Can't instal the software using the CD-ROM
I have tried installing the software using the CD-ROM that came with the 3 in one and so far my computer cannot recognize it.
please help
  • 76 Answers
Make sure everything is pluged , also make sure that the desk that they sent you for the printer is compatible with the operating system that on your computer. I have a 3 in one and they sent me a disc for a mac when i use windows
Posted on Feb 23, 2009
1305.Error reading from file....MoviesG.big How can i fix it?, should i delete it?... thnks
This issue may occur if one of the following conditions are true:
  • There is a configuration issue with the CD-ROM drive.
  • The MDAC (Microsoft Data Access Components) is damaged or is not installed properly.
  • There is an issue with the CD-ROM media. For example, the program CD-ROM is damaged or dirty.
Solution:
  • Examine the CD-ROM or DVD Disc
  • Clean the Program CD-ROM or DVD
  • Test the CD-ROM or DVD in another Drive
  • Clean the Drive
  • Quit Unnecessary Software
  • Look for Known Issues with the Drive or Recording Software
  • Check for Drive Firmware Updates
  • Make Sure That You Are Using Protected Mode CD-ROM Drivers
  • Enable and Disable UDF Support
  • Reduce Drive Caching
  • Disable Auto-Insert Notification
  • Remove Duplicate Drives]
  • Restart Windows in Safe Mode
  • Clean Boot Your Computer
  • Install the MDAC Update
  • Check for Alternate Installation Locations
if problem persist contact game manufacturer.
Jul 02, 2011 | EA - Electronic Arts Command & Conquer 3:...
Have an EeePC, then i cannot run cd-rom compact disk. EOTSQAAJ
You will either need to share a CD drive on another computer on the network, or purchase an external CD drive in order to install this from the CD.
Mar 08, 2011 | Arcsoft PhotoImpression 5
I have an acer netbook computer running with vista and 2 mg RAM. I am using a usb CD Rom drive to lload programs. When I try to insstall Office Enterprise 2007 (licensed for students and faculty) the disk...
Sorry, but that's not the case. Most DVD drives will read CD's, but most CD drives will not read DVDs, so unless yours specifically says it's a DVD drive, It's not going to work for you. HINT: the cost of a DVD drive is far less than the cost of Office software.
Dec 08, 2009 | Microsoft Office Professional 2007 Full...
When I install the D7260 printer using the CD-Rom supplied it works fine. Then after a few days only the top two or three lines of the first page are printed and, after a long pause, the sheet comes out....
Many issues are caused when the HP Photosmart is connected to computer using a USB cable before the HP Photosmart software is installed on the computer. IF you connected the HP Photo smart to your computer before the software installation screen prompts you to do so, you must follow these steps.
Troubleshooting common setup issues :
1) Discoonect the USB cable from the computer.
2) Uninstall the software (if you have already installed it.)
3) Restart you computer.
4) Turn off the HP Photosmartm wait one minute then turn it on.
5) Reinstall the HP Photosmart software.
If your installation is incomplete, or if you connected the USB cable to the computer before prompted by the software installation screen, you might need to uninstall and reinstall the software. Do not simply delete the Hp Photosmart application files from your computer. Make sure to remove them properly using the uninstall utility provided when you installed the software that came with the HP Photosmart.
To uninstall from a Window computer and then reinstall
1) On the Windows taskbar, click Start, Settings, Control Panel (or just Control Panel).
2) Double-click Add/Remove Programs (or click Uninstall a program).
3) Select HP Photosmart Driver Software, and then click Change/ Remove.
Follow the onscreen instructions.
4) Disconnect the HP Photosmart from your computer.
5) Restart your computer.
Note : It is important to that you disconnect the HP Photosmart before restaring your computer. Do not connect the HP Photosmart to your computer untill after you have reinstalled the software.
6) Insert the HP Photosmart CD-ROM into your computer's CD-ROM drive and then start the Setup program,
7) Follow the onscreen instructions and the instructions provided in the Setup Guide that came with the HP Photosmart.
Nov 09, 2009 | HP Photosmart D7260 Printer
How do i install a Kodak esp series 3 printer to a dell computer
Take the CD-ROM that came with the printer, and install the software.
When prompted, connect the printer to your computer.
If you have lost the CD-ROM disk, you can download the software from Kodak's web-site.
Oct 29, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Bought a new computer and want to use usb 3g adapter on new computer. I think I need to install software, however there is no disk drive as it is a netbook
Dear johnls,
Try to copy the installation CD to a flashdisk the run the installation from flashdisk when you connect it via USB jack on your netbook.
Or try to connect the external Optic Drive (CD/DVD ROM), wait until the netbook complete the installation of your optic drive. Restart your netbook with external CD ROM connected via USB jack, then run the 3G installation from your External CD ROM.
