Question about Canon imageRUNNER C3200 Copier
Canon IR 3030 error code 000 002-0000
The copier started giving the error message E000 002-0000 a few days ago. It does not get past the initial startup it goes immediately to the error screen. We attempted to get to the control panel but it would not let us. We have no idea what the error message means or what would have started causing it.
Any help that can be given would be wonderful
This code is for the fixing area. I have found that most times it is the lower pressure roller bearings that have seized up and need to be replaced. it could also be the main thermistor has a problem, it would have to be replaced or cleaned ( try cleaning first). on the rare occasion a retaining clip has broken and had jammed the upper roller. The best thing would be to check everything in the fixing area. it is under the yellow cover that gets very hot.
Posted on Mar 07, 2009
What does error Code e00030000 from Canon ir 5075 Mean?
I have come across :
E000 - The heater fails to heat
E003 - There is an error in the rise in temperature
Can you recheck the error message?
Aug 07, 2014 | Canon Office Equipment & Supplies
Canon iR 2022 gives a system error E000 and error E003, what could be a problem?
how to clear error code e000 please help me copier ir 2022 show me how to clear
May 19, 2011 | Office Equipment & Supplies
Canon IR 2016
Additional Functions>2 key>8 key>Additional Functions (each key is pressed seperately, unlike regular iR copiers) Go to Copier>Functions>Clear> Err_ or Err_Clr. An E000 is a fuser code.
Aug 29, 2008 | Office Equipment & Supplies
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
Technical suport
I have e000 message on my machine IR 1600
Jan 24, 2008 | Canon imageRUNNER 2000 Copier
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
Nov 03, 2007 | Canon imageCLASS D860 All-In-One Laser...
Canon imageRUNNER C3200 Copier Logo
631 people viewed this question
old marine
old marine
