7 LTD Executive Trainer Treadmill
Landice L7 treadmill won't turn on
1)LUBE the deck belt, maybe you have a deck belt worn, by lack maintenance.
2) Lube the rollers bearings, in according with the maintenance schedule.
3) Test the main motor for voltage input, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) After fixing RUN the software calibration for diagnose, and troubleshooting.
May 08, 2012 | Landice L7 Executive Trainer Treadmill...
Motor or belt sqeals - adjusting running belt does nothing. Also the tension on the belt from electric motor to running belt roller appears to be correct set with approx. 40 degree twist occurring. What...
Apr 04, 2011 | Landice Exercise & Fitness
Landice L7 motor voltage in wet conditions
What do you think--what changes when something happens???
Sep 19, 2017 | Landice L8 LTD Cardio Trainer Treadmill
I need a manual for a carl lewis treadmill
You can download the Carl Lewis Treadmill manual here
Apr 20, 2009 | Landice L7 LTD Executive Trainer Treadmill
Landice L9 Treadmill - Loss of Speed Signal Code
at starting, trys to go to speed and then reads LS on screen and runs very slow, with no response to any buttons.
Feb 26, 2009 | Landice L9 Cario Trainer Commercial...
Landice L7 LTD Executive Trainer Treadmill Logo
90 people viewed this question
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Dave
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
