Question about Mitsubishi CS-35405 TV
Set only has a thin line across,but sound is still there Is this something that I can repair myself ? I dont know much... 1 Solution
  • 4,234 Answers
This is a problem with the vertical circuit. It can be as simple as poor solder connections at the vertical IC or a defective IC. Look for a small flat IC attached to a heatsink with about 11 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that does not resolve the problem, replace the IC. Please note that there are potentially dangerous high voltages present inside the set even when unplugged.
Keep us posted as there may be other components that need to be replaced. If so, the symptoms will change. Report them here and we'll provide additional details.
Thanks,
Dan
Posted on Feb 23, 2009
I have a thin horizontal line across my dell latitude laptop screen
If the thin line is always there, you have a set of pixels burned out. This usually occures vertically. There is easy fix, except to replace the screen. If the laptop is under warrenty, contact the manufacture for repair options.
Sorry could not be something easier for you.
Mar 19, 2012 | Dell Latitude D630 Notebook
Slight damage by impact.
Dont worry its not about to die but................. that hairline crack could expand and to avoid this you could start by not hitting it hard or moving the pen past that line to much. You could ask any videogame seller (in stores obviously) were it can be fixed believe me they told me were this guy is that fixed my gamecube console and ds but scince i dont know were you live i dont think it would be usefull to tell you. I hope this really helps you and plkease post me a comment. By the way if you know someone near San diego that fixes ds stuff tell me because the guy i know doesnt know how to fix something. tnx
Jan 16, 2009 | Nintendo DS Lite Console
Thin white line across center of screen Fisher PC-32S90
yes there's a lose connection of your tv. It needs to re solder.if you know how to solder .,solder the vertical section specially the vertical I but be careful of short circuite coz it may damage your tv set.
Nov 16, 2008 | Fisher PC-32S90 TV
My mitsubishi CS-35405
This condition can be easily fix by replacing and IC that is the vertical amplifier.
The number is something like LA7835 or LA7836, this IC is mounted on a heatsink.
Do a search in google for it.
Mar 01, 2008 | Mitsubishi CS-35405 TV
Thin black line across display screen on psp
yes unfortunately i think its been dropped by the sounds of things,and yes it can be repaired,you can purchase a screen off ebay thier not that expensive,if you know anybody thats electricly minded if so let me know and i'll send you the webpage that shows you how to do it step by step.dont send it away to be mended what ever you do because it'll cost more to repair than its worth.
Jan 26, 2008 | Sony PlayStation Portable (PSP) Console
TV Picture Reduced to Line across the Middle
This is called field-collapse. Either
1. The problem lies in the vertical deflection voltage-doubler circuit. The usual fault is a single capacitor of 100uF/35V that has failed. It is normally connected to a rectifier diode right at the vertical IC. Replacing the capacitor usually gets it working perfectly again.
or
2. The vertical drive IC has failed.
If you are finicky around technical work, then a reputable local repair shop in your locality should do it quickly for you and charge only labour.
Jan 13, 2008 | Symphonic ST419E TV
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Jun 14, 2006 | Toshiba 35A44 35" TV
Televison & Video Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