GoodLuck!
Best regards,
bionic23
Oct 27, 2009 | Computers & Internet
My scanner is not working. Can't open HP director on my laptop. I tried to reinstall CD that came with it, but " more recent version installed" Printer and copier work fine.
Here are some diagnostics.
1. Go to control Panel and then to scanners & camera.
2. look for your scanner there.
3. if you find your scanner there try to scan from the wizard and you will be able to scan you docs.
To Reinstall the Hp Director....
1. first uninstall the HP director software using the removal utility located in your cd...
The uninstaller on the Internet is newer and works better than the one on the CD-ROM. Use this method only if the Internet version is not available. Follow the steps below to use the CD-ROM version only if you cannot get the regular uninstall to work correctly and cannot access the Internet:
  1. Leave the USB cable disconnected from the all-in-one.
  2. Insert the all-in-one CD-ROM into the computer. Cancel or close any installation windows that appear.
  3. Right-click the Start button, and then click Explore . This will open Windows Explorer.
  4. In the pane on the left, locate the CD-ROM drive letter that contains the all-in-one CD-ROM.
  5. There are two different versions of the software for some of these models. Use the file path that pertains to your version of the all-in-one software.
    • Early versions of the HP Officejet 6100 and PSC 2100 and 2200 series: Double-click the file hposcr01.exe , located in the Drivers\Uninst\language (ENU for English, ESN for Spanish, FRA for French, or PTB for Portuguese) folder of the CD-ROM.
    • The newer software version: Double-click the file Cleanall.bat , which is located in the Util\CCC\Cleanup folder of the CD-ROM.
    ONCE THE SOFTWARE IS COMPLETELY REMOVED.RESTART THE PC AND TRY TO INSTALL THE HP DIRECTOR SOFTWARE FROM THE CD.
Let me know for any further help....
http://www.ikarmatech.com
Sep 08, 2009 | HP PSC 2410 All-In-One InkJet Printer
I lost the cd rom to install my webcam, and now cannot install.
Try to search online for the webcam manufacturer driver and manual. If you have usb pen drive and another computer try to copy the installation file from the cd using other computer on pen drive and then connect the pen drive and trnasfer software and install software and driver. Good luck.
Aug 27, 2009 | Ezonics EZCam Plus Webcam
Brand new computer and i did not install the adobe it came with the computer Vista basic and i get the 1311 error message when i try to run adobe computer 1 day old !
no big problm if u comp is new r old...
When you try to install Adobe Acrobat 6, 7, 8, or 3D on Windows, the installer returns the error message "Error [1311, 1335 or 2350]. Source file not found: [drive name]:\ Adobe Acrobat [version]\data1.cab. Verify that the file exists and that you can access it." If you click Retry, the installer returns the error message "Cannot find the file Adobe Acrobat [version]\data1.cab."
Solution Perform one or more of the following solutions:
Solution 1: Check the Acrobat CD-ROM.
Make sure that the CD-ROM from which you are installing is free of dirt and debris. If necessary, clean the CD-ROM with a soft, lint-free cloth.
Solution 2: Temporarily disable anti-virus software, and then install Acrobat.
For instructions, see the documentation for the anti-virus software or contact the manufacturer.
Solution 3: Extract the compressed installation files, and then install Acrobat.
  1. Right-click the folder and choose Extract All.
  2. Follow the on-screen instructions.
  3. To install Acrobat, double-click the Setup.exe file located in the folder that contains the extracted files.
Solution 4: Uninstall the CD-ROM drive and let Windows redetect it, and then install Acrobat.
  1. Right-click My Computer and choose Properties.
  2. Click the Hardware tab, and then click Device Manager.
  3. Expand the DVD/CD-ROM drives section.
  4. Right-click each device listed under DVD/CD-ROM drives and choose Uninstall. Click OK to confirm.
  5. Close Device Manager and restart the computer.
  6. After Windows redetects the DVD/CD-ROM drive(s), insert the Acrobat CD into the CD-ROM drive and install Acrobat.
Solution 5: Install Acrobat from the desktop.
  1. Insert the Acrobat CD into the CD-ROM drive.
  2. Copy the Acrobat folder from the Acrobat CD to the Desktop.
  3. Double-click setup.exe in the Acrobat folder on the Desktop, and then follow the on-screen instructions to complete installation.
Additional Information Errors 1311, 1335, and 2350 occur when the Acrobat installer is unable to access the necessary files from the CD-ROM drive. These same errors may also occur if antivirus software interferes with an installation or if the installation files are compressed.
thank u sir,, if u feel i helped u, then plz vote/rate me with good marks..thank u!!
Jul 18, 2009 | Dell Inspiron 530s Desktop Computer...
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
19 people viewed this question
jasbo
jasbo
